Cover for '80's 35 FC's
11-01-2007, 03:06
Hi All!
Does anybody know where one might purchase a good manageble cover for 80's model 35-foot FC's that has hatches for the A/C units? Maybe this asking does not exist. Having to fight too much debris and sun light exposure. Thanks for the help! Dru Dru and Debora Corpus Christi, TX 1983 FC 35 RB Steady Gittin' It! [Non-text portions of this message have been removed] |
11-01-2007, 03:28
I had a sunbrella cover made that weighs 75 lbs. I put it on the roof
with a fork lift and never took it off the bus. I found a canvas cargo bag at pepboys to store it ontop when traveling. I pull up the sides then roll the front to the center where the bag is then roll in the back. It take 15 min to uncover. Cover was just under a grand and bag was around 40 bucks. Maybe what you need is nursery netting for the roof. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, dru penland > > Hi All! > > Does anybody know where one might purchase a good manageble cover for 80's model 35-foot FC's that has hatches for the A/C units? Maybe this asking does not exist. Having to fight too much debris and sun light exposure. > > > Thanks for the help! > > Dru > > > Dru and Debora > Corpus Christi, TX > 1983 FC 35 RB > Steady Gittin' It! > > [Non-text portions of this message have been removed] > |
11-01-2007, 05:06
> > Hi All! > > Does anybody know where one might purchase a good manageble cover for 80's model 35-foot FC's that has hatches for the A/C units? Maybe this asking does not exist. Having to fight too much debris and sun light exposure. > > > Thanks for the help! > > Dru > > > Dru and Debora > Corpus Christi, TX > 1983 FC 35 RB > Steady Gittin' It! > > [Non-text portions of this message have been removed] Dru I have posted this is the past and what I use and its fairly resemble is a Costco Car Shelter. I would have used two units put together end to end but I do not have the room for this configuration. The only reason I used only one was because I did not have enough room for the second cover as it would have extended into my driveway. I used 10 ft electrical conduit pipes cut in haft to make 5 ft and then after putting up the cover I just slid the 5ft pipes into each leg of the car shelter. And then I slid the original pipes up till they were around 4 to 5 ft oft the ground. This made it about 12 high on the sides and about 14 ft in the middle. It really worked out great for me and at a cost of a little over 150 dollars its pretty cheap to construct. I have had no wind problem with it blowing over or anything like that as it is staked into the ground with the original ground pads. On the ends since I my motor home extends past the shelter I just used a heavy tarp to add the proper length so it was protected in that area. As far as how long the material will last? I have had a few of these shelters and they seem to last about five years. I think when its time to recover this unit I will just get a large tarp and then just recover the whole thing. Works good and keeps the old Rebel Bird cool and dry under my cheap little car port. JIpjob 78 Wanderlodge Bremerton > |
11-01-2007, 05:12
--- In WanderlodgeForum@yahoogroups.com, "Jon"
> > --- In WanderlodgeForum@yahoogroups.com, dru penland > > > > > Hi All! > > > > Does anybody know where one might purchase a good manageble cover > for 80's model 35-foot FC's that has hatches for the A/C units? Maybe > this asking does not exist. Having to fight too much debris and sun > light exposure. > > > > > > Thanks for the help! > > > > Dru > > > > > > Dru and Debora > > Corpus Christi, TX > > 1983 FC 35 RB > > Steady Gittin' It! > > > > [Non-text portions of this message have been removed] > > > Dru I have posted this is the past and what I use and its fairly > resemble is a Costco Car Shelter. I would have used two units put > together end to end but I do not have the room for this configuration. > > The only reason I used only one was because I did not have enough > room for the second cover as it would have extended into my driveway. > > I used 10 ft electrical conduit pipes cut in haft to make 5 ft and > then after putting up the cover I just slid the 5ft pipes into each > leg of the car shelter. And then I slid the original pipes up till > they were around 4 to 5 ft oft the ground. This made it about 12 > high on the sides and about 14 ft in the middle. It really worked > out great for me and at a cost of a little over 150 dollars its > pretty cheap to construct. I have had no wind problem with it blowing > over or anything like that as it is staked into the ground with the > original ground pads. On the ends since I my motor home extends past > the shelter I just used a heavy tarp to add the proper length so it > was protected in that area. > > As far as how long the material will last? I have had a few of these > shelters and they seem to last about five years. I think when its > time to recover this unit I will just get a large tarp and then just > recover the whole thing. > > Works good and keeps the old Rebel Bird cool and dry under my cheap > little car port. > > JIpjob > 78 Wanderlodge > Bremerton > > > Here's a picture of the shelter cover up but the sides have not been installed yet. http://tinyurl.com/2tnabu Jon Rebel Bird Bremerton > |
