Need some advice
10-08-2007, 14:48
Need some advice
I have an 84 Subaru four wheel drive as my toad and its a wonderful
little car. But I have one problem and that is when I make a tight
slow right hand turn the steering stays in that position and will not
correct itself. By this I mean it will not come back to a neutral
position. This is kind of buggy as I really haft to watch out when I
do make this type of turn as the tires will just not correct themselves
and causing them to drag along turned. Is there any device I can use
to help correct this problem? Has anyone here else had that kind of
problem. Sure would like some answers on this baddddddd problem.
http://s2.photobucket.com/albums/y4/1942...l%20Bird/?
Jipjob
Rebel Bird
10-08-2007, 15:46
Need some advice
Jon I'm relying on my old f#*t memory here but sometime back a few years ago
I heard that most any vehicle could be towed four down with the exception of
some Subaru's. It was something to do with the geometry of their steering.
Their caster I believe. I could be wrong on the Subaru but I'm sure the
problem was steering related. Also in the past some people, who wished a
more positive return to the steering wheel's neutral position, have
advocated the use of bungee cords to restrict the steering wheel travel and
input a force that will center the wheel more readily.
> Jipjob
> Rebel Bird
Rob, Sue & Merlin Robinson
94 WLWB
10-08-2007, 16:23
Need some advice
Jon further to your problem I checked around Remco site
http://www.remcotowing.comand I couldn't find a towing product for Subaru
anywhere on the site. Give
them a call and ask them if they provide towing equipment for Subaru. If
they don't then maybe they can explain any problems that may exisit. Their
number is 1 (800) 228-2481
> Jipjob
> Rebel Bird
94 WLWB
10-09-2007, 01:44
Need some advice
The tow bar needs to be parallel with the ground, usually requires a drop hitch
ball for the bus.
MH
Sent: Monday, October 08, 2007 9:48 PM
Subject: [WanderlodgeForum] Need some advice
Jipjob
Rebel Bird
10-09-2007, 02:07
Need some advice
I've heard that some 'early' Sabarus have insufficient caster, so the
tires won't re-center. You might talk to a front-end shop and see if
there's anything that can be done.
aeonix1@...
On the road at Hurricane UT (Zion NP)
> themselves
10-09-2007, 03:24
Need some advice
I understood the 'parallel to the ground rule' was to keep inerta
force of the toad from pushing the ass of the motorhome farther up in
the air then the natural reaction of braking. It also keeps
acceleration from 'picking up' or 'pulling down' on the front end of
a toad at rest.
I have seen toads with bungie cords on the steering. I wonder if
there is a chance that the bungie force could get set off center and
the wheels will run untrue when your bus is center/true. Or if you
pass 180 degree on the steer-wheel, you cam past a return to
true/center?????
I would tie a rope that limits the turning of the steering wheel to
less than 180 deg.(or prior to the point a sharp right turn make a
recenter unatainable) At center/true the rope would be relaxed and
the caster reaction will have no opposing forces. but the tires would
skid on sharp turns if more than a 180degree steering wheel turn was
naturaly required.
Some times The best mod is a a ForSale sign.
GregoryO'Connor
94ptRomolandCa
a drop hitch ball for the bus.
> MH
> From: Jon
wonderful
tight
not
when I
themselves
use
of
> Jipjob
> Rebel Bird
10-09-2007, 03:28
Need some advice
if
> Pete Masterson
> aeonix1@...
wonderful
tight
not
when I
> > themselves
use
of
Well just my luck that when I called up a rep that sells front end
towing units that the subaru he stated is one that does has a problem
with tracking. Oh well 300 dollars out the window and now to find a
used car dolly. Jon
Jipjob
Rebel Bird
10-09-2007, 07:39
Need some advice
Hi Jon,
Google steering stabilizers for your rig...see what pops up.
Bob Lawrence
84 PT36
Tacoma, Wa.
themselves
> Jipjob
> Rebel Bird
10-09-2007, 08:46
Need some advice
The vehicle is not properly aligned or you have a faulty part in the
steering.
> Jipjob
> Rebel Bird
10-09-2007, 09:33
Need some advice
My understanding of the angle of the tow bar relative to the toad
is that the toad end should be level or slightly lower (a couple of
inches). If the toad end is too low it will force the front end of
the toad down hard when breaking and stress the suspension and front
tires. If the toad end is higher, the front of the toad will rise up
and in extreme braking situations and the toad could vault into the
rear of the coach.
Gardner
78FC33
in
of
> a toad at rest.
> true/center?????
to
would
was
> naturaly required.
> GregoryO'Connor
> 94ptRomolandCa
requires
> > MH
> > From: Jon
> wonderful
> tight
will
> not
neutral
> when I
> themselves
can
> use
kind
> of
problem.
> > Jipjob
> > Rebel Bird
