Simple Question: Where is the cut oft vlv for the auxiliary air supply?
11-16-2007, 11:33
Could someone tell me where the cut oft vlv is located at for the air
supply quick disconnect that's located in the stowage compartment for the sewer hoses. And one more question as I noticed today while having fun under my coach. There are two air tanks that sit next to each other, why are there two? Thanks Jipjob 78 Wanderlodge |
11-16-2007, 11:54
Hi J:
There is not a shut off valve for the out put air line. Actually you have 3 air tanks under your coach, 2 in front one on the curb side and one on the drivers side. The 3 rd one is located back by the rear axle and is mounted curb to drivers. The tank on the front curb side is the wet tank, the one on the front drivers side is the rear break tank and the one in the rear over the drive axle is the front air break tank. The compressor fills the wet tank and the wet tank fills the other 2 tanks with a check valve in line so the air can not return to the wet tank. Every thing air except the breaks, work off of the wet tank. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma At 11:33 PM 11/16/2007 +0000, you wrote: >Could someone tell me where the cut oft vlv is located at for the air >supply quick disconnect that's located in the stowage compartment for >the sewer hoses. > >And one more question as I noticed today while having fun under my >coach. There are two air tanks that sit next to each other, why are >there two? Thanks > >Jipjob >78 Wanderlodge > > |
11-16-2007, 12:27
> > Hi J: > > There is not a shut off valve for the out put air line. > > Actually you have 3 air tanks under your coach, 2 in front one on the curb > side and one on the drivers side. The 3 rd one is located back by the rear > axle and is mounted curb to drivers. > The tank on the front curb side is the wet tank, the one on the front > drivers side is the rear break tank and the one in the rear over the drive > axle is the front air break tank. > > The compressor fills the wet tank and the wet tank fills the other 2 tanks > with a check valve in line so the air can not return to the wet tank. Every > thing air except the breaks, work off of the wet tank. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Duncan, Oklahoma > > At 11:33 PM 11/16/2007 +0000, you wrote: > >Could someone tell me where the cut oft vlv is located at for the air > >supply quick disconnect that's located in the stowage compartment for > >the sewer hoses. > > > >And one more question as I noticed today while having fun under my > >coach. There are two air tanks that sit next to each other, why are > >there two? Thanks > > > >Jipjob > >78 Wanderlodge I guess maybe the new connections hoses are not the right size for the quick disconnect vlv located in the hose tray area as I'm not getting any air out of the hose. I thought maybe there would be a vlv someplace to secure this quick disconnect fitting but maybe I was wrong. Jipjob > > > > > |
11-16-2007, 12:31
> > Hi J: > > There is not a shut off valve for the out put air line. > > Actually you have 3 air tanks under your coach, 2 in front one on the curb > side and one on the drivers side. The 3 rd one is located back by the rear > axle and is mounted curb to drivers. > The tank on the front curb side is the wet tank, the one on the front > drivers side is the rear break tank and the one in the rear over the drive > axle is the front air break tank. > > The compressor fills the wet tank and the wet tank fills the other 2 tanks > with a check valve in line so the air can not return to the wet tank. Every > thing air except the breaks, work off of the wet tank. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Duncan, Oklahoma > > At 11:33 PM 11/16/2007 +0000, you wrote: > >Could someone tell me where the cut oft vlv is located at for the air > >supply quick disconnect that's located in the stowage compartment for > >the sewer hoses. > > > >And one more question as I noticed today while having fun under my > >coach. There are two air tanks that sit next to each other, why are > >there two? Thanks > > > >Jipjob > >78 Wanderlodge Forgot to ask? Where would that air line be that supplys air to the outpput air? Would that be on the wet tank or one of the other two tanks? Thanks Jipjob 78 Wanderlodge > |
11-16-2007, 12:41
>It comes from the wet tank to that disconect. You can change the
>disconnect out but there are still nipple ends for the old ones. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma >Forgot to ask? Where would that air line be that supplys air to the >outpput air? Would that be on the wet tank or one of the other two >tanks? Thanks >Jipjob >78 Wanderlodge > > > > |
11-16-2007, 13:14
> > > >It comes from the wet tank to that disconect. You can change the > >disconnect out but there are still nipple ends for the old ones. > > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Duncan, Oklahoma > > > > > >Forgot to ask? Where would that air line be that supplys air to the > >outpput air? Would that be on the wet tank or one of the other two > >tanks? Thanks > >Jipjob > >78 Wanderlodge > > > > > > > > Thanks I thought the new hose fitting was a bit small and will look to replace the old conection with a new one. Jon Jon Rebel Bird |
