Gen has stop making electricity
11-12-2007, 04:46
Scott, do you have the manual or automatic change over switch?
Ernie Ekberg 83PT40 Weatherford, Tx ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] |
11-12-2007, 08:25
My Kohler generator has stopped making juice. Engine part is fine.
Ideas to troubleshoot? Scott Forman 86 PT38 Memphis |
11-12-2007, 08:33
Scott,
You made sure that the breakers on the generator are not tripped? Al Johnson '96 BMC B75 ==> B100 Mandeville, Louisiana --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > My Kohler generator has stopped making juice. Engine part is fine. > Ideas to troubleshoot? > > Scott Forman > 86 PT38 > Memphis > |
11-12-2007, 09:43
Yes
--- In WanderlodgeForum@yahoogroups.com, "Al" > > Scott, > You made sure that the breakers on the generator are not tripped? > > Al Johnson > '96 BMC B75 ==> B100 > Mandeville, Louisiana > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > > > > My Kohler generator has stopped making juice. Engine part is fine. > > Ideas to troubleshoot? > > > > Scott Forman > > 86 PT38 > > Memphis > > > |
11-12-2007, 15:31
Manual
--- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Scott, do you have the manual or automatic change over switch? > > Ernie Ekberg > 83PT40 > Weatherford, Tx > > > > > ************************************** See what's new at http://www.aol.com > > > [Non-text portions of this message have been removed] > |
11-12-2007, 15:37
Scott, it is fairly easy to inspect the brushes and leads so have you
checked them to see if they are good? Dan 88pt38 Jackson, MS _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Scott Forman Sent: Monday, November 12, 2007 9:32 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Gen has stop making electricity Manual --- In WanderlodgeForum@ yahoogroups.com, erniecarpet@... wrote: > > Scott, do you have the manual or automatic change over switch? > > Ernie Ekberg > 83PT40 > Weatherford, Tx > > > > > ************************************** See what's new at http://www.aol. <http://www.aol.com> com > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
11-13-2007, 17:26
Yup. Check those brushes. If they're good, check the voltage regulator next.
-Ryan '86 PT-40 8V92 On 11/12/07, Dan Williams > > Scott, it is fairly easy to inspect the brushes and leads so have you > checked them to see if they are good? > > Dan > 88pt38 > Jackson, MS |
11-14-2007, 02:13
> > Yup. Check those brushes. If they're good, check the voltage regulator next. > > -Ryan > '86 PT-40 8V92 > > On 11/12/07, Dan Williams > > > > Scott, it is fairly easy to inspect the brushes and leads so have you > > checked them to see if they are good? > > > > Dan > > 88pt38 > > Jackson, MS > If it is a transformer regulated generator then check the taps on the transformer. Mine started making 80 volts instead of 120. After much searching i grabbed the wires and shook one loose from the sapde connector. Fixed that and was back in business at 120 volts. Bob Criss 90SP36 Bethel Park, PA |
11-14-2007, 11:32
It's down at the shop now, same guys who rebuilt the Kohler in my 82
FC (I knew it was bad when I bought the coach). I am sure they will find it, I just hope it isn't the same problem that killed the other one. Scott --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Yup. Check those brushes. If they're good, check the voltage regulator next. > > -Ryan > '86 PT-40 8V92 > > On 11/12/07, Dan Williams > > > > Scott, it is fairly easy to inspect the brushes and leads so have you > > checked them to see if they are good? > > > > Dan > > 88pt38 > > Jackson, MS > |
