How many floors/levels does my black tank have?
05-13-2005, 06:19
1) I suspect that my black tank has a problem because I discovered,
after 3 weeks of use, that the drain valve was not closing completely. (2) What confuses me is, even after apparently emptying the black system, I still see water when I look down the hole through the commode. Why is there water in the tank below the commode even after emptying the black tank? I never used to notice the water until I discovered the above described drain problem. Thanks. Henry@... 1979 FC 35, McAllen, Tx |
05-13-2005, 06:26
Henry Claeys wrote:
> 1) I suspect that my black tank has a problem because I discovered, > after 3 weeks of use, that the drain valve was not closing completely. > (2) What confuses me is, even after apparently emptying the black > system, I still see water when I look down the hole through the > commode. Why is there water in the tank below the commode even after > emptying the black tank? I never used to notice the water until I > discovered the above described drain problem. Thanks. > Henry@... 1979 FC 35, McAllen, Tx You've got something seriously funky going on in there. Somebody's been eating at Taco Bell too much and it's formed a "clump" of yucko. I'd hit it with a high-pressure garden hose spray down the toilet, try and blast it out. Jim (no rig yet but SOON!) |
05-13-2005, 08:52
the tank is one level (two story outhouse?) and it has no baffles.sounds like
all the liquid ran out leaving you a paper mache pie in the bottom.you may have to run a hose up the drain outlet to balst it free,wear a raincoat and wear gloves!! then,lets figure out the valve not closing deal! randydupree93wb http://www.dupreeproducts.com ----- Original Message ----- From: Henry Claeys To: WanderlodgeForum@yahoogroups.com Sent: Friday, May 13, 2005 2:19 PM Subject: [WanderlodgeForum] How many floors/levels does my black tank have? 1) I suspect that my black tank has a problem because I discovered, after 3 weeks of use, that the drain valve was not closing completely. (2) What confuses me is, even after apparently emptying the black system, I still see water when I look down the hole through the commode. Why is there water in the tank below the commode even after emptying the black tank? I never used to notice the water until I discovered the above described drain problem. Thanks. Henry@... 1979 FC 35, McAllen, Tx ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-13-2005, 09:21
Paper Mache Pie...Randy you "crack" me up!! He probably has some
paper in the groove where the paddle goes..I am sure you will get it worked out. After all at the MB rally didnt I hear you humming "I just wanna be king" lol Scott 86FC35 SC --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > the tank is one level (two story outhouse?) and it has no baffles.sounds like all the liquid ran out leaving you a paper mache pie in the bottom.you may have to run a hose up the drain outlet to balst it free,wear a raincoat and wear gloves!! then,lets figure out the valve not closing deal! randydupree93wb http://www.dupreeproducts.com > ----- Original Message ----- > From: Henry Claeys > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, May 13, 2005 2:19 PM > Subject: [WanderlodgeForum] How many floors/levels does my black tank have? > > > 1) I suspect that my black tank has a problem because I discovered, > after 3 weeks of use, that the drain valve was not closing completely. > (2) What confuses me is, even after apparently emptying the black > system, I still see water when I look down the hole through the > commode. Why is there water in the tank below the commode even after > emptying the black tank? I never used to notice the water until I > discovered the above described drain problem. Thanks. > Henry@H... 1979 FC 35, McAllen, Tx > > > > -------------------------------------------------------------------- ---------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] |
