Troubleshooting Bendix Fast Idle/Cruise Control on 89 35FC 3208 ATAAC
10-14-2007, 04:40
I need help understanding how to set the fast idle speed using the
cruise control on my 89 35FC 3208ATAAC. With engine idling at 650
rpm and Cruise Control switch turned On, depressing the SET seems to
have no effect on the rpms; however when the RESUME switch is
depressed, the rpm immediately increases to 3000. I quickly turn the
Cruise Control switch to OFF and the rpms reduce to 650 or 700 range.
I've owned this coach just over 1 year and fixing this idle speed
thing is now reached the top of the "To Do" list.
The Cruise Control does seem to operate, but not smoothly; if set at
55 mph for instance, when speed drops to 55 the throttle opens FULLY
and Turbo Boost goes to 8 or 10 psi or so depending on the terrain
and then vehicle speed goes slightly past the Set speed of 55 mph at
which the time the throttle seems to fully close. Behaves as though
throttle is either fully open or fully closed...no in between.
Another serious thing...it appears that touching the brake does not
disengage the Cruise Control; the Cruise Control can be disengaged
by turning the CC switch to OFF.
Because of the above issues I do not have a functional Cruise Control
and feel it's unsafe to engage on most highways and when I do use it
the fuel economy suffers because of the jerky responce.
Would very much like to get the obsolete Bendix back operational if
there is and easy fix; faulty ground? poor connections? bad ECM?
Please share your experiences with me and other on this board.
Perhaps its time to invest in a KING Cruise or Rostra?
Dick Gideon
Freedom Bird
1989 35FCSB
Rolla, MO
10-14-2007, 06:00
Is fast idle on all models handled through the CC? My fast idle
switch works fine, but my CC is inop on the road.
Scott Forman
86 PT38
Memphis
--- In WanderlodgeForum@yahoogroups.com, "Richard Gideon"
range.
Control
> Dick Gideon
> Freedom Bird
> 1989 35FCSB
> Rolla, MO
10-14-2007, 07:09
Hi Scott: Not sure how your PT 38 works; On my FC, reading from my
owners manual, the engine idle speed can be increased, while parked,
by means of the cruise control switches; push the ON-OFF rocker
switch to ON; then push and release RESUME rocker switch until
desired RPM is attained. RPM will return to normal idle speed when:
1. CRUISE CONTROL ON-OFF switch is turned off.
2. Transmission selector is moved from N position
3. Parking brake is released
NOTE: Pressing on brake pedal will decrease RPM but speed will return
to higher setting as soon as pedal is released.(copied from my manual)
(On my 1989 FC, when trying to bump up the idle, pushing the RESUME
rocker switch immediately causes the 3208 engine to soar to 3000 rpm).
Dick Gideon
Freedom Bird
1989 35FCSB
Rolla, MO
> Scott Forman
> 86 PT38
> Memphis
to
> range.
at
FULLY
at
though
not
> Control
it
if
> > Dick Gideon
> > Freedom Bird
> > 1989 35FCSB
> > Rolla, MO
10-14-2007, 10:14
PTs have a separate "high idle" switch on dash.
Scott
parked,
when:
return
manual)
rpm).
> Dick Gideon
> Freedom Bird
> 1989 35FCSB
> Rolla, MO
> --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@>
> > Scott Forman
> > 86 PT38
> > Memphis
650
seems
> to
turn
> the
> > range.
speed
set
> at
> FULLY
terrain
mph
> at
> though
> not
disengaged
> > Control
use
> it
operational
> if
> > > Dick Gideon
> > > Freedom Bird
> > > 1989 35FCSB
> > > Rolla, MO
10-15-2007, 03:19
Scott,
My Tachometer went out last week on a trip and my CC quit at the same time. The
CC must work off the Tach. Are you having trouble with your Tach.
Howard T., Sowega, 86 PT40
Sent: Sunday, October 14, 2007 2:00 PM
Subject: [WanderlodgeForum] Re: Troubleshooting Bendix Fast Idle/Cruise
Scott Forman
86 PT38
Memphis
range.
Control
> Dick Gideon
> Freedom Bird
> 1989 35FCSB
> Rolla, MO
Checked by AVG Free Edition.
Version: 7.5.485 / Virus Database: 269.14.9/1067 - Release Date: 10/12/2007
6:02 PM
10-15-2007, 03:36
Scott,
My Bluebook describes the same procedure as Dick described.
Howard T.
Sent: Sunday, October 14, 2007 6:14 PM
Scott
parked,
when:
return
manual)
rpm).
> Dick Gideon
> Freedom Bird
> 1989 35FCSB
> Rolla, MO
> > Scott Forman
> > 86 PT38
> > Memphis
650
seems
> to
turn
> the
> > range.
speed
set
> at
> FULLY
terrain
mph
> at
> though
> not
disengaged
> > Control
use
> it
operational
> if
> > > Dick Gideon
> > > Freedom Bird
> > > 1989 35FCSB
> > > Rolla, MO
6:02 PM
10-15-2007, 04:22
This is getting interesting.
Howard, my Tach is inop (has been since before I purchased in July),
but my cruise control is working fine. I have an 86 PT-40 with a
6V92. Are you the 6V or the 8V. I would assume they both use the
same CC hardware.
Glenn Allen
1986 PT-40
Marietta, GA
--- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt"
> Scott,
same time. The CC must work off the Tach. Are you having trouble with
your Tach.
> From: Scott Forman
> Scott Forman
> 86 PT38
> Memphis
10-15-2007, 04:50
PT cruise/air throttle/high idle
Some time back, I posted to the files section, a couple of files on how
these systems work and inter act.
As for the FC's it is a little difference because the factory <BB> dip
switch settings allowed the fc cruise controls to work slightly different
than the PT's.
As for the problem in the FC, where it is on or off and no in between, I
would suspect the CC5 potentiometer internal of the cylinder to be faulty.
All this can be checked with a decent Multimeter and following the checks
in the Bendix manual that should be in the blue box.
The only thing I have found that was done a little funky form the factory,
is how the clutch switch was wired up since there are no clutches in the
Birds and that was done with 2 solenoids in the system. I have actually
taken those out of the system to get my cruise working properly and that
was done with a pair of side cutters! One snip and you have cruise.
Now the problem with the break pedal not canceling the cruise is or has
generally been a bad set switch or corroded contacts in a connector. And
can usually be cleared up by cleaning the pin contacts coming from the
Bendix control.
Remember that our Coaches put out 120 to 130 psi of air and there is a
regulator with the bendix set up to drop that pressure to 80 to 90 psi,
thereby making the working difference of only a few psi differential that
the electronics of the bendix system reads and enacts on.
Safe travels,
84FC35
Duncan, Oklahoma
10-15-2007, 07:41
Mine is an 8V92. Maybe just a coincedence.
Sent: Monday, October 15, 2007 12:22 PM
same CC hardware.
Glenn Allen
1986 PT-40
Marietta, GA
> Scott,
your Tach.
> From: Scott Forman
> Scott Forman
> 86 PT38
> Memphis
6:02 PM
10-15-2007, 09:50
Thanks for the reply Ralph: Early this morning I got into my "blue
box" and retrieved the booklet describing the operation and
troubleshooting the Bendix Cruise Control System (SD-10-1)and on page
15 of the booklet I found the symptoms, cause & remedy for what
appears to be ailing the CC on my FC.
V. Cruise Control System oscillates above and below the speed
setting. Will not hold a specific speed setting within plus or minus
1 mph on level highway.
Cause, CC-5 potentiometer or its wiring is defective.
Remedy. Visually inspect for broken or obviously damaged wiring to
the CC-5 potentiometer (Figure 13). Disconnect wiring connector 3 in
Figure 13 and check the resistance between the sockets shown:
1 and 3 3600-4400 ohms
2 and 3 1080-1320 ohms
1 and 2 4320-5280 ohms
If these readings are not obtained, replace the CC-5 potentiometer.
I'll post later this week, with the results of my testing. Thanks
for the guidance...I"ll dig out my digital volt/ohmeter.
Dick Gideon
Freedom Bird
1989 35FCSB
Rolla, MO
on how
dip
different
> than the PT's.
between, I
faulty.
checks
factory,
in the
actually
that
cruise.
has
connector. And
> Bendix control.
is a
psi,
differential that
> Safe travels,
> 84FC35
> Duncan, Oklahoma
