Fuel Additives
11-19-2007, 07:24
Fuel Additives
I've owned diesel vehicles but never a BIG ONE. I never worried about
the fuel in the cars and trucks because I always drove them regularly throughout the winter. With this BB it will be sitting most of the winter although I do intend to get the bus out at least every couple weeks and drive it until warmed up to circulate the fluids and exercise her a little. Now with that considered what needs to be done relative to the diesel fuel. I certainly will not be used large amounts of diesel over the next couple months. Should I add an additive and what would be best? I assume its best to keep the tank full as well. John Heckman central Pa 1973 FC Diesel |
11-19-2007, 11:21
Fuel Additives
John,
You are correct in keeping the fuel tank full. It keeps condensation from forming inside the tank. I use Stanadyne Fuel Additive on the advise of the owner of a local fuel injector repair shop that I had dealt with for years before retiring. I am sure their are other good additives on the market. I read once where a fellow had designed a secondary fuel filter system. He could filter his fuel while the coach was in storage without running the engine. Howard Truitt Sowega Camilla, Ga. 86 PT40 ----- Original Message ----- From: bubblerboy64 To: WanderlodgeForum@yahoogroups.com Sent: Monday, November 19, 2007 2:24 PM Subject: [WanderlodgeForum] Fuel Additives I've owned diesel vehicles but never a BIG ONE. I never worried about the fuel in the cars and trucks because I always drove them regularly throughout the winter. With this BB it will be sitting most of the winter although I do intend to get the bus out at least every couple weeks and drive it until warmed up to circulate the fluids and exercise her a little. Now with that considered what needs to be done relative to the diesel fuel. I certainly will not be used large amounts of diesel over the next couple months. Should I add an additive and what would be best? I assume its best to keep the tank full as well. John Heckman central Pa 1973 FC Diesel ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.5.486 / Virus Database: 269.15.34/1134 - Release Date: 11/16/2007 9:52 AM [Non-text portions of this message have been removed] |
10-27-2009, 09:29
Fuel Additives
10-27-2009, 11:42
Fuel Additives
10-27-2009, 11:48
Fuel Additives
10-27-2009, 13:28
Fuel Additives
Ken, I also use Lucas Fuel Injector Additive in my Bird (6V92) & my Ford Powerstroke (7.3). Much smoother running engines & always easy to start, except at -30 or so.... I have also used the Power Service products but I like the Lucas much better. It seems to clean the injectors better. Terry Neal Bozeman, MT 82PT40 73FC34 KP Marsh wrote:
