GROAN-N-N
12-26-2007, 07:07
GROAN-N-N
Howdy, Wanderlodge family.
I turned on the hot water tap in our 1993 Wanderlodge's shower
earlierthis AM. Zilch, nada, no hot water, just lukewarm water. No hot
waterat any of the other sinks, either. Jack is going to check out
theelectrical connections. If you have replaced your electric
waterheater in your coach, we sure would like to hear about
yourexperiences.
TIA,
Jack and Liz Pearce
1993 Wanderlodge
Wintering in Hondo, TX
12-26-2007, 07:54
GROAN-N-N
Several of us have replaced our Sealand originals with Force Ten. Force Ten
are Sealand copies but with better materials and engineering. Make sure you
get the one that is the exact replacement for your existing water heater. If
your 93 is like my 94 it will have two nipples at the back end for motor aid
heat IN/OUT. Here's a link for the Force Ten
http://www.force10.com/index.html
> yourexperiences.
> TIA,
> Jack and Liz Pearce
> 1993 Wanderlodge
Rob, Sue & Merlin Robinson
94 WLWB
12-26-2007, 07:59
GROAN-N-N
I should have sent you this url for Force Ten suppliers
http://www.force10.com/distributors.html
> yourexperiences.
> TIA,
> Jack and Liz Pearce
> 1993 Wanderlodge
94 WLWB
12-26-2007, 08:02
GROAN-N-N
And I misspoke. They are Seaward copies.
> yourexperiences.
> TIA,
> Jack and Liz Pearce
> 1993 Wanderlodge
94 WLWB
12-26-2007, 08:42
GROAN-N-N
Force Ten
sure you
heater. If
motor aid
Howdy, Rob.
We have an Atwood heater. Thanks for the informative reply, though.
Jack feels that he might just have to replace the heating element. I'll
check out the Force Ten, too.
Thanks again,
Liz
1993 WLWb
Hondo, TX
12-26-2007, 08:58
GROAN-N-N
We have Force ten water heaters in stock
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce"
> Force Ten
> sure you
> heater. If
> motor aid
> Howdy, Rob.
> Thanks again,
> Liz
> 1993 WLWb
> Hondo, TX
12-26-2007, 09:31
GROAN-N-N
The Force Ten link you provided works just fine, except for the fact
that they don't show any hot water heaters under products. Would
appreciate more information.
R.E. (Ron) Marabito, Dallas, tX 92WB40
Force Ten
sure you
heater. If
motor aid
> > yourexperiences.
> > TIA,
> > Jack and Liz Pearce
> > 1993 Wanderlodge
> 94 WLWB
12-26-2007, 09:57
GROAN-N-N
I ran into the same lack of water heater product information Smile
Dorn Hetzel
77FC35
Hogansville, GA
> "Rob Robinson"
> Force Ten
> sure you
> heater. If
> motor aid
> > > yourexperiences.
> > > TIA,
> > > Jack and Liz Pearce
> > > 1993 Wanderlodge
> > 94 WLWB
12-26-2007, 10:03
GROAN-N-N
Sorry folks I just remembered they sold out and I believe it was to this
company. You might have to call them to get info on the model with rear
in/out primus nipples.
http://www.kuumaproducts.com/index3.html
Steve Birtles can get them for you. I would check out his prices.
> Dorn Hetzel
> 77FC35
> Hogansville, GA
> > --- In
WanderlodgeForum@yahoogroups.com Forum%40yahoogroups.com>,
> > "Rob Robinson"
> > Force Ten
> > sure you
> > heater. If
> > motor aid
> hot
> > > > yourexperiences.
> > > > TIA,
> > > > Jack and Liz Pearce
> > > > 1993 Wanderlodge
> > > 94 WLWB
94 WLWB
12-26-2007, 14:03
GROAN-N-N
Jack and Liz, turn off the 110 vac at the breaker box, going to the water
heater. Remove the cap that covers the electrical connections and between
the two spade type connectors there will be a re-setable circuit breaker
ECO, push it to reset the breaker. Bring power back up and check for 110
vac with your meter on those spade connectors. That should get you hot
water. If it trips again then we need to do an ohms check on the heating
element.
Lets not jump off the deep end planning a replacement until you know it
needs replacing?
Safe travels,
84FC35 "Ruff Diamond"
Duncan, Oklahoma
>Force Ten
>sure you
>heater. If
>motor aid
>Howdy, Rob.
>Thanks again,
>Liz
>1993 WLWb
>Hondo, TX
