Power Steering Problems
12-21-2007, 05:25
I'm having a problem with the power steering on my '83 FC-35, and
after looking through the archives I'm afraid I probably know what the
answer is, but being a "new" BB owner; just wanted the experts to
confirm my suspicions of needing a new or rebuilt PS pump.
The problem I'm having is that I can only turn the wheel less then a
1/4 turn when the coach is stationary. Beyond that point, the wheel
stiffens up, accompanied by some loud squealing and growling. When
moving, it seems to work ok, but at low speeds (such as when parking
in a tight spot) it doesn't want to turn more then a 1/4 turn of the
wheel. When I took a test drive prior to purchasing it, all worked
fine during the brief trip. Now however, it's a different story. I
was able to back the coach into it's storage spot by making what
seemed like a 30-point turn, but I need to move it to a different
location soon and I'm at somewhat of a loss as to what I'm up against
in terms of the repair. Considering the time of year & weather, I'd
like to get a mobile mechanic out to look at it if I can, but not sure
I'd have much luck with that. How involved of a R&R job is this?
Graham
Baltimore, MD
83 FC-35
12-21-2007, 06:15
Probably need to tighten the belt. It can be done from the bottom. Not easily,
but it can be done. If the pump area is too nasty to see the bolts and such, a
couple of cans of brake kleen will reveal most of what you need to see. You
will of course place a drain pan under the pump while cleaning.
MH
Sent: Friday, December 21, 2007 11:25 AM
Subject: [WanderlodgeForum] Power Steering Problems
Graham
Baltimore, MD
83 FC-35
12-21-2007, 08:19
Check the fluid level before calling the mobile Guy.
There may be a power steerng fluid leak.
Bill 88 Fc Michigan
--- In WanderlodgeForum@yahoogroups.com, "ridgemede310"
against
sure
> Graham
> Baltimore, MD
> 83 FC-35
12-21-2007, 08:35
You have it right Rose Mary. It does help to have the belts very tight to
stop the squeals and slipping but, at a stop, there just isn't enough power
steering to move the wheels. You should only be turning the wheels when the
coach has some movement, forward or backwards.
Steve Anderson
79 FC 35
Presently in Laughlin, Nevada. freezin my ass.
In a message dated 12/21/2007 3:26:43 P.M. US Mountain Standard Time,
winstonnews@... writes:
Hi
I thought this was the norm? thought we weren't supposed to crank the
steering much while stationery..steering much while stationery..
mine squeaks and moans when turning sharp at very low speed...
otherwise works fine, though have had to have the bolts on the
steering box tightened more than once.
Rose Mary
82 FC 35
JP's White Bird
near Sacramento at present
--- In _WanderlodgeForum@WanderlodgeFWan_
(mailto:WanderlodgeForum@yahoogroups.com) , "ridgemede310"
> Graham
> Baltimore, MD
> 83 FC-35
**************************************See AOL's top rated recipes
(http://food.aol.com/top-rated-recipes?NC...0000000004)
12-21-2007, 10:26
Hi
steering much while stationery...or so I was previously told.
Rose Mary
82 FC 35
JP's White Bird
> Graham
> Baltimore, MD
> 83 FC-35
12-21-2007, 10:36
When we arrived here Monday, it was beautifully clear and 65. Yesterday
evening at dusk, the wind came up gusting 20 to 25 and the temperature dropped
to
mid 40's. It has continued to blow pretty hard all day today and this
evening with the temperature remaining in mid 40 to low 40's. We are parked in
River Palms upper parking lot. We have a gorgeous view but there is no way we
could sit outside to enjoy it. We are moving up to Las Vegas Saturday to
meet our daughter for Christmas Sunday morning. We made a trial run to Vegas
today. Windy and 46 degrees.
I don't know what type of work you plan but outside work will be not so
pleasant.
Steve Anderson
79 FC 35
In a message dated 12/21/2007 7:34:29 P.M. US Mountain Standard Time,
curtsprenger@... writes:
Steve,
How cold is it over there? Day time temperatures? I have a home a few miles
south of Laughlin, about 18 miles, and plan to go over there next week to do
some TLC work. Maybe I should put that off for a while.
On Dec 21, 2007 5:35 PM, <_ebirder2000@ebirder_ (mailto:ebirder2000@...)
> to
> power
> the
> Steve Anderson
> 79 FC 35
> _winstonnews@winstonne_ (mailto:winstonnews@...)
writes:
> Hi
> steering much while stationery.. steering much while station
> Rose Mary
> 82 FC 35
> JP's White Bird
> --- In _WanderlodgeForum@ --- In _Wan
> (mailto:_WanderlodgeForum@WanderlodgeFWan_
(mailto:WanderlodgeForum@yahoogroups.com) )
> , "ridgemede310"
> > Graham
> > Baltimore, MD
> > 83 FC-35
> (_http://food.http://food.http://food.<Whttp://food.<WBRhttp://fo_
(http://food.aol.com/top-rated-recipes?NC...0000000004) )
Curt Sprenger
Anaheim Hills, CA
12-21-2007, 10:48
Too T
In a message dated 12/21/2007 8:42:33 P.M. US Mountain Standard Time,
marvwheeler@... writes:
Steve:
You might as well be in Poulsbo.
Marv
2004 M380
Ocean Shores, WA
(mailto:WanderlodgeForum@yahoogroups.com) , ebirder2000@, ebir
Yesterday
temperature dropped to
this
are parked in the
is no way we
Saturday to
run to Vegas
not so
> pleasant.
> Steve Anderson
> 79 FC 35
Time,
> curtsprenger@ curtsp
> Steve,
few miles
week to do
> On Dec 21, 2007 5:35 PM, <_ebirder2000@_ebirder2
(mailto:ebirder2000(mailt
tight
> > to
enough
> > power
wheels when
> > the
> > Steve Anderson
> > 79 FC 35
Time,
> > _winstonnews@ _winstonnews@winstonne_ _wins
> writes:
> > Hi
crank the
> > Rose Mary
> > 82 FC 35
> > JP's White Bird
> > (mailto:_Wanderlodg (mailto:_Wander (mailto:_Wa
(mailto:WanderlodgeForum@yahoogroups.com) ) WanderlodgeForWan>
> > , "ridgemede310"
what the
to
then a
wheel
When
parking
of the
worked
story. I
what
different
against
weather, I'd
not sure
this?
> > > Graham
> > > Baltimore, MD
> > > 83 FC-35
(__http://food.http://food.http://food._
(http://food.http//food.http://food.) <_Whttp://food._ (whttp://food./)
<_WBRhttp://fo__ (wbrhttp://fo_/)
(http://food.aol.com/top-rated-recipes?NC...0000000004) ) )
> Curt Sprenger
> Anaheim Hills, CA
12-21-2007, 14:34
Steve,
> to
> power
> the
> Steve Anderson
> 79 FC 35
> Hi
> Rose Mary
> 82 FC 35
> JP's White Bird
> , "ridgemede310"
> > Graham
> > Baltimore, MD
> > 83 FC-35
Curt Sprenger
Anaheim Hills, CA
12-21-2007, 15:42
Steve:
Marv
2004 M380
Ocean Shores, WA
Yesterday
this
are parked in the
is no way we
Saturday to
run to Vegas
not so
> pleasant.
> Steve Anderson
> 79 FC 35
Time,
> Steve,
few miles
week to do
tight
> > to
enough
> > power
wheels when
> > the
> > Steve Anderson
> > 79 FC 35
Time,
> writes:
> > Hi
crank the
> > Rose Mary
> > 82 FC 35
> > JP's White Bird
> (mailto:WanderlodgeForum@yahoogroups.com) WanderlodgeForWan>)
> > , "ridgemede310"
what the
to
then a
wheel
When
parking
of the
worked
story. I
what
different
against
weather, I'd
not sure
this?
> > > Graham
> > > Baltimore, MD
> > > 83 FC-35
> Curt Sprenger
> Anaheim Hills, CA
12-22-2007, 03:20
Thanks everyone for the replies! I do still get some squealing and
resistance when turning the wheel when moving slowly. And the
previous owner mentioned that there is a small PS leak, so looks like
I do have some work to do in that area, but the problem doesn't appear
as critical as I originally though. Have a great holiday!
Graham
83 FC 35
Baltimore, MD
tight to
enough power
when the
> Steve Anderson
> 79 FC 35
> Hi
> Rose Mary
> 82 FC 35
> JP's White Bird
what the
sure
> > Graham
> > Baltimore, MD
> > 83 FC-35
