Question on dash gage-Fuel gage-
11-15-2007, 17:24
On my 78 Wanderlodge gage board there is only one fuel gage that is
suppose to read both the about of diesel I have on board and also the amount of gasoline (For Generator). I was told when I bought my coach that the micro switch that shows how much fuel is in each tank works by flipping it up or down and it would show how much fuel was in each tank. And the same gage on the dash will show how much fuel is in each tank by operating that single switch. Ok so far so good. But the past owner stated to me that the gage itself worked backward for the gas fuel tank. By this I mean when the gas tank is full it would read empty on the gage and when that tank was empty it would show full. When the selector switch is put in the position to show the amount of diesel it works just like any other gage. Does anyone here have that same set up on there older coaches? Only ones with a gas generator. Jipjob 78 Wanderlodge |
11-15-2007, 19:43
wrong fuel sender in the gas tank
Stephen 77fc35 same set up both both read correctly --- In WanderlodgeForum@yahoogroups.com, "Jon" > > On my 78 Wanderlodge gage board there is only one fuel gage that is > suppose to read both the about of diesel I have on board and also the > amount of gasoline (For Generator). I was told when I bought my > coach that the micro switch that shows how much fuel is in each tank > works by flipping it up or down and it would show how much fuel was > in each tank. And the same gage on the dash will show how much fuel > is in each tank by operating that single switch. > > Ok so far so good. But the past owner stated to me that the gage > itself worked backward for the gas fuel tank. By this I mean when > the gas tank is full it would read empty on the gage and when that > tank was empty it would show full. > > When the selector switch is put in the position to show the amount of > diesel it works just like any other gage. > > Does anyone here have that same set up on there older coaches? Only > ones with a gas generator. > > Jipjob > 78 Wanderlodge > |
