dry camping
12-02-2007, 13:58
dry camping
The primary drain (through the inverters) is the power to the
refrigerator. It will limit your ability to operate off the grid with
an all-electric coach. (My '95 is all electric.) Newer refrigerators
are perhaps a bit more economical to operate than the 22 cu ft 2-door
Amana that I have in my coach -- but you're likely to experience the
similar power drain.
For example, I have 6 model 4D AGM-type house batteries. These have
about 220 amp hours each. So, 6 x 220 = 1320 amp hours. However,
that's an overstatement of what's available, as you can't deplete the
battery more than 50% for standard wet cell or by more than 60% for
AGM batteries. So that would mean there's between 660 and 792 amp
hours available from the battery to power all the 120 volt systems
that are serviced by the inverters. (I have two, 2500 watt
inverters.) Also, don't forget that the inverters cause a loss (10%
or more) while changing the 12 vdc to 120 vac. Don't forget that amps
X volts = watts. So, a 1000 watt refrigerator is about 8.3 amps at
120 v per hour. Convert that to 12 vdc, and its about 83 amps. With
the inverter loss, that's about 95 or 100 amps (per hour while the
refrigerator is running)... so that suggests about 6 to 8 hours or
perhaps 10 hours of operation (since it doesn't run 100% of the time)
just for the refrigerator. Add the microwave (high draw, but short
period) plus the various lights and the 12 volt stuff... and then you
can see that the batteries are kind of limiting!
Here's where you have to do some math. First figure out the
approximate hourly draw in amps of each appliance that runs on 120
volts. Don't forget that _some_ of the lights run on 120 volts and
are powered by the inverters. Of course, all 12 volt items and
appliances also draw from the batteries. So, you also have to figure
out what 12 volt appliances you have operating. Do not ignore the
draw from the Microphor toilet compressor nor from the air-system
auxiliary compressor, if you have one (I don't) along with various
signal lights, etc. etc. -- well, to be honest, there's a _lot_ of
load on a 'bird and without a source to recharge, the batteries can
be drawn down to a dangerous level in just a few days, even when
everything is "off."
So, back to the refrigerator -- the practical situation is to make
sure your house batteries are fully charged. If you have an isolation
switch to "turn off" everything, it would help. Anyway, when you
think your batteries are fully charged, isolate them (and unplug
shore power), then check the voltage. (This is the "resting"
voltage.) For AGM batteries, it should be about 12.9 to 13.0 volts
(wet cell batteries are different). Then, turn on the isolation
switch (apply the normal load) -- wait and hour, remove the load, and
check the voltage. 12.4 volts is 50% depletion and 12.25 volts is 60%
depletion -- do not let the volts drop below 12.25 volts!!! ---this
is "resting" voltage measured from the battery terminals.
Measurements drawn from other locations (e.g. a fuse panel) are
likely to be much lower due to line losses.)
My experience has been that "boondocking" isn't especially practical.
I can shut down the generator in the evening, but I usually need to
restart after about 12 hours or so. So, if I shut down at 8:00 PM,
I'll usually need to start the generator by about 8:00 AM the next
morning to avoid causing any damage to my batteries. This has caused
a fair amount of heart burn when I've stayed in a CA state park that
had a generator operation ban between 8 PM and 10 AM ... those two
hours were nail biting time and I had to shut down any/all items that
made demands on the batteries.
My plan (the next time I boondock) is to pull the breakers on the
inverters perhaps at 10 PM or so, and see how the batteries are the
next morning. The refrigerator won't warm up much during the night,
if it is not opened and if we're in a reasonably cool location.
I've compared notes with another all-electric Blue Bird owner (just
this past weekend at the Lone Star Birds rally in Kerrville, TX) and
I'm of the impression that my voltage drain seems to be on the high
side (so I may need to further explore possible reasons).
The reality is that you can probably turn off the generator in the
evening then turn it back on in the morning without major problems.
You can run the generator for 3 hours or so to bring the batteries
back up to full or near full charge. Then you can shut down the
generator for a few hours, then run it for 3 or 4 hours until the
time you wish complete quiet at night (or until any required shut
down time occurs).
The coach can be off the grid without the generator for periods of
several hours -- but it will need to have power to recover the
batteries rather more often and/or for longer periods than coaches
that have LP gas appliances.
See Poop Sheets by Phred at:
<http://www.phrannie.org/phredex.html>
#5 has a thorough discussion of "electrical stuff."
aeonix1@...
On the road at Lubbock Texas following a great weekend with the Lone
Star Birds at Kerrville, TX.
On Dec 1, 2007, at 2:08 PM, medpro28 wrote:
> Just purchased a 2005 LXi and need some advice on dry camping. I cook
> in bbq contests and sometimes no power or 110 only. Dealer says I
> will
> have to use the generator all the time. Although the unit is all
> electric, will not use the stove top or microwave while camping.
> It is
> hard to believe I can't dry camp any length of time and then use
> generator to keep batteries up.
> Is the dealers advice right or does anyone have thoughts or
> suggestions?
> Jerry Smith
> 2005 450 LXI
12-02-2007, 14:10
dry camping
You may have to check the batteries with a multi-tester at the
battery terminals.
I have a non-standard Heart Link 2000 R controller installed in my
coach that has a digital readout of the battery voltage at all times.
(Only problem is that it's misleading as it measures the batteries
under load which is a lower reading than when they're not under load.
aeonix1@...
On Dec 1, 2007, at 4:22 PM, JERRY SMITH wrote:
> Thanks for the reply have gone through the manual and the box. Can
> find
> nothing on the auto start for the generator and see no digital read
> out in
> the coach as to condition of the batteries. Bought coach at
> Parliament.
> Previous plastic coaches I had all had digital read out on
> condition of
> batteries.
> Jerry Smith
> -------Original Message-------
> Date: 12/01/07 16:50:51
> Subject: [WanderlodgeForum] Re: dry camping
> Jerry,
12-02-2007, 14:59
dry camping
Pete have you ever considered L16s. Randy has four in his rig and swears by
them. He says with a little modification he could put six in the available
space. They sure pack a lot of amps.
> down time occurs).
> Pete Masterson
> aeonix1@...
> > will
> > It is
> > suggestions?
> > Jerry Smith
> > 2005 450 LXI
Rob, Sue & Merlin Robinson
94 WLWB
12-02-2007, 17:43
dry camping
Not true. My Amana home fridge can run all day on inverters. I
charge in the evening and it runs all night with no problem.
Tom 2 Shoes McCarthy
Poway CA
--- In WanderlodgeForum@yahoogroups.com, "Gary Smith"
> Jerry,
> Dealer is right on for the most part. Your 120v refrigerator
gobbles 30-40
> amps of 12v power (via the inverter) each hour, so even a 4-6 hour
period
> will draw down your house batteries something serious, and that's
with
> everything else turned off, if you can.
> Gary
> SOB
> From: "medpro28" <medpro@...>
> To:
> Sent: Saturday, December 01, 2007 3:08 PM
> Subject: [WanderlodgeForum] dry camping
cook
will
It is
suggestions?
> Jerry Smith
> 2005 450 LXI
12-03-2007, 01:55
dry camping
Unfortunately, I just replaced the 4Ds this spring. The previous set
were (apparently) damaged by an improper controller setting that
occurred while the coach was in various dealer's hands. (It was reset
to the default settings, so it thought it was charging wet cell
batteries -- which over charged the AGMs.)
I'll check into the L16s... I did look at some various alternatives,
but I wasn't able to find anything that would (1) fit (2) provide at
least as much AH capacity as the 4Ds. (i.e. "better" batteries
wouldn't fit to allow enough to match/improve on the 4Ds.)
Thanks.
aeonix1@...
On the road at Lubbock TX where it's 26 degrees this morning.
> swears by
> available
>> down time occurs).
>> Pete Masterson
>> aeonix1@...
>>> cook
>>> will
>>> It is
>>> suggestions?
>>> Jerry Smith
>>> 2005 450 LXI
> 94 WLWB
> Yahoo! Groups Links
12-03-2007, 01:58
dry camping
Pete, great explanation. A big help to a guy like me that is electrically
challenged. Thank you for the help.
Jerry Smith
2005 450 LXi
Sarasota, Fl.
Date: 12/02/07 20:59:42
Subject: Re: [WanderlodgeForum] dry camping
down time occurs).
aeonix1@...
> will
> It is
> suggestions?
> Jerry Smith
> 2005 450 LXI
12-03-2007, 04:25
dry camping
Great explanation of the amp hour figure, Pete. Your refrigerator
shouldn't use that much juice though. If you can keep the door shut
most of the time, it should run about 30% of the time. The duty cycle
goes up a lot if you're fanning the door. Also, the defrost heater
uses a lot of juice when it cycles. It will normally occur once or
twice a day and last for about 12 or 15 minutes. Then the
refrigeration system has to run longer to cool things back off. You
can improve things a lot with a domestic refrigerator by keeping the
condenser coils clean and keeping the doors shut as much as possible.
Also, if there is a switch on its control panel for "humidity
control" or some such, you might want to keep it in the off or normal
or whatever it's labeled position. This is for some electrical
heating elements that are in the mullions around the door openings to
keep them from sweating in high humidity areas. The humidity probably
doesn't get that high inside your coach anyway. They use a fair
amount of electricity 24/7 when turned on. Not a big issue on shore
power, but could be significant when dry camping. A lot of the newer
refrigerators solve the sweating issue by routing the hot gas piping
from the compressor through the mullions before going to the
condenser; that's why you'll notice the mullions feeling hot to the
touch.
I'd like to see what the actual running amp draw is on one of these.
I work on appliances for a living; maybe I can remember to put an
Amprobe on one and see. I have a digital data logger that I can leave
in a refrigerator for a couple of days and tell you exactly how long
it's running and when it defrosts. Guess I need to find out how much
current it's drawing. Never been an issue in a home, but would be
good to know for when running on batteries.
Travis, the Newell guy in Lubbock, Texas
> down time occurs).
> Pete Masterson
> aeonix1@...
> cook
> > will
> > It is
> > suggestions?
> > Jerry Smith
> > 2005 450 LXI
12-03-2007, 07:56
dry camping
I had no idea that there even was an RV of any type that did not have
propane tanks? Guess that shows how out of touch I am. How about
heat in cold conditions? I guess you would certainly be running the
generator then? I guess you pays your money and takes your choice.
Gasoline or propane. Makes not a lot of difference?
John Heckman
central Pa
1973 FC
shut
cycle
You
possible.
normal
to
probably
shore
newer
piping
> touch.
these.
leave
long
much
with
refrigerators
door
have
for
(10%
amps
With
time)
you
figure
can
isolation
60%
this
practical.
to
caused
that
that
night,
(just
high
problems.
> > down time occurs).
> > Pete Masterson
> > aeonix1@...
Lone
I
> > cook
I
> > > will
> > > It is
> > > suggestions?
> > > Jerry Smith
> > > 2005 450 LXI
12-03-2007, 10:00
dry camping
John, in my case I have not filled the propane tank in three years. It
operates the cook top, reefer, and outside grill. It is still half
full. Up until recently, we used the coach quite often. Heat comes
from Wabasto, (hot). We (5 of us) can dry camp without significant
problems operating the genset about 4 hours per day if we are
conservative. Otherwise, the genset runs longer.
> John Heckman
> central Pa
> 1973 FC
> shut
> cycle
> You
> the
> possible.
> normal
> to
> probably
> shore
> newer
> piping
> the
> > touch.
> these.
> leave
> long
> much
> with
> refrigerators
> door
> the
> have
> the
> for
> (10%
> amps
> With
> time)
> you
> figure
> can
> isolation
> and
> 60%
> this
> practical.
> to
> caused
> that
> that
> the
> night,
> (just
> and
> high
> problems.
> > > down time occurs).
> > > Pete Masterson
> > > aeonix1@
> Lone
> I
> > > cook
> I
> > > > will
> > > > It is
> > > > suggestions?
> > > > Jerry Smith
> > > > 2005 450 LXI
12-03-2007, 11:12
dry camping
Leroy what coach and year do you have?
> > John Heckman
> > central Pa
> > 1973 FC
> > shut
> > cycle
> > You
> > the
> > possible.
> > normal
> > to
> > probably
> > shore
> > newer
> > piping
> > the
> > > touch.
> > these.
> > leave
> > long
> > much
> > with
> > refrigerators
> > door
> > the
> > have
> > the
> > for
> > (10%
> > amps
> > With
> > time)
> > you
> > figure
> > can
> > isolation
> > and
> > 60%
> > this
> > practical.
> > to
> > caused
> > that
> > that
> > the
> > night,
> > (just
> > and
> > high
> > problems.
> > > > down time occurs).
> > > > Pete Masterson
> > > > aeonix1@
> > Lone
> > I
> > > > cook
> > I
> > > > > will
> > > > > It is
> > > > > suggestions?
> > > > > Jerry Smith
> > > > > 2005 450 LXI
94 WLWB
