1990 wb40 starter question
12-18-2007, 10:31
I have a 1990 wb40 it seems to have a delay when I turn the Key
it seems to be a hesitation ,like the batterys are week but then it kicks right in and starts Is this normal Jamie Brandt 1990 wb40 port charlotte florida |
12-18-2007, 10:44
Jamie it sounds like maybe some electrical connections might need some
cleaning up. Grounds would be my first check and that brass bent band of metal that connects the starter to the solenoid strapped on top of it. Mine was corroded, pitted and definitely caused a hesitation in my start routine. Cleaned up and has never hesitated since. On 18/12/2007, gasparillaglass > > I have a 1990 wb40 it seems to have a delay when I turn the Key > it seems to be a hesitation ,like the batterys are week but then it > kicks right in and starts > Is this normal > > Jamie Brandt > 1990 wb40 > port charlotte florida > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
12-18-2007, 10:48
When you first the key on, the coach is going through some diagnostics
and I assume that is the slight delay you are experiencing. R.E. (Ron) Marabito, dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "gasparillaglass" > > I have a 1990 wb40 it seems to have a delay when I turn the Key > it seems to be a hesitation ,like the batterys are week but then it > kicks right in and starts > Is this normal > > Jamie Brandt > 1990 wb40 > port charlotte florida > |
