Freeze Heaters
12-14-2007, 10:04
Freeze Heaters
I have located three freeze heaters on my PT...one behind the kitchen
sink, one under the street-side twin bed, and one in the water heater
compartment. They all appear to work. The coach is drained of water,
so I doubt I will use them much, but it will be nice to know they are
there for a little insurance on a very cold night.
Are these the only three? What about heating the water tank (under
curb-side twin bed) or the bathroom plumbing?
Scott Forman
86 PT38
Memphis
12-14-2007, 10:08
Freeze Heaters
Much of the copper water lines are wrapped with an electric heat tape.
Bill 88 FC Michigan
water,
> Scott Forman
> 86 PT38
> Memphis
12-14-2007, 10:16
Freeze Heaters
Then why are there radiant heaters in these spaces?
I have never noticed any heat tape in my coach...then again, I wasn't
looking for it. Where is the thermostat for heat tape if I have it?
Scott
tape.
> Bill 88 FC Michigan
> --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@>
kitchen
heater
> water,
are
(under
> > Scott Forman
> > 86 PT38
> > Memphis
12-14-2007, 11:30
Freeze Heaters
Your coach has little electric heaters in those spaces? You have circuit
breakers in the main panel for freeze heaters? Just wondering, BB's are so
different.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Royale Conversion
Scott Forman <sforman@...> wrote: Then
Scott
tape.
> Bill 88 FC Michigan
kitchen
heater
> water,
are
(under
> > Scott Forman
> > 86 PT38
> > Memphis
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
12-14-2007, 11:42
Freeze Heaters
My coach depends primarily on the AquaHot-heated basement to protect
against freezing. However, while replacing the floor, I discovered a
small length of plumbing running in the curb-side "chase" (that's
normally covered up with carpet/flooring) with heat tape wrapped
around it.
There is no indication where the power comes from for the heat tape
and the wires disappear behind the galley cabinets so I couldn't
trace the wires. Nothing on any of the power panels mentions a
breaker for the heat tape nor did I see a thermostat for it.
I guess it works, 'cause we've been down to 9 degrees here during the
past couple of weeks and nothing (inside or in the basement) has
frozen up.
Pete Masterson
aeonix1@...
On the road at Golden CO
> circuit breakers in the main panel for freeze heaters? Just
> wondering, BB's are so different.
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
> wrote: Then why are there radiant
> Scott
> tape.
>> Bill 88 FC Michigan
> kitchen
> heater
>> water,
> are
> (under
>>> Scott Forman
>>> 86 PT38
>>> Memphis
12-14-2007, 11:59
Freeze Heaters
Yes, small electric radiant heaters similar to to an old fashioned
baseboard heater. Each one has a separate industrial thermostat that
allows temp setting from 30-110 degrees. There are two breakers for
these heaters.
Scott
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
wasn't
it?
> Scott
> tape.
> > Bill 88 FC Michigan
<sforman@>
> kitchen
> heater
of
> > water,
they
> are
> (under
> > > Scott Forman
> > > 86 PT38
> > > Memphis
Try it now.
12-14-2007, 14:49
Freeze Heaters
I would not mind having those if needed. Even with hydronic heat mine had a wire
type freeze heater, can't remember the name now since I removed them. I did not
know they were there. Mine were hidden wrapped inside the insulation of the
plumbing, they somehow got crossed over, shorted out an fried the water pipe in
half. The circuit breaker did not trip. I am just happy the water pump was on.
It did flood the bus up and down but that is better than burning up.
Leroy Eckert
Dahlonega, GA
Royale Conversion
Scott Forman <sforman@...> wrote: Yes,
these heaters.
Scott
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
wasn't
it?
> Scott
> tape.
> > Bill 88 FC Michigan
<sforman@>
> kitchen
> heater
of
> > water,
they
> are
> (under
> > > Scott Forman
> > > 86 PT38
> > > Memphis
Try it now.
12-14-2007, 15:19
Freeze Heaters
Pete,
The freeze tape is connected to a regular 120v duplex outlet behind the false
back of the kitchen cabinet and is controlled by the Freeze Heater Breaker in
the main 120v fuse panel. I know of 2 for sure in my coach they are under the
sink in the kitchen against the inside wall. The cabinets are not heated and
being against an outside wall, I suppose in very cold weather they could freeze
while the interior of the coach is toasty warm. My coach sat outside all last
winter no problems.
Kurt Horvath
95 PT-42 WLWB
10AC
----- Original Message ----
Sent: Friday, December 14, 2007 5:42:55 PM
Subject: Re: [WanderlodgeForum] Re: Freeze Heaters
around it.
frozen up.
Pete Masterson
aeonix1@mac. com
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
> Scott Forman <sforman@renasant. com>
> Scott
> --- In WanderlodgeForum@ yahoogroups. com, "pattypape"
> tape.
>> Bill 88 FC Michigan
>> --- In WanderlodgeForum@ yahoogroups. com, "Scott Forman" <sforman@>
> kitchen
> heater
>> water,
> are
> (under
>>> Scott Forman
>>> 86 PT38
>>> Memphis
____
Looking for last minute shopping deals?
Find them fast with Yahoo! Search.
http://tools.search.yahoo.com/newsearch/...y=shopping
12-15-2007, 08:23
Freeze Heaters
That good to know. I note that the _thermostat_ for the under-galley
Perfectoe electric heater is located on an exterior wall. In the
current weather situation, it runs constantly even with the
thermostat set to a very low temperature. (It was 9 degrees early
this AM.) I realized that the cold from the outside was reaching the
thermostat through the wall... I'd expect that the heat tape is very
needed in those locations behind the sink cabinets and in the wire
chase where I observed it.
Pete Masterson
aeonix1@...
On the road at Golden CO.
On Dec 14, 2007, at 8:19 PM, Kurt Horvath wrote:
> Pete,
> the false back of the kitchen cabinet and is controlled by the
> Freeze Heater Breaker in the main 120v fuse panel. I know of 2 for
> sure in my coach they are under the sink in the kitchen against the
> inside wall. The cabinets are not heated and being against an
> outside all last winter no problems.
