Air filter replcement
10-09-2007, 09:23
Today for the first time after owning 7 wanderlodges I checked the air
filter in our 88 pt 40. I dont know why I never did it, I always thought it would be fine since it was so big and usually the vaccume gauge thing registered in the green. Anyway, I took it out today and it was quite dirty a lot of pine needles and dust. It is a baldwin filter and napa has it for 110 dollars, but I was wondering if anyone makes a less restrictive cleanable filter. Should I replace it even though the indicator is registering green? I could just blow it off with the compressor I guess. Robert Rahn Kalispell, Mt. 88 pt 40 |
10-09-2007, 09:36
I think your visual inspection trumps the indicator. I've heard you can blow
out most any air filter once but beyond that, the fibers begin tangling up and degrading. Considering what it protects, you can't be too careful. Brad Barton 00LXiDFWbbartonwx@... To: WanderlodgeForum@...: chaunceyboyblu@...: Tue, 9 Oct 2007 21:23:01 +0000Subject: [WanderlodgeForum] Air filter replcement Today for the first time after owning 7 wanderlodges I checked the air filter in our 88 pt 40. I dont know why I never did it, I always thought it would be fine since it was so big and usually the vaccume gauge thing registered in the green. Anyway, I took it out today and it was quite dirty a lot of pine needles and dust. It is a baldwin filter and napa has it for 110 dollars, but I was wondering if anyone makes a less restrictive cleanable filter. Should I replace it even though the indicator is registering green? I could just blow it off with the compressor I guess.Robert RahnKalispell, Mt.88 pt 40 _________________________________________________________________ Peek-a-boo FREE Tricks & Treats for You! http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us [Non-text portions of this message have been removed] |
10-09-2007, 10:05
Robert,
That price sounds about right for NAPA, but you can get that filter much cheaper at a truck parts store. I usually get the Donaldson Duralife brand for about $40-50 or so at my local supplier. I believe the cross reference for that should be as follows: Air Filter AC A760C Baldwin PA2501 Donaldson (Duralife) P12-9396 Donaldson EAF5024 (Extended Life) Fleetguard 1:AF-954M FRAM CA3517 Lubrifiner LAF9396 Purolator AF3057 WIX 42610 NAPA FIL2610 If it looks really dirty, I would probably change it out. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Robert & Teri Rahn" > > Today for the first time after owning 7 wanderlodges I checked the air > filter in our 88 pt 40. I dont know why I never did it, I always > thought it would be fine since it was so big and usually the vaccume > gauge thing registered in the green. Anyway, I took it out today and it > was quite dirty a lot of pine needles and dust. It is a baldwin filter > and napa has it for 110 dollars, but I was wondering if anyone makes a > less restrictive cleanable filter. Should I replace it even though the > indicator is registering green? I could just blow it off with the > compressor I guess. > Robert Rahn > Kalispell, Mt. > 88 pt 40 > |
