Air Conditioner Drain tubes
11-09-2007, 10:04
Until last Saturday I had only run the air conditioners in dry conditions. On
Saturday in Bakersfield it was humid, and when running the middle air conditioner it began to drain water inside the coach. I got up there today and removed the covers, and poured some water in the drains. It drained, but very slowly, and there was no sign of water anywhere on the ground around the coach. So, two questions: Where do the drains go (I got out a mirror and the only drains I can find are at the very front, presumably for the engine-driven air), and what tips for unclogging them? Don Bradner 90 PT40 "Blue Thunder" Eureka, CA |
11-09-2007, 12:40
Don, on my coach the drains are located as follows. The front a/c exits in the
left front wheel well in front of the tire. The center air tube exits in the center of the bus near the fuel tank. The rear air drips from the center of the fairings on the left rear wheels. All of the tubing is red nylon. I have had some periodic issues with the center drain. No leaks inside just running down the side of the bus and pissing me off. I use high pressure air and back blow the line. One of these days I will need to disassemble the a/c box and do it right. Don Bradner Until last Saturday I had only run the air conditioners in dry conditions. On Saturday in Bakersfield it was humid, and when running the middle air conditioner it began to drain water inside the coach. I got up there today and removed the covers, and poured some water in the drains. It drained, but very slowly, and there was no sign of water anywhere on the ground around the coach. So, two questions: Where do the drains go (I got out a mirror and the only drains I can find are at the very front, presumably for the engine-driven air), and what tips for unclogging them? Don Bradner 90 PT40 "Blue Thunder" Eureka, CA Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Dahlonega, GA __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
