Wall thermostat problem
12-08-2007, 15:52
I have a problem in one of my wall thermostats. The one in the bedroom
that controls the propane furnace and chassis heat will work fine for some period of time, but sooner or later (usually sometime overnight while I am asleep), it quits shutting off and the heater runs continuously. While I guess I could just consider it a sauna, I'd really like to fix it instead. Any ideas what might cause this? Scott Forman 86 PT38 Memphis |
12-08-2007, 16:02
Scott,
Replace the theromostat with a digital unit. I'm going to do the same. On Dec 8, 2007 7:52 PM, Scott Forman <sforman@...> wrote: > I have a problem in one of my wall thermostats. The one in the bedroom > that controls the propane furnace and chassis heat will work fine for > some period of time, but sooner or later (usually sometime overnight > while I am asleep), it quits shutting off and the heater runs > continuously. While I guess I could just consider it a sauna, I'd > really like to fix it instead. Any ideas what might cause this? > > Scott Forman > 86 PT38 > Memphis > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
12-08-2007, 18:05
Curt will the digital maintain memory with the transfer switch? or
park power outage? I remember someone posting that they leave one a/c stat murcury to keep one zone on if they are away from the bus during the day and there is a momentary park poweroutage???? GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > Scott, > Replace the theromostat with a digital unit. I'm going to do the same. > > On Dec 8, 2007 7:52 PM, Scott Forman <sforman@...> wrote: > > > I have a problem in one of my wall thermostats. The one in the bedroom > > that controls the propane furnace and chassis heat will work fine for > > some period of time, but sooner or later (usually sometime overnight > > while I am asleep), it quits shutting off and the heater runs > > continuously. While I guess I could just consider it a sauna, I'd > > really like to fix it instead. Any ideas what might cause this? > > > > Scott Forman > > 86 PT38 > > Memphis > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > > [Non-text portions of this message have been removed] > |
12-08-2007, 20:51
Mine does the same- about froze a couple weeks, ago. Let us know what kind
of thermostat you come up with. Ernie Ekberg 83PT40 Weatherford, Tx **************************************Check out AOL's list of 2007's hottest products. (http://money.aol.com/special/hot-product...0000000001) [Non-text portions of this message have been removed] |
12-09-2007, 02:47
I don't know what's wrong with using a simple mechanical
thermostat. It's cheap and does the job. Maybe in my home where I want it to have several settings throughout the day/week, but in the RV it's much simpler to set it by hand. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Curt will the digital maintain memory with the transfer switch? or > park power outage? I remember someone posting that they leave one a/c > stat murcury to keep one zone on if they are away from the bus during > the day and there is a momentary park poweroutage???? > > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > > > > Scott, > > Replace the theromostat with a digital unit. I'm going to do the > same. > > > > On Dec 8, 2007 7:52 PM, Scott Forman <sforman@> wrote: > > > > > I have a problem in one of my wall thermostats. The one in the > bedroom > > > that controls the propane furnace and chassis heat will work fine > for > > > some period of time, but sooner or later (usually sometime > overnight > > > while I am asleep), it quits shutting off and the heater runs > > > continuously. While I guess I could just consider it a sauna, I'd > > > really like to fix it instead. Any ideas what might cause this? > > > > > > Scott Forman > > > 86 PT38 > > > Memphis > > > > > > > > > > > > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > > > > [Non-text portions of this message have been removed] > > > |
12-09-2007, 05:03
The Hunter digitals usually used to replace the mercury units are battery
powered, so yes, they retain their memory. In the 90 Bird, the original thermostats are a mixture - mercury for the heat, but digital for the A/C. Those digitals are A/C powered, and while they maintain memory, they revert to an off condition when there is momentary power loss. I intended to replace one of those, but instead opted for an in-shroud control when replacing an A/C. Gardner, the point of the digitals isn't for things like weekend differences - the digitals most use don't offer such "features." The points are: easy precision setting, low precise hysteresis, and no issues of contact sticking. The mercuries I replaced had high and variable hysteresis, in one case more than 10 degrees between off and on. The Hunter 42999B is cheap, easy to install, and easy to use. Wal-Mart is common source in the $20 range. The thermostat manual can be seen at http://www.hunterfanhq.com/tools/sales/h...42999b.pdf or http://tinyurl.com/2g47pv On 12/9/2007 at 6:05 AM Gregory OConnor wrote: >Curt will the digital maintain memory with the transfer switch? or >park power outage? I remember someone posting that they leave one a/c >stat murcury to keep one zone on if they are away from the bus during >the day and there is a momentary park poweroutage???? > >GregoryO'Connor >94ptRomolandCa > >--- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > >> >> Scott, >> Replace the theromostat with a digital unit. I'm going to do the >same. |
12-09-2007, 05:03
Is replacing the thermostat straightforward? I haven't pulled mine
off to investigate, but since that one unit controls propane heat, chassis heat, and the exhaust fan in the bedroom, I wondered if it might be more complicated than a normal one. Scott --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > Scott, > Replace the theromostat with a digital unit. I'm going to do the same. > > On Dec 8, 2007 7:52 PM, Scott Forman <sforman@...> wrote: > > > I have a problem in one of my wall thermostats. The one in the bedroom > > that controls the propane furnace and chassis heat will work fine for > > some period of time, but sooner or later (usually sometime overnight > > while I am asleep), it quits shutting off and the heater runs > > continuously. While I guess I could just consider it a sauna, I'd > > really like to fix it instead. Any ideas what might cause this? > > > > Scott Forman > > 86 PT38 > > Memphis > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > > [Non-text portions of this message have been removed] > |
12-09-2007, 05:17
Shouldn't be difficult. One of the ones I replaced controls propane furnace,
electric heat, and exhaust fan. In heat mode it controls either furnace or heater depending on the setting of an existing/remaining switch. In cool mode it controls the fan. In fan mode the fan can be manually turned on/off. All normal. On 12/9/2007 at 5:03 PM Scott Forman wrote: >Is replacing the thermostat straightforward? I haven't pulled mine >off to investigate, but since that one unit controls propane heat, >chassis heat, and the exhaust fan in the bedroom, I wondered if it >might be more complicated than a normal one. > >Scott > >--- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > >> >> Scott, >> Replace the theromostat with a digital unit. I'm going to do the >same. |
12-09-2007, 05:30
Don,
Thanks for the response. I guess I'm getting old and just don't trust the new fangeled 'digital' things. But really, thanks for the explanation. My original units do seem to have a mind of their own. The unique "boyoiyoing" sound when it shuts off is always a reasurance during the night that it is working, and it wakes you up just to be sure you are paying attention. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > The Hunter digitals usually used to replace the mercury units are battery powered, so yes, they retain their memory. In the 90 Bird, the original thermostats are a mixture - mercury for the heat, but digital for the A/C. Those digitals are A/C powered, and while they maintain memory, they revert to an off condition when there is momentary power loss. I intended to replace one of those, but instead opted for an in-shroud control when replacing an A/C. > > Gardner, the point of the digitals isn't for things like weekend differences - the digitals most use don't offer such "features." The points are: easy precision setting, low precise hysteresis, and no issues of contact sticking. The mercuries I replaced had high and variable hysteresis, in one case more than 10 degrees between off and on. > > The Hunter 42999B is cheap, easy to install, and easy to use. Wal- Mart is common source in the $20 range. The thermostat manual can be seen at http://www.hunterfanhq.com/tools/sales/h...ges/owners /42999b.pdf or http://tinyurl.com/2g47pv > > On 12/9/2007 at 6:05 AM Gregory OConnor wrote: > > >Curt will the digital maintain memory with the transfer switch? or > >park power outage? I remember someone posting that they leave one a/c > >stat murcury to keep one zone on if they are away from the bus during > >the day and there is a momentary park poweroutage???? > > > >GregoryO'Connor > >94ptRomolandCa > > > >--- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > > >> > >> Scott, > >> Replace the theromostat with a digital unit. I'm going to do the > >same. > |
12-09-2007, 06:26
Does anyone know if the Hunter (or some other digital) can replace
the Dometic thermostats used for both AC and hydronic heat in my '95? They appear to be analog/digital ... the temperature lever is a rheostat (?) that slides back and forth (and isn't very precise) but I see no moving parts inside the box -- just a circuit board. I was hoping there was a control for the hysteresis (temperature lag) -- but there's none I can identify. My issue with the thermostat is only with the heat -- it seems to have a too narrow temperature range. For example, I like to keep the bedroom cool for sleeping (around 60-62) if weather permits, but the thermostat will cycle on for 15 seconds, then off for 15 seconds, then on for 15 seconds, etc. I can get used to the fan noise (it's not _that_ loud) but the constant on-off-on-off wakes me up and drives me nuts. I wouldn't mind _more_ hysteresis so that heat would run on for at least a few minutes before it cycles off for several more minutes. Anyone else have this issue? Any ideas? Thanks. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Golden CO On Dec 9, 2007, at 10:03 AM, Don Bradner wrote: <snip> > The point of the digitals isn't for things like weekend differences > - the digitals most use don't offer such "features." The points > are: easy precision setting, low precise hysteresis, and no issues > of contact sticking. The mercuries I replaced had high and variable > hysteresis, in one case more than 10 degrees between off and on. > > The Hunter 42999B is cheap, easy to install, and easy to use. Wal- > Mart is common source in the $20 range. The thermostat manual can > be seen at http://www.hunterfanhq.com/tools/sales/h...preseason/ > images/owners/42999b.pdf or http://tinyurl.com/2g47pv |
