Oil Temperature
12-20-2007, 06:51
Oil Temperature
Anyone know where the oil temp sensor is located. Need to know what
the temp guage is reading. After a long idle checking flow on
radiator, I have a reading of 170F on guage and 150F on the oil pan.
Which is more likely the accurate temperature?
R.e. (Ron) Marabito, Dallas, TX 92WB40
12-20-2007, 07:21
Oil Temperature
You CANNOT get a diesel up to temp by idleing it>you will do it no good!
Pete
-------------- Original message --------------
12-20-2007, 07:29
Oil Temperature
Mine is located on top of the oil filter housing on the road side of the engine.
I would guess both are probably close because of where the temperatures are
measured. swag!!!
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Royale Conversion
ronmarabito2002 wrote: Anyone
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
12-20-2007, 09:52
Oil Temperature
Both are accurate and relative to a monitored change. the 170 may be
reading closer to the friction and thus a quicker indicator of stress.
the pan may be the last place oil temp signals friction stress, the
metal pan may also lose heat to the cast block.
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002"
12-20-2007, 10:06
Oil Temperature
But, do you know where the sensor is located?
> GregoryO'Connor
> 94ptRomolandCa
12-20-2007, 15:09
Oil Temperature
Its up above the starter closer to the tranny remote mounted. some
may be hooked up to the oilfilter housing
GregroyO'Connor
94ptRomolandCa
be
stress.
> > GregoryO'Connor
> > 94ptRomolandCa
what
pan.
12-21-2007, 03:38
Oil Temperature
Thanks for the location Greg.
> GregroyO'Connor
> 94ptRomolandCa
> be
> stress.
> the
> > > GregoryO'Connor
> > > 94ptRomolandCa
> what
> pan.
