PT-42 Front Heaters
11-21-2007, 12:51
PT-42 Front Heaters
'95 PT-42 Front Heater Question
1 - Ok I have dash heat and air like in any car or truck. But I also have three vents on the bottom of the front consol, near the step well. I thought that the thermostat that controls the front air would operate one these vents, like the two thermostats in the kitchen and bedroom, they operate the hydronic heat and A/C in those areas, but it doesn't. The dash A/C â Heater operates the two floor vents over the step well. But the third larger vent, more or less amid ship, doesn't seem to do anything. I got my hand up in there behind it, though the CB compartment and I couldn't feel any heater core of any kind, or much of anything else for that matter. It might be like the vents over the step well the heat just dumps into the consol area and kind of pushes its way through the vents. Any help would be great! I was told when I bought the coach that there is no heat up front when the coach is in camper mode, only when the engine is running. If anyone is curious there is a heater just under the sofa up front near the drivers chair and it does a great job. I would just like one near the door to offset heat loss when the family is going in and out 50 times a day. 2 - Also the temperature control slider on the dash is very difficult to operate. I'm afraid that I will break it; it takes that much force to slide left or right. I know the cable and hinges need to be lubed, but I'm not sure what to use for lube. WD-40 need not respond;} |
11-21-2007, 18:40
PT-42 Front Heaters
I believe the one you are talking about at mid-ship, which would be
at floor level below the draws is the electric heater. This is controlled by the thermostat that is mounted near the kitchen on most coaches. This is a standard analog type thermostat, on my 92 it is mount right at the edge of the kitchen counter above the couch. If you place the left most switch on heat, and set the temp with the upper dial it should turn on this heater. The catch is that the front AC switch on the dash to the left of the steering wheel that conrols all the coach AC's (there are total of three switches front, mid, rear) the front AC must be in the on position as it controls the electric relay to that heater. Which temp controls in the dash are you talking about, the overhead dash (Chassis AC), or the lower left dash where the chassis heat is located? Michael Brundridge 1992 WB40 Georgetown, TX --- In WanderlodgeForum@yahoogroups.com, "bumpersbird" > > '95 PT-42 Front Heater Question > > 1 - Ok I have dash heat and air like in any car or truck. But I also > have three vents on the bottom of the front consol, near the step > well. I thought that the thermostat that controls the front air would > operate one these vents, like the two thermostats in the kitchen and > bedroom, they operate the hydronic heat and A/C in those areas, but > it doesn't. The dash A/C â Heater operates the two floor vents over > the step well. But the third larger vent, more or less amid ship, > doesn't seem to do anything. I got my hand up in there behind it, > though the CB compartment and I couldn't feel any heater core of any > kind, or much of anything else for that matter. It might be like the > vents over the step well the heat just dumps into the consol area and > kind of pushes its way through the vents. Any help would be great! I > was told when I bought the coach that there is no heat up front when > the coach is in camper mode, only when the engine is running. If > anyone is curious there is a heater just under the sofa up front near > the drivers chair and it does a great job. I would just like one near > the door to offset heat loss when the family is going in and out 50 > times a day. > > 2 - Also the temperature control slider on the dash is very difficult > to operate. I'm afraid that I will break it; it takes that much force > to slide left or right. I know the cable and hinges need to be lubed, > but I'm not sure what to use for lube. WD-40 need not respond;} > |
11-22-2007, 03:35
PT-42 Front Heaters
1. Front thermostat (above driver's head) only controls the AC. When
set to 'gas heat' it doesnt' do anything. I have the vents you describe, and nothing I've tried causes them to do anything. I, too, can not find (feel) any heater core or other heating element behind them. My supposition is that the vents are to allow air circulation to the components behind the dash -- nothing more. (Indeed, it would be great to have a little heat in that area while parked... but it doesn't seem to be the case. I suppose you could turn on the 'engine preheat' switch (board above driver's head) which turns on a pump from the AquaHot to heat the engine so then you'd get some heat through the chassis system -- but I expect that would be subject to a _lot_ of waste and neither be economical or effective.) The AquaHot heater core under the sofa is very effective. It's controlled by the center thermostat. (Dash AC switch on, power switch on thermostat on, second switch on thermostat to 'gas heat' and set temperature according to your desire.) This same thermostat also controls the AH heater core located under the galley cabinet. A square Robert Shaw thermostat next to the Dometic thermostat controls the electric Perfectoe heater under the galley. The AquaHot system in the '95 is set up with 3 heating loops. One to the bedroom, another to the bathroom, and the third to the forward area with the heater cores under the sofa and galley cabinets. One of these loops (I'm not sure which one) also 'feeds' the basement heat system that has cores located in strategic places (such as one aimed right at the domestic water pump) and is controlled by a 'low temperature' thermostat on the front basement bulkhead on the curb side. It allows settings as low as 40. I've used it in temperatures down to 15 degrees and it seems to work as I haven't had any freezing problems in the basement. All of the AquaHot heater cores have small "pancake" 12 v fans to move air through the heater core. One service check is to turn on the heat and check to see that the fans are working. (In my coach, the fans under the kitchen cabinets are a trifle noisy, but they move a goodly amount of air. The other fans have modest noise when operating, but aren't too intrusive.) 2. My control lever requires moderate effort -- and the passage from left to right (or right to left) has 'sticky' spots. I'd guess a spray silicone lubricant if you can reach any of the cable or other components. I haven't tried to get to them, yet. (see next) I'm sad to report that I do have one problem with the chassis system. There's a "door" deep in side that's supposed to move when the AC goes on ... unfortunately, it's not moving when it's supposed to. The most noticeable symptom is that the amount of air coming from the 'eyeball' vent isn't very significant. The door was working when I first got the coach, but quit sometime last year. If anybody had any ideas on how to get to the internal workings of the vent system, I'd appreciate any suggestions. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Lockhart Texas On Nov 21, 2007, at 6:51 PM, bumpersbird wrote: > '95 PT-42 Front Heater Question > > 1 - Ok I have dash heat and air like in any car or truck. But I also > have three vents on the bottom of the front consol, near the step > well. I thought that the thermostat that controls the front air would > operate one these vents, like the two thermostats in the kitchen and > bedroom, they operate the hydronic heat and A/C in those areas, but > it doesn't. The dash A/C â Heater operates the two floor vents over > the step well. But the third larger vent, more or less amid ship, > doesn't seem to do anything. I got my hand up in there behind it, > though the CB compartment and I couldn't feel any heater core of any > kind, or much of anything else for that matter. It might be like the > vents over the step well the heat just dumps into the consol area and > kind of pushes its way through the vents. Any help would be great! I > was told when I bought the coach that there is no heat up front when > the coach is in camper mode, only when the engine is running. If > anyone is curious there is a heater just under the sofa up front near > the drivers chair and it does a great job. I would just like one near > the door to offset heat loss when the family is going in and out 50 > times a day. > > 2 - Also the temperature control slider on the dash is very difficult > to operate. I'm afraid that I will break it; it takes that much force > to slide left or right. I know the cable and hinges need to be lubed, > but I'm not sure what to use for lube. WD-40 need not respond;} > |
11-22-2007, 05:03
PT-42 Front Heaters
Pete,
If you turn on the floor heat from the dash controls while the engine is running you should get some heat from the two vent over the step well. You can access the two vents over the step well by pulling the left side of the door where the A/C vents and the group of four switchs are mounted , there are two latchs one the left side and two hinges on the right just jiggle it firmly from the left side and it will open, be gentle mine only open four or five inches The heat is blow down from a manifold towards the two vents it is not connected buy any duct work. I would guess it helps to heat the whole consol and your passenger toes. The mid ship vent might be air intake although I don't know if thats true or if like you said just air for the interior of the consol. Everything else you described is the same on my coach. I'll get after the sticky controls in the nevt few days and I'll let you know what I come up with. Kurt Horvath 95 PT-42 10AC Ready to over eat Happy Thankgiving ----- Original Message ---- From: Pete Masterson To: WanderlodgeForum@yahoogroups.com Sent: Thursday, November 22, 2007 9:35:49 AM Subject: Re: [WanderlodgeForum] PT-42 Front Heaters 1. Front thermostat (above driver's head) only controls the AC. When set to 'gas heat' it doesnt' do anything. I have the vents you describe, and nothing I've tried causes them to do anything. I, too, can not find (feel) any heater core or other heating element behind them. My supposition is that the vents are to allow air circulation to the components behind the dash -- nothing more. (Indeed, it would be great to have a little heat in that area while parked... but it doesn't seem to be the case. I suppose you could turn on the 'engine preheat' switch (board above driver's head) which turns on a pump from the AquaHot to heat the engine so then you'd get some heat through the chassis system -- but I expect that would be subject to a _lot_ of waste and neither be economical or effective.) The AquaHot heater core under the sofa is very effective. It's controlled by the center thermostat. (Dash AC switch on, power switch on thermostat on, second switch on thermostat to 'gas heat' and set temperature according to your desire.) This same thermostat also controls the AH heater core located under the galley cabinet. A square Robert Shaw thermostat next to the Dometic thermostat controls the electric Perfectoe heater under the galley. The AquaHot system in the '95 is set up with 3 heating loops. One to the bedroom, another to the bathroom, and the third to the forward area with the heater cores under the sofa and galley cabinets. One of these loops (I'm not sure which one) also 'feeds' the basement heat system that has cores located in strategic places (such as one aimed right at the domestic water pump) and is controlled by a 'low temperature' thermostat on the front basement bulkhead on the curb side. It allows settings as low as 40. I've used it in temperatures down to 15 degrees and it seems to work as I haven't had any freezing problems in the basement. All of the AquaHot heater cores have small "pancake" 12 v fans to move air through the heater core. One service check is to turn on the heat and check to see that the fans are working. (In my coach, the fans under the kitchen cabinets are a trifle noisy, but they move a goodly amount of air. The other fans have modest noise when operating, but aren't too intrusive.) 2. My control lever requires moderate effort -- and the passage from left to right (or right to left) has 'sticky' spots. I'd guess a spray silicone lubricant if you can reach any of the cable or other components. I haven't tried to get to them, yet. (see next) I'm sad to report that I do have one problem with the chassis system. There's a "door" deep in side that's supposed to move when the AC goes on ... unfortunately, it's not moving when it's supposed to. The most noticeable symptom is that the amount of air coming from the 'eyeball' vent isn't very significant. The door was working when I first got the coach, but quit sometime last year. If anybody had any ideas on how to get to the internal workings of the vent system, I'd appreciate any suggestions. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Lockhart Texas On Nov 21, 2007, at 6:51 PM, bumpersbird wrote: > '95 PT-42 Front Heater Question > > 1 - Ok I have dash heat and air like in any car or truck. But I also > have three vents on the bottom of the front consol, near the step > well. I thought that the thermostat that controls the front air would > operate one these vents, like the two thermostats in the kitchen and > bedroom, they operate the hydronic heat and A/C in those areas, but > it doesn't. The dash A/C â Heater operates the two floor vents over > the step well. But the third larger vent, more or less amid ship, > doesn't seem to do anything. I got my hand up in there behind it, > though the CB compartment and I couldn't feel any heater core of any > kind, or much of anything else for that matter. It might be like the > vents over the step well the heat just dumps into the consol area and > kind of pushes its way through the vents. Any help would be great! I > was told when I bought the coach that there is no heat up front when > the coach is in camper mode, only when the engine is running. If > anyone is curious there is a heater just under the sofa up front near > the drivers chair and it does a great job. I would just like one near > the door to offset heat loss when the family is going in and out 50 > times a day. > > 2 - Also the temperature control slider on the dash is very difficult > to operate. I'm afraid that I will break it; it takes that much force > to slide left or right. I know the cable and hinges need to be lubed, > but I'm not sure what to use for lube. WD-40 need not respond;} > Yahoo! Groups Links ________________________________________________________________________________\ ____ Be a better pen pal. Text or chat with friends inside Yahoo! Mail. See how. http://overview.mail.yahoo.com/ [Non-text portions of this message have been removed] |
11-22-2007, 05:42
PT-42 Front Heaters
The larger vent up front should be controoled by you AquaHot Gas
heating control near the middle of the coach. If you do not get heat there, your circulation fan must be out. My slider for the dash temparature control is also tight. Let me know if you find a way to make it easier. Tom McCarthy 95 PT42 Poway CA --- In WanderlodgeForum@yahoogroups.com, "bumpersbird" > > '95 PT-42 Front Heater Question > > 1 - Ok I have dash heat and air like in any car or truck. But I also > have three vents on the bottom of the front consol, near the step > well. I thought that the thermostat that controls the front air would > operate one these vents, like the two thermostats in the kitchen and > bedroom, they operate the hydronic heat and A/C in those areas, but > it doesn't. The dash A/C â Heater operates the two floor vents over > the step well. But the third larger vent, more or less amid ship, > doesn't seem to do anything. I got my hand up in there behind it, > though the CB compartment and I couldn't feel any heater core of any > kind, or much of anything else for that matter. It might be like the > vents over the step well the heat just dumps into the consol area and > kind of pushes its way through the vents. Any help would be great! I > was told when I bought the coach that there is no heat up front when > the coach is in camper mode, only when the engine is running. If > anyone is curious there is a heater just under the sofa up front near > the drivers chair and it does a great job. I would just like one near > the door to offset heat loss when the family is going in and out 50 > times a day. > > 2 - Also the temperature control slider on the dash is very difficult > to operate. I'm afraid that I will break it; it takes that much force > to slide left or right. I know the cable and hinges need to be lubed, > but I'm not sure what to use for lube. WD-40 need not respond;} > |
11-22-2007, 06:32
PT-42 Front Heaters
On Nov 22, 2007, at 11:03 AM, Kurt Horvath wrote:
> Pete, > > If you turn on the floor heat from the dash controls while the > engine is running you should get some heat from the two vent over > the step well. That's correct--heat from the "AC" adjustable vents. But you get nothing from the "vents" along the floor. > You can access the two vents over the step well by pulling the left > side of the door where the A/C vents and the group of four switchs > are mounted , there are two latchs one the left side and two hinges > on the right just jiggle it firmly from the left side and it will > open, be gentle mine only open four or five inches The heat is > blow down from a manifold towards the two vents it is not connected > buy any duct work. I would guess it helps to heat the whole consol > and your passenger toes. The mid ship vent might be air intake > although I don't know if thats true or if like you said just air > for the interior of the consol. Everything else you described is > the same on my coach. I'll get after the sticky controls in the > nevt few days and I'll let you know what I come up with. > > Kurt Horvath > 95 PT-42 > 10AC Ready to over eat > Happy Thankgiving > I'll have to explore the inside of the dash area further. I thought the vents were connected with some flexible tubing. At least, those around the driver's area are... It would seem like the ones on the passenger (stair well) side would be hooked up as well -- at least we get a fairly strong flow of air from them when the heat is on. The (outside) front of the coach has two little 'grills' next to the fog/driving lights. The curb side is a "fake" as the thing behind it isn't hooked up. The street side unit is attached to a tube that disappears up into the front of the coach somewhere. I presume that this is the fresh air intake for the chassis heat/AC system. (I don't get much flow when the vent is open unless the fan is on.) Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at |
11-22-2007, 11:49
PT-42 Front Heaters
Well now I feel stupid, Tom is right, it is a heater for the Aqua hot and if I'd
have looked past my nose I would have seen the heater core from the CB compartment. I took the little compartment below the draw / cup holder out. There is a covering, plywood, above the heater core. There was a large tangle of wires and the control box for the musical horns and a wiring loom, all of it was just lying on top of the fans keeping them from operating. I moved everything out of the way and it is functioning fine. But as you know for every action there is an opposite and equal reaction. There are several things that are not as they should be. Fix one problem find two more needing attention. There appears to be an alarm system and two small boxes one of them appears to be a remote controlled relay it has a 10 pin harness, I bought a similar device to control the cooling fans Iâm installing in the engine compartment, the second box has a turn screw control and a light, it has a three pin harness, the switch is labeled: Alarm System it has three settings: Mikes On, System Off, Mikes Off. The wiring harnesses are not hooked up. Iâm not sure if all of these pieces are related or are for different systems. I was told the coach did not have an alarm system when I bought it but that appears to be wrong. If some one could tell what this stuff is I'd appreciate it. I'm hesitant to just plug everything in and wait to see what happens. The last thing I need is an unknown system shutting down the coach when least expected. Kurt Horvath, ( bumpersbird ) 95 PT-42 WLWB, ( Indulgance ) 10AC, ( Tennessee ) ----- Original Message ---- From: Tom McCarthy To: WanderlodgeForum@yahoogroups.com Sent: Thursday, November 22, 2007 11:42:23 AM Subject: [WanderlodgeForum] Re: PT-42 Front Heaters The larger vent up front should be controoled by you AquaHot Gas heating control near the middle of the coach. If you do not get heat there, your circulation fan must be out. My slider for the dash temparature control is also tight. Let me know if you find a way to make it easier. Tom McCarthy 95 PT42 Poway CA --- In WanderlodgeForum@ yahoogroups. com, "bumpersbird" > > '95 PT-42 Front Heater Question > > 1 - Ok I have dash heat and air like in any car or truck. But I also > have three vents on the bottom of the front consol, near the step > well. I thought that the thermostat that controls the front air would > operate one these vents, like the two thermostats in the kitchen and > bedroom, they operate the hydronic heat and A/C in those areas, but > it doesn't. The dash A/C â Heater operates the two floor vents over > the step well. But the third larger vent, more or less amid ship, > doesn't seem to do anything. I got my hand up in there behind it, > though the CB compartment and I couldn't feel any heater core of any > kind, or much of anything else for that matter. It might be like the > vents over the step well the heat just dumps into the consol area and > kind of pushes its way through the vents. Any help would be great! I > was told when I bought the coach that there is no heat up front when > the coach is in camper mode, only when the engine is running. If > anyone is curious there is a heater just under the sofa up front near > the drivers chair and it does a great job. I would just like one near > the door to offset heat loss when the family is going in and out 50 > times a day. > > 2 - Also the temperature control slider on the dash is very difficult > to operate. I'm afraid that I will break it; it takes that much force > to slide left or right. I know the cable and hinges need to be lubed, > but I'm not sure what to use for lube. WD-40 need not respond;} > ________________________________________________________________________________\ ____ Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs [Non-text portions of this message have been removed] |
11-23-2007, 05:40
PT-42 Front Heaters
Looks like I need to do some digging in the front dash area... I
probably have the same situation with the fans under the front dash. Alarm system: My coach was reported to not have an alarm system. There is nothing (obvious) that arms it -- although there was one Ace key (the round kind) that came with the coach and I haven't found anyplace where it is used. That said, when I experimented with the panic switch above the bed, an alarm sounded (darned if I know where it is mounted). I also noticed magnetic switches mounted on the bedroom window -- that are commonly used with alarm systems. So, there might be an alarm system _somewhere_ but previous owners were unaware of it. Or, the coach is prewired for an alarm system, but it isn't activated until a control box of some sort is installed. (The owner's manual is silent on the topic.) I also note that there is a switch for a radar detector on the dash. Up at the top of the windshield is a black box thing -- that I discovered was empty. So, it's possible that a radar detector was installed at one time in the past (and was removed) or that it was never installed, but a bracket for it was. I'm not really interested in a radar detector anyway... (The bracket holds my GPS aerial very nicely.) As for plugging in the alarm system, I don't think it will shut down the coach -- but it might set off a noisy alarm when you least expect it! Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Lockhart Texas On Nov 22, 2007, at 5:49 PM, Kurt Horvath wrote: > Well now I feel stupid, Tom is right, it is a heater for the Aqua > hot and if I'd have looked past my nose I would have seen the > heater core from the CB compartment. I took the little compartment > below the drawer / cup holder out. There is a covering, plywood, > above the heater core. There was a large tangle of wires and the > control box for the musical horns and a wiring loom, all of it was > just lying on top of the fans keeping them from operating. I moved > everything out of the way and it is functioning fine. > > <snip>The wiring harnesses are not hooked up. Iâm not sure if all > of these pieces are related or are for different systems. I was > told the coach did not have an alarm system when I bought it but > that appears to be wrong. > > If some one could tell what this stuff is I'd appreciate it. I'm > hesitant to just plug everything in and wait to see what happens. > The last thing I need is an unknown system shutting down the coach > when least expected. > > Kurt Horvath, ( bumpersbird ) > 95 PT-42 WLWB, ( Indulgance ) > 10AC, ( Tennessee ) |
11-23-2007, 08:12
PT-42 Front Heaters
Pete,
The Ace key is probably for the safe. Mine is located under a counter top in the bedroom, if you stand at the foot of the bed mine is under the right side cabinet, just as you enter the bedroom, against the bathroom wall. Just lift up the corian top and a steel cover will open up and there is a safe. Good luck there could be some goodies in there! I am happy to find the Heater, and that it works after getting all the mess cleaned up. As far as the alarm goes I'll ask my BB guru he might have an idea. The radar switch powers up the radar detector and your right that little boxed area is where it is located, my coach still has a radar detector in it but I never use it, they are more of a distraction than a help. Besides IMHO, if you need one in a Bird your driving too fast for your own good, not to mention eveyone else on the road. Pete I see that you sign off with '95 Blue Bird Wanderlodge WBDA 42. I found 4 designations for our year model coaches 42' WLWB -- 42' WTOS -- 42' WBSD -- 42' WBDA. I have been using WLWB but to tell you the truth I not really sure which is my proper designation, whenever I've talked with the guys a BB they don't seem to destiguish anything past WLWB. Maybe you or someone else could shed some light on this question. Kurt Horvath 95 PT-42 WLWB,WTOS, WBSD, WBDA ????????????????????? ----- Original Message ---- From: Pete Masterson To: WanderlodgeForum@yahoogroups.com Sent: Friday, November 23, 2007 11:40:04 AM Subject: Re: [WanderlodgeForum] PT-42 Front Heaters Looks like I need to do some digging in the front dash area... I probably have the same situation with the fans under the front dash. Alarm system: My coach was reported to not have an alarm system. There is nothing (obvious) that arms it -- although there was one Ace key (the round kind) that came with the coach and I haven't found anyplace where it is used. That said, when I experimented with the panic switch above the bed, an alarm sounded (darned if I know where it is mounted). I also noticed magnetic switches mounted on the bedroom window -- that are commonly used with alarm systems. So, there might be an alarm system _somewhere_ but previous owners were unaware of it. Or, the coach is prewired for an alarm system, but it isn't activated until a control box of some sort is installed. (The owner's manual is silent on the topic.) I also note that there is a switch for a radar detector on the dash. Up at the top of the windshield is a black box thing -- that I discovered was empty. So, it's possible that a radar detector was installed at one time in the past (and was removed) or that it was never installed, but a bracket for it was. I'm not really interested in a radar detector anyway... (The bracket holds my GPS aerial very nicely.) As for plugging in the alarm system, I don't think it will shut down the coach -- but it might set off a noisy alarm when you least expect it! Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Lockhart Texas On Nov 22, 2007, at 5:49 PM, Kurt Horvath wrote: > Well now I feel stupid, Tom is right, it is a heater for the Aqua > hot and if I'd have looked past my nose I would have seen the > heater core from the CB compartment. I took the little compartment > below the drawer / cup holder out. There is a covering, plywood, > above the heater core. There was a large tangle of wires and the > control box for the musical horns and a wiring loom, all of it was > just lying on top of the fans keeping them from operating. I moved > everything out of the way and it is functioning fine. > > <snip>The wiring harnesses are not hooked up. I¢m not sure if all > of these pieces are related or are for different systems. I was > told the coach did not have an alarm system when I bought it but > that appears to be wrong. > > If some one could tell what this stuff is I'd appreciate it. I'm > hesitant to just plug everything in and wait to see what happens. > The last thing I need is an unknown system shutting down the coach > when least expected. > > Kurt Horvath, ( bumpersbird ) > 95 PT-42 WLWB, ( Indulgance ) > 10AC, ( Tennessee ) Yahoo! Groups Links ________________________________________________________________________________\ ____ Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs [Non-text portions of this message have been removed] |
11-23-2007, 09:06
PT-42 Front Heaters
Well, I'll be darned.... there's a safe on board! Sadly, it was
empty. But it's good to know that it's there. And now I know what the round key is for! Designations... <sigh> Well the basic would be "PT-42" since that's what it is... The subcategories are important as some features are in different locations. WBDA means "wide body, diagonal aisle" as my coach is 102" wide (wide body) and has a diagonal refrigerator located on the centerline of the coach leading to a side aisle that goes past the bathroom (with a door on the aisle). Interestingly, Mr. Olivers now has a 95 with the diagonal aisle -- but a full width bath. So I don't know what they'd call it. WBWL is "wide body, WanderLodge" -- not really very descriptive. WBSD I'd guess is wide body side "d" (whatever "d" is) and so on... See vintage birds web site where they have some of the Wanderlodge alphabet soup spelled out... Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Lockhart Texas On Nov 23, 2007, at 2:12 PM, Kurt Horvath wrote: > Pete, > > The Ace key is probably for the safe. Mine is located under a > counter top in the bedroom, if you stand at the foot of the bed > mine is under the right side cabinet, just as you enter the > bedroom, against the bathroom wall. Just lift up the corian top and > a steel cover will open up and there is a safe. Good luck there > could be some goodies in there! > <snip> > Pete I see that you sign off with '95 Blue Bird Wanderlodge WBDA > 42. I found 4 designations for our year model coaches 42' WLWB -- > 42' WTOS -- 42' WBSD -- 42' WBDA. I have been using WLWB but to > tell you the truth I not really sure which is my proper > designation, whenever I've talked with the guys a BB they don't > seem to destiguish anything past WLWB. Maybe you or someone else > could shed some light on this question. > > Kurt Horvath 95 PT-42 WLWB,WTOS, WBSD, WBDA ????????????????????? > |
