depree dump valves
05-12-2005, 00:23
depree dump valves
Replaced my black water dump valve (gold) with silver in March. Seems like
it cost about $125. Randy will know the EXACT amount! Valve was easy to install--I made it a little more difficult than necessary but Randy told me to do the obvious. There is no comparison between the old valve & the new one. IT OPERATES FLAWLESSLY. BTW I found the manual tool used to open struck valves when I installed the new valve. It's right by the valve, but not obivous to the (my) eye. Hopefully it will stay mounted in place and suffer from lack of use. Bill in Roanoke, VA 1987 FC-35 [Non-text portions of this message have been removed] |
05-12-2005, 03:30
depree dump valves
I am sure this has been answered before, but what is the cost and what
is involved in replacing the black actuators in my 89SP with the silver ones? |
05-12-2005, 04:56
depree dump valves
Bill: The TOOL is the best part of that system. It work's just great!
It's well designed and never once have I had a failure using the TOOL. Infact I have grown so attached to it that I just automatically reach in and grab the tool before I attempt to open either valve. I feel very confident and relaxed using it. I've even wrapped a little black tape on the end to make it more cushioned in my hand. Great piece of engineering.. Bob, 93pt-il. |
05-12-2005, 05:38
depree dump valves
Bob are you saying that the Dupree air Dump valves do not work all of the
time and you have to constantly have the TOOL handy? I am not trying to be facetious just trying to understand how they work. Tom 1982 FC35 Vernon Center,NY At 04:56 PM 5/12/2005 +0000, you wrote: >Bill: The TOOL is the best part of that system. It work's just great! >It's well designed and never once have I had a failure using the TOOL. >Infact I have grown so attached to it that I just automatically reach >in and grab the tool before I attempt to open either valve. I feel very >confident and relaxed using it. I've even wrapped a little black tape >on the end to make it more cushioned in my hand. Great piece of >engineering.. Bob, 93pt-il. |
05-12-2005, 05:52
depree dump valves
Tom ,I am wondering if there is a grease I can put on the shaft to make it
slide with out an assist from the toolkDave 91 kKWLPT 40 & 82 FC 35 >From: Tom Warner >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: Re: [WanderlodgeForum] Re: depree dump valves >Date: Thu, 12 May 2005 13:38:37 -0400 > [Non-text portions of this message have been removed] |
05-12-2005, 08:06
depree dump valves
If your Dupree valves are sticking you can easily pull them out and check
the paddles to see if you need new ones. Another fix could be that you just need to shoot a little silicon spray on the shaft and in the air inlet/outlet orfices. You'll get a million miles out of these valves but they do require a little lube every ten years or so. Just did mine and Tom McCarthy's 1995 and they work like new. Rob 1994 WLWB Original Message: ----------------- From: David Heibult ceheibult@... Date: Thu, 12 May 2005 12:52:19 -0500 To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: depree dump valves Tom ,I am wondering if there is a grease I can put on the shaft to make it slide with out an assist from the toolkDave 91 kKWLPT 40 & 82 FC 35 >From: Tom Warner >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: Re: [WanderlodgeForum] Re: depree dump valves >Date: Thu, 12 May 2005 13:38:37 -0400 > [Non-text portions of this message have been removed] <!-- |**|begin egp html banner|**| --> Yahoo! Groups Links
<!-- |**|end egp html banner|**| --> -------------------------------------------------------------------- mail2web - Check your email from the web at http://mail2web.com/ . |
05-12-2005, 08:54
depree dump valves
I honestly dont know Dave. I tried everything with the Dupree manual valve
on my black water tank and finally gave up. I order new "guts" for it, lubed everything with silicon grease and a few months later it got even harder to pull the handle out and even worse to get it back in. I finally got frustrated enough to buy the electric Drain Masters. I just finished installing them today.........and like Randy says I may be sorry. But for now will just have to wait and see. Nice thing about this is that now I know how easy it really is to change the plumbing on the tanks. I just may do it again a little later and completely hide the plumbing. Now these FCs with a Side bath look like they have a guided missle strapped to the side. Tom 1982 FC35 Vernon Center,NY At 12:52 PM 5/12/2005 -0500, you wrote: >Tom ,I am wondering if there is a grease I can put on the shaft to make it >slide with out an assist from the toolkDave 91 kKWLPT 40 & 82 FC 35 > > >From: Tom Warner > >Reply-To: WanderlodgeForum@yahoogroups.com > >To: WanderlodgeForum@yahoogroups.com > >Subject: Re: [WanderlodgeForum] Re: depree dump valves > >Date: Thu, 12 May 2005 13:38:37 -0400 > > > > > >[Non-text portions of this message have been removed] > > > >---------- >Yahoo! Groups Links > * To visit your group on the web, go to: > * > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/W\ anderlodgeForum/ > > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. |
05-12-2005, 09:40
depree dump valves
20 minutes work and $129.50 each. everything will be new except the
housing,which is glued in on your coach. randydupree93wb ----- Original Message ----- From: fred89sp To: WanderlodgeForum@yahoogroups.com Sent: Thursday, May 12, 2005 11:30 AM Subject: [WanderlodgeForum] depree dump valves I am sure this has been answered before, but what is the cost and what is involved in replacing the black actuators in my 89SP with the silver ones? ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-12-2005, 09:44
depree dump valves
ouch! i didnt engineer that "tool"...its only needed on the older black or gold
cyls. randydupree93wb ----- Original Message ----- From: Bob & Carol Howald` To: WanderlodgeForum@yahoogroups.com Sent: Thursday, May 12, 2005 12:56 PM Subject: [WanderlodgeForum] Re: depree dump valves Bill: The TOOL is the best part of that system. It work's just great! It's well designed and never once have I had a failure using the TOOL. Infact I have grown so attached to it that I just automatically reach in and grab the tool before I attempt to open either valve. I feel very confident and relaxed using it. I've even wrapped a little black tape on the end to make it more cushioned in my hand. Great piece of engineering.. Bob, 93pt-il. ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-12-2005, 12:20
depree dump valves
Yes, I do have the older GOLD colored valve. It actually looks more
orange than gold. I've replaced the paddle's and adjusted the air several times. I do like the TOOL if the air is a little low or whatever , I just give it a little nudge with the TOOL it never fail's. It's also a Great conversation piece, everyone want's to know how the TOOL work's. Seriously, I think the valve's are great. When you look at some of the other plumbing system's on the market it make's your BRUTE system look great. I can't imagine SOB holding back 800# plus waste. Work's ok for me.. Bob 93pt Illinois. |
