Successful trips, was heater problem
11-12-2007, 09:53
I agree. We just finished 60 days/4100 miles through Oregon, a bit of
Washington, Idaho, Utah, Wyoming, Colorado, New Mexico, Arizona and California. Lots of steep grades up and down, heat above 100, cold below freezing, and mechanically rather uneventful. I think it is rare to have zero annoyances, and we had a couple such as the clogged A/C drain, but I don't think I ever went that far in my (purchased new) SOB without at least a similar or greater number of annoyances. It is the basic nature of support forums to get calls for support, and not generally get "Everything's fine" messages. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA On 11/12/2007 at 9:28 PM mbulriss wrote: >> We just completed a 3000 mile trip in our bus and nothing broke or >> went wrong the whole way. It was such an awsome trip. > >To all of the newbies and wannabes out there that we hear from that >are frightened off by all the posts about problems, *this* is the >normal type of trip report that you don't usually hear about. Since >these forums are mainly about help on problems, you usually hear only >the bad stuff because something broke. This report from Robert is >actually the normal result of good maintenance practices. > >FWIW. Thanks for posting this Robert. > >Mike Bulriss >1991 WB40 "Texas Minivan" >San Antonio, TX > > >--- In WanderlodgeForum@yahoogroups.com, "Robert & Teri Rahn" > >> >> We just completed a 3000 mile trip in our bus and nothing broke or went >> wrong the whole way. |
11-12-2007, 10:28
Don, most SOB don't even know what a A/C drain is! They just run down
the roof. Marty Gregg 95 BMC 37' Kennewick WA. |
11-12-2007, 10:44
That was the case on mine, so obviously I didn't have the same small annoyances,
but other ones instead. It is getting hard to remember specifics, but after each long trip (we did 63,000 miles in 3-1/2 years in the last one) I always had a list of varying length, with things that had stopped working the right way and needed some fixit. I don't expect to bounce a house down the road for thousands of miles without having to fix something. On 11/12/2007 at 10:28 PM martingregg598 wrote: >Don, most SOB don't even know what a A/C drain is! They just run down >the roof. >Marty Gregg >95 BMC 37' >Kennewick WA. |
11-12-2007, 10:59
what does "SOB" stand for? (other than one obvious option that
doesn't seem to apply ) ?On 11/12/07, Don Bradner > That was the case on mine, so obviously I didn't have the same small > annoyances, but other ones instead. It is getting hard to remember > specifics, but after each long trip (we did 63,000 miles in 3-1/2 years in > the last one) I always had a list of varying length, with things that had > stopped working the right way and needed some fixit. > > I don't expect to bounce a house down the road for thousands of miles > without having to fix something. > > On 11/12/2007 at 10:28 PM martingregg598 wrote: > > >Don, most SOB don't even know what a A/C drain is! They just run down > >the roof. > >Marty Gregg > >95 BMC 37' > >Kennewick WA. > > > |
11-12-2007, 11:18
"Some Other Brand" - non-Wanderlodge
Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Dorn Hetzel" wrote: > > what does "SOB" stand for? (other than one obvious option that > doesn't seem to apply ) ?> > On 11/12/07, Don Bradner > > That was the case on mine, so obviously I didn't have the same small > > annoyances, but other ones instead. It is getting hard to remember > > specifics, but after each long trip (we did 63,000 miles in 3-1/2 years in > > the last one) I always had a list of varying length, with things that had > > stopped working the right way and needed some fixit. > > > > I don't expect to bounce a house down the road for thousands of miles > > without having to fix something. > > > > On 11/12/2007 at 10:28 PM martingregg598 wrote: > > > > >Don, most SOB don't even know what a A/C drain is! They just run down > > >the roof. > > >Marty Gregg > > >95 BMC 37' > > >Kennewick WA. > > > > > > > |
11-12-2007, 11:21
Dorn, this forum uses SOB as "Some Other Brand", meaning anything except a
'Bird'. Gary SOB ----- Original Message ----- From: "Dorn Hetzel" To: Sent: Monday, November 12, 2007 5:59 PM Subject: Re: [WanderlodgeForum] Re: Successful trips, was heater problem > what does "SOB" stand for? (other than one obvious option that > doesn't seem to apply ) ?> > On 11/12/07, Don Bradner >> That was the case on mine, so obviously I didn't have the same small >> annoyances, but other ones instead. It is getting hard to remember >> specifics, but after each long trip (we did 63,000 miles in 3-1/2 years >> in >> the last one) I always had a list of varying length, with things that had >> stopped working the right way and needed some fixit. >> >> I don't expect to bounce a house down the road for thousands of miles >> without having to fix something. >> >> On 11/12/2007 at 10:28 PM martingregg598 wrote: >> >> >Don, most SOB don't even know what a A/C drain is! They just run down >> >the roof. >> >Marty Gregg >> >95 BMC 37' >> >Kennewick WA. >> >> >> > > ---------------------------------------------------- > This message has been processed by Firetrust Benign. |
11-12-2007, 13:02
SOB is always applicable. lol It's up to you to make that call.
mbulriss <mbulriss@...> wrote: "Some Other Brand" - non-Wanderlodge Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Dorn Hetzel" wrote: > > what does "SOB" stand for? (other than one obvious option that > doesn't seem to apply ) ?> > On 11/12/07, Don Bradner > > That was the case on mine, so obviously I didn't have the same small > > annoyances, but other ones instead. It is getting hard to remember > > specifics, but after each long trip (we did 63,000 miles in 3-1/2 years in > > the last one) I always had a list of varying length, with things that had > > stopped working the right way and needed some fixit. > > > > I don't expect to bounce a house down the road for thousands of miles > > without having to fix something. > > > > On 11/12/2007 at 10:28 PM martingregg598 wrote: > > > > >Don, most SOB don't even know what a A/C drain is! They just run down > > >the roof. > > >Marty Gregg > > >95 BMC 37' > > >Kennewick WA. > > > > > > > Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Dahlonega, GA --------------------------------- Never miss a thing. Make Yahoo your homepage. [Non-text portions of this message have been removed] |
11-12-2007, 23:51
![]() On Nov 12, 2007 8:02 PM, Leroy Eckert > SOB is always applicable. lol It's up to you to make that call. > > mbulriss <mbulriss@... <mbulriss%40yahoo.com>> wrote: "Some Other > Brand" - non-Wanderlodge > > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > --- In WanderlodgeForum@yahoogroups.com > "Dorn Hetzel" > wrote: > > > > what does "SOB" stand for? (other than one obvious option that > > doesn't seem to apply ) ?> > > > On 11/12/07, Don Bradner > > > That was the case on mine, so obviously I didn't have the same small > > > annoyances, but other ones instead. It is getting hard to remember > > > specifics, but after each long trip (we did 63,000 miles in 3-1/2 > years in > > > the last one) I always had a list of varying length, with things > that had > > > stopped working the right way and needed some fixit. > > > > > > I don't expect to bounce a house down the road for thousands of miles > > > without having to fix something. > > > > > > On 11/12/2007 at 10:28 PM martingregg598 wrote: > > > > > > >Don, most SOB don't even know what a A/C drain is! They just run down > > > >the roof. > > > >Marty Gregg > > > >95 BMC 37' > > > >Kennewick WA. > > > > > > > > > > > > > > > > > Leroy Eckert > 1990 WB-40 "Smoke N Mirrors" > Dahlonega, GA > > --------------------------------- > Never miss a thing. Make Yahoo your homepage. > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed] |
