8v92 temperature
12-09-2007, 13:49
8v92 temperature
8v92 owners...what temp does your engine run when cruising?
Mine hovers around 190. When it creeps a bit past the 190 line on the gauge, I assume the fan kicks in, and it cools to just below 190 on the gauge. Then it heats back up and the process is repeated. Is this similar to other owners' experiences? Scott Forman 86 PT38 Memphis |
12-09-2007, 13:54
8v92 temperature
Exactly what happens with mine. It typically only goes 5 to 8 degrees over 190
before the fan kicks in and lowers it back down to the 190 range. Scott Forman <sforman@...> wrote: 8v92 owners...what temp does your engine run when cruising? Mine hovers around 190. When it creeps a bit past the 190 line on the gauge, I assume the fan kicks in, and it cools to just below 190 on the gauge. Then it heats back up and the process is repeated. Is this similar to other owners' experiences? Scott Forman 86 PT38 Memphis --------------------------------- Looking for last minute shopping deals? Find them fast with Yahoo! Search. [Non-text portions of this message have been removed] |
12-09-2007, 13:55
8v92 temperature
Sorry, fyi below.
1988 WB40 Drew May happens with mine. It typically only goes 5 to 8 degrees over 190 before the fan kicks in and lowers it back down to the 190 range. Scott Forman <sforman@...> wrote: 8v92 owners...what temp does your engine run when cruising? Mine hovers around 190. When it creeps a bit past the 190 line on the gauge, I assume the fan kicks in, and it cools to just below 190 on the gauge. Then it heats back up and the process is repeated. Is this similar to other owners' experiences? Scott Forman 86 PT38 Memphis --------------------------------- Looking for last minute shopping deals? Find them fast with Yahoo! Search. [Non-text portions of this message have been removed] --------------------------------- Never miss a thing. Make Yahoo your homepage. [Non-text portions of this message have been removed] |
12-09-2007, 13:56
8v92 temperature
Sent from my Verizon Wireless BlackBerry
12-09-2007, 14:05
8v92 temperature
That pretty much describes what I see on my analoge guage. My VMSPC will
register as high as 199. It does, as you say, go up and down in conjunction with the fan on and off. If I leave the fan override on then the temp does not fluctuate and stays steady......usually around188F On 09/12/2007, Scott Forman <sforman@...> wrote: > > 8v92 owners...what temp does your engine run when cruising? > > Mine hovers around 190. When it creeps a bit past the 190 line on the > gauge, I assume the fan kicks in, and it cools to just below 190 on the > gauge. Then it heats back up and the process is repeated. > > Is this similar to other owners' experiences? > > Scott Forman > 86 PT38 > Memphis > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
12-09-2007, 14:08
8v92 temperature
Scott,
My experience is the same as yours. Howard T., Sowega, 86, 8V92, PT40 ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Sunday, December 09, 2007 8:49 PM Subject: [WanderlodgeForum] 8v92 temperature 8v92 owners...what temp does your engine run when cruising? Mine hovers around 190. When it creeps a bit past the 190 line on the gauge, I assume the fan kicks in, and it cools to just below 190 on the gauge. Then it heats back up and the process is repeated. Is this similar to other owners' experiences? Scott Forman 86 PT38 Memphis ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.5.486 / Virus Database: 269.16.13/1170 - Release Date: 12/4/2007 10:52 AM [Non-text portions of this message have been removed] |
12-09-2007, 14:22
8v92 temperature
Major detail on 8v92 temps in the archives. try a message search. I
search these archives and get most of my answers/ input. Not saying you are lazy just saying you may be missing the quality input archived on this site. The yahoo message search crawler is lame but you can also do a google advance search and list this site to get a more refined result. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > 8v92 owners...what temp does your engine run when cruising? > > Mine hovers around 190. When it creeps a bit past the 190 line on the > gauge, I assume the fan kicks in, and it cools to just below 190 on the > gauge. Then it heats back up and the process is repeated. > > Is this similar to other owners' experiences? > > Scott Forman > 86 PT38 > Memphis > |
12-09-2007, 15:48
8v92 temperature
Our '87 PT38 performed about the same...after new thermostats and radiator
cleaning the temp. runs about 180 and rarely climbs to 190 on the steep grades. Oil temperature is running cooler as well. On Dec 9, 2007 5:49 PM, Scott Forman <sforman@...> wrote: > 8v92 owners...what temp does your engine run when cruising? > > Mine hovers around 190. When it creeps a bit past the 190 line on the > gauge, I assume the fan kicks in, and it cools to just below 190 on the > gauge. Then it heats back up and the process is repeated. > > Is this similar to other owners' experiences? > > Scott Forman > 86 PT38 > Memphis > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
12-09-2007, 16:24
8v92 temperature
Observing the VMSpc digital reading, I believe my cutin/outs are 196 and 190,
and on tyical non-stress level driving there is one degree of over/undershoot, so the temp floats between 189 and 197. I could not possibley say that from the analog gauge, other than to say the bottom is just below 190, and the top a few degrees above 190. With the fan override on the temps run steady dependent on load and ambient. Under non-stress conditions that is about 180, presumably where the water thermostat is. I've touched 200 a couple of times, but nothing higher. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA On 12/10/2007 at 1:49 AM Scott Forman wrote: >8v92 owners...what temp does your engine run when cruising? > >Mine hovers around 190. When it creeps a bit past the 190 line on the >gauge, I assume the fan kicks in, and it cools to just below 190 on the >gauge. Then it heats back up and the process is repeated. > >Is this similar to other owners' experiences? > >Scott Forman >86 PT38 >Memphis |
12-09-2007, 23:48
8v92 temperature
I do not know what year Alarmstat electric controls were first installed by BB.
By reading posts on this and other forums apparently some earlier fan controls were air operated. I have personally seen two coaches without either one. Mine is a DDEC II and has an Alarmstat. The factory setting was 195 degrees. The typical Alarmstat has an operating range of 8-10 degrees. I changed mine to 190 degrees some time ago. With the chassis air and the fan override off, the temperature will cycle. There will be a noticeable difference in Winter due to OAT being lower. In Summer the temperature should remain stable at about 190 degrees simply because the road surface temperature may not allow radiator water to be cooled to the cut in point of the Alarmstat.(ie. the fan is constantly in high mode.) In any case, if the fan override or the chassis a/c is on the fan is always in high mode. Temperatures should remain stable in this configuration until significant loads are introduced. Water temperature on different coaches with the same Alarmstat configuration could be as much as 5 degrees different depending on the placement of the chassis a/c condenser (mine covers most of the front of the engine radiator, others are on top of the bus with separate fans), how clean the radiator is and other factors. I recently found from another owner that the fan is controlled by the DDEC control unit on units with DDECIII configuration.Probably a later model Series 60. If all works according to the book, mine will alarm at 210 degrees and shut down a 215 degrees. The real key is the engine oil temperature. It is controlled by the water temp. All that being said, mine runs normally between 185 and 193 on the VMSpc. With the fan override on I can see stable temperatures in Winter in the 178 degree range. Summer between 188-190 with the chassis a/c on. Hope this helps. Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Scott Forman <sforman@...> wrote: 8v92 owners...what temp does your engine run when cruising? Mine hovers around 190. When it creeps a bit past the 190 line on the gauge, I assume the fan kicks in, and it cools to just below 190 on the gauge. Then it heats back up and the process is repeated. Is this similar to other owners' experiences? Scott Forman 86 PT38 Memphis --------------------------------- Looking for last minute shopping deals? Find them fast with Yahoo! Search. [Non-text portions of this message have been removed] |
