Whistling windshield
11-01-2007, 12:07
I have a good wind whistle coming from my curb side windshield.
Haven't noticed any water. ANy tips on sealing it up? Scott Forman 86 PT38 Memphis |
11-01-2007, 15:35
Scott,
First check (on the outside) the inserted ribbing that forces the windshield rubber to tighten up. Could be that it is has shrunk and another section may be in order. You can also pull out that ribbing and stretch it out an put it back in the track. If that doesn't work...I've used black silicone ...pull back the windshield rubber on the outside and squeeze in a narrow bead of silicone. On 11/1/07, Scott Forman <sforman@...> wrote: > > I have a good wind whistle coming from my curb side windshield. > Haven't noticed any water. ANy tips on sealing it up? > > Scott Forman > 86 PT38 > Memphis > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
11-02-2007, 06:21
Are you sure it's the windshield?
I had a pretty good whistle from the curb-side (door) window. Fresh weather stripping (a kind of soft, fuzzy stuff with a sticky back) tamed the noise and a rattle as well. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at On Nov 1, 2007, at 6:07 PM, Scott Forman wrote: > I have a good wind whistle coming from my curb side windshield. > Haven't noticed any water. ANy tips on sealing it up? > > Scott Forman > 86 PT38 > Memphis |
