How many floors / levels does my black tank have?
05-13-2005, 15:09
Jim. Thanks for your reply. I don't have a high pressure device. What
brand/type do you recommend and where can I buy one? Henry@... 1979 FC 35, McAllen, Tx Date: Fri, 13 May 2005 11:26:21 -0700 From: Jim March Subject: Re: How many floors/levels does my black tank have? Henry Claeys wrote: >> 1) I suspect that my black tank has a problem because I discovered, >> after 3 weeks of use, that the drain valve was not closing completely. >> (2) What confuses me is, even after apparently emptying the black >> system, I still see water when I look down the hole through the >> commode. Why is there water in the tank below the commode even after >> emptying the black tank? I never used to notice the water until I >> discovered the above described drain problem. Thanks. >> Henry@... 1979 FC 35, McAllen, Tx > > You've got something seriously funky going on in there. Somebody's been eating at Taco Bell too much and it's formed a "clump" of yucko. I'd hit it with a high-pressure garden hose spray down the toilet, try and blast it out. Jim (no rig yet but SOON!) |
05-13-2005, 15:16
Henry do yourself a favor and do this. Put a 1/2 cup of detergent in your
black water tank with about 15 gallons or so of water.. Add a couple of big bags of ice cubes and take a 1/2 drive and then fill the tank and dump. Clean tank tom 1982 FC35 Vernon Center,NY At 10:09 PM 5/13/2005 -0500, you wrote: >Jim. Thanks for your reply. I don't have a high pressure device. What >brand/type do you recommend and where can I buy >one? Henry@... 1979 FC 35, McAllen, Tx > >Date: Fri, 13 May 2005 11:26:21 -0700 > From: Jim March >Subject: Re: How many floors/levels does my black tank have? > >Henry Claeys wrote: > > > >> 1) I suspect that my black tank has a problem because I discovered, > >> after 3 weeks of use, that the drain valve was not closing completely. > >> (2) What confuses me is, even after apparently emptying the black > >> system, I still see water when I look down the hole through the > >> commode. Why is there water in the tank below the commode even after > >> emptying the black tank? I never used to notice the water until I > >> discovered the above described drain problem. Thanks. > >> Henry@... 1979 FC 35, McAllen, Tx > > > > > > >You've got something seriously funky going on in there. Somebody's been >eating at Taco Bell too much and it's formed a "clump" of yucko. > >I'd hit it with a high-pressure garden hose spray down the toilet, try >and blast it out. > >Jim >(no rig yet but SOON!) > > > > >---------- >Yahoo! Groups Links > * To visit your group on the web, go to: > * > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/W\ anderlodgeForum/ > > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. |
05-13-2005, 23:48
i forgot to mention that i've used the cheapo (less than $100) power washers
from home depot,they work fine..randydupree93wb ----- Original Message ----- From: Henry Claeys To: WanderlodgeForum@yahoogroups.com Sent: Friday, May 13, 2005 11:09 PM Subject: [WanderlodgeForum] How many floors / levels does my black tank have? Jim. Thanks for your reply. I don't have a high pressure device. What brand/type do you recommend and where can I buy one? Henry@... 1979 FC 35, McAllen, Tx Date: Fri, 13 May 2005 11:26:21 -0700 From: Jim March Subject: Re: How many floors/levels does my black tank have? Henry Claeys wrote: >> 1) I suspect that my black tank has a problem because I discovered, >> after 3 weeks of use, that the drain valve was not closing completely. >> (2) What confuses me is, even after apparently emptying the black >> system, I still see water when I look down the hole through the >> commode. Why is there water in the tank below the commode even after >> emptying the black tank? I never used to notice the water until I >> discovered the above described drain problem. Thanks. >> Henry@... 1979 FC 35, McAllen, Tx > > You've got something seriously funky going on in there. Somebody's been eating at Taco Bell too much and it's formed a "clump" of yucko. I'd hit it with a high-pressure garden hose spray down the toilet, try and blast it out. Jim (no rig yet but SOON!) ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-14-2005, 12:53
Tom. Your idea sounds great provided the valve will close enough to hold 15 or
so gallons. I thought the valve was an all or nothing type thing meaning that it either works, or it doesn't, but to my surprise it seems to hold some water. Can you explain why/how it could behave that way and what to do to fix? Thanks for your advice. Henry@... 1979 FC/SB 35, McAllen, Tx Date: Fri, 13 May 2005 23:16:13 -0400 From: Tom Warner Subject: Re: How many floors / levels does my black tank have? Henry do yourself a favor and do this. Put a 1/2 cup of detergent in your black water tank with about 15 gallons or so of water.. Add a couple of big bags of ice cubes and take a 1/2 drive and then fill the tank and dump. Clean tank tom 1982 FC35 Vernon Center,NY |
05-14-2005, 13:27
Henry you probably have the Dupree manual valve on your black water tank.
if its not filled yet, take the two screws out of the housing just below the handle and remove the guts. Lube it up good with silicon grease and put it back together. Tom 1982 FC35 Vernon Center,NY At 07:53 PM 5/14/2005 -0500, you wrote: >Tom. Your idea sounds great provided the valve will close enough to hold >15 or so gallons. I thought the valve was an all or nothing type thing >meaning that it either works, or it doesn't, but to my surprise it seems >to hold some water. Can you explain why/how it could behave that way and >what to do to fix? Thanks for your advice. Henry@... 1979 >FC/SB 35, McAllen, Tx > >Date: Fri, 13 May 2005 23:16:13 -0400 > From: Tom Warner >Subject: Re: How many floors / levels does my black tank have? > >Henry do yourself a favor and do this. Put a 1/2 cup of detergent in your >black water tank with about 15 gallons or so of water.. Add a couple of big >bags of ice cubes and take a 1/2 drive and then fill the tank and >dump. Clean tank > >tom >1982 FC35 >Vernon Center,NY |
05-14-2005, 14:02
silicon spray works best...randydupree93wb
----- Original Message ----- From: Tom Warner To: WanderlodgeForum@yahoogroups.com Sent: Saturday, May 14, 2005 9:27 PM Subject: Re: [WanderlodgeForum] How many floors / Levels does my black tank have? Henry you probably have the Dupree manual valve on your black water tank. if its not filled yet, take the two screws out of the housing just below the handle and remove the guts. Lube it up good with silicon grease and put it back together. Tom 1982 FC35 Vernon Center,NY At 07:53 PM 5/14/2005 -0500, you wrote: >Tom. Your idea sounds great provided the valve will close enough to hold >15 or so gallons. I thought the valve was an all or nothing type thing >meaning that it either works, or it doesn't, but to my surprise it seems >to hold some water. Can you explain why/how it could behave that way and >what to do to fix? Thanks for your advice. Henry@... 1979 >FC/SB 35, McAllen, Tx > >Date: Fri, 13 May 2005 23:16:13 -0400 > From: Tom Warner >Subject: Re: How many floors / levels does my black tank have? > >Henry do yourself a favor and do this. Put a 1/2 cup of detergent in your >black water tank with about 15 gallons or so of water.. Add a couple of big >bags of ice cubes and take a 1/2 drive and then fill the tank and >dump. Clean tank > >tom >1982 FC35 >Vernon Center,NY ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
