Air compressor and "that hose"
12-26-2007, 09:40
Scott..Check out my thread on the WOO forum..I have a 1991 WLWB with an 8V92
and I just checked the same thing you are planning. With my coach I could see and touch the alternator and the compressor but did not have enough room to service them. In my coach there were two plates..the first was easily removed and allowed the visual but the second plate continued towards the back of the coach and would require removal of plumbing and disassembly of the bed to get at it. Let me know if yours is similiar and how you are going to handle it..Thanks, Jim Barone, fulltiming in Tubac, Arizona **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NC...0000000004) [Non-text portions of this message have been removed] |
12-26-2007, 11:19
This weekend, I am going to open up the hatch in the bedroom in an
effort to look at my air compressor and the associated hose that has been the topic of so much discussion around here. My questions is this: when I open the hatch up, where is the compressor? I have only had it open once, and that was briefly just to see if I could get it open. As I remeber, the exhaust pipe crosses just below it and the alternator is directly below. Can someone direct me the the compressor and the hose? Thanks Scott Forman 86 PT38, 8v92 Memphis |
12-26-2007, 11:24
Scott there are two hoses. Hopefully Curt Sprenger will chime in here soon
as he has done this job. Randy is in Bainbridge at his new house and might not be able to answer until later tonight. On 26/12/2007, Scott Forman <sforman@...> wrote: > > This weekend, I am going to open up the hatch in the bedroom in an > effort to look at my air compressor and the associated hose that has > been the topic of so much discussion around here. > > My questions is this: when I open the hatch up, where is the > compressor? I have only had it open once, and that was briefly just to > see if I could get it open. As I remeber, the exhaust pipe crosses > just below it and the alternator is directly below. Can someone direct > me the the compressor and the hose? > > Thanks > Scott Forman > 86 PT38, 8v92 > Memphis > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
12-26-2007, 14:59
On the 6v92, the air compressor is on the fwd passenger side of engine between
the Alt and exhaust. While you are in there, clean or replace the compressor's air filter. Good luck, Glenn Allen 1986 PT-40 Marietta, GA --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > This weekend, I am going to open up the hatch in the bedroom in an > effort to look at my air compressor and the associated hose that has > been the topic of so much discussion around here. > > My questions is this: when I open the hatch up, where is the > compressor? I have only had it open once, and that was briefly just to > see if I could get it open. As I remeber, the exhaust pipe crosses > just below it and the alternator is directly below. Can someone direct > me the the compressor and the hose? > > Thanks > Scott Forman > 86 PT38, 8v92 > Memphis > |
12-26-2007, 15:00
Scott,
Stick you head down in the hatch hole into the engine compartment The engine air compressor is just forward of the cross member. Air compressor forward hose (towards the front of the coach) runs to the curb side of the engine block and above the starter. The rear hose runs to the manifold or head on the curb side of the engine. Here is a link to a procedure I put together some time ago. Check section "D". Let me know if you have any questions. *http://tinyurl.com/3a628w* [Open in new window <http://tinyurl.com/3a628w>] On Dec 26, 2007 3:24 PM, Rob Robinson > Scott there are two hoses. Hopefully Curt Sprenger will chime in here > soon > as he has done this job. Randy is in Bainbridge at his new house and might > not be able to answer until later tonight. > > > On 26/12/2007, Scott Forman <sforman@... <sforman%40renasant.com>> > wrote: > > > > This weekend, I am going to open up the hatch in the bedroom in an > > effort to look at my air compressor and the associated hose that has > > been the topic of so much discussion around here. > > > > My questions is this: when I open the hatch up, where is the > > compressor? I have only had it open once, and that was briefly just to > > see if I could get it open. As I remeber, the exhaust pipe crosses > > just below it and the alternator is directly below. Can someone direct > > me the the compressor and the hose? > > > > Thanks > > Scott Forman > > 86 PT38, 8v92 > > Memphis > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > [Non-text portions of this message have been removed] > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
12-26-2007, 15:15
Thanks! This is great. I am hoping to God that I open up the hatch
and see that those hoses are fresh and recent like the others on the engine...but I am sure I will not be so lucky Scott --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > Scott, > > Stick you head down in the hatch hole into the engine compartment The engine > air compressor is just forward of the cross member. Air compressor forward > hose (towards the front of the coach) runs to the curb side of the engine > block and above the starter. The rear hose runs to the manifold or head on > the curb side of the engine. Here is a link to a procedure I put together > some time ago. Check section "D". Let me know if you have any questions. > > *http://tinyurl.com/3a628w* > [Open in new window <http://tinyurl.com/3a628w>] > > > On Dec 26, 2007 3:24 PM, Rob Robinson > > > Scott there are two hoses. Hopefully Curt Sprenger will chime in here > > soon > > as he has done this job. Randy is in Bainbridge at his new house and might > > not be able to answer until later tonight. > > > > > > On 26/12/2007, Scott Forman <sforman@... <sforman%40renasant.com>> > > wrote: > > > > > > This weekend, I am going to open up the hatch in the bedroom in an > > > effort to look at my air compressor and the associated hose that has > > > been the topic of so much discussion around here. > > > > > > My questions is this: when I open the hatch up, where is the > > > compressor? I have only had it open once, and that was briefly just to > > > see if I could get it open. As I remeber, the exhaust pipe crosses > > > just below it and the alternator is directly below. Can someone direct > > > me the the compressor and the hose? > > > > > > Thanks > > > Scott Forman > > > 86 PT38, 8v92 > > > Memphis > > > > > > > > > > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > > > [Non-text portions of this message have been removed] > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > > [Non-text portions of this message have been removed] > |
12-26-2007, 15:21
Mine only has one hatch that I can find. It is big enough to work
through. I have twin beds, so that probably makes it easier. Scott --- In WanderlodgeForum@yahoogroups.com, ciao70@... wrote: > > Scott..Check out my thread on the WOO forum..I have a 1991 WLWB with an 8V92 > and I just checked the same thing you are planning. With my coach I could > see and touch the alternator and the compressor but did not have enough room to > service them. In my coach there were two plates..the first was easily removed > and allowed the visual but the second plate continued towards the back of > the coach and would require removal of plumbing and disassembly of the bed to > get at it. Let me know if yours is similiar and how you are going to handle > it..Thanks, Jim Barone, fulltiming in Tubac, Arizona > > > > **************************************See AOL's top rated recipes > (http://food.aol.com/top-rated-recipes?NC...0000000004) > > > [Non-text portions of this message have been removed] > |
12-26-2007, 15:24
Scott,
Very possible you will be that lucky; would be great. Be sure both hoses are newer or get replaced. Good luck! On Dec 26, 2007 7:15 PM, Scott Forman <sforman@...> wrote: > Thanks! This is great. I am hoping to God that I open up the hatch > and see that those hoses are fresh and recent like the others on the > engine...but I am sure I will not be so lucky > > Scott > > --- In WanderlodgeForum@yahoogroups.com > "Curt Sprenger" > > > > > > Scott, > > > > Stick you head down in the hatch hole into the engine compartment > The engine > > air compressor is just forward of the cross member. Air compressor > forward > > hose (towards the front of the coach) runs to the curb side of the > engine > > block and above the starter. The rear hose runs to the manifold or > head on > > the curb side of the engine. Here is a link to a procedure I put > together > > some time ago. Check section "D". Let me know if you have any > questions. > > > > *http://tinyurl.com/3a628w* > > [Open in new window <http://tinyurl.com/3a628w>] > > > > > > On Dec 26, 2007 3:24 PM, Rob Robinson > > > > > Scott there are two hoses. Hopefully Curt Sprenger will chime > in here > > > soon > > > as he has done this job. Randy is in Bainbridge at his new house > and might > > > not be able to answer until later tonight. > > > > > > > > > On 26/12/2007, Scott Forman <sforman@... <sforman%40renasant.com>> > > > wrote: > > > > > > > > This weekend, I am going to open up the hatch in the bedroom in > an > > > > effort to look at my air compressor and the associated hose > that has > > > > been the topic of so much discussion around here. > > > > > > > > My questions is this: when I open the hatch up, where is the > > > > compressor? I have only had it open once, and that was briefly > just to > > > > see if I could get it open. As I remeber, the exhaust pipe > crosses > > > > just below it and the alternator is directly below. Can someone > direct > > > > me the the compressor and the hose? > > > > > > > > Thanks > > > > Scott Forman > > > > 86 PT38, 8v92 > > > > Memphis > > > > > > > > > > > > > > > > > > -- > > > Rob, Sue & Merlin Robinson > > > 94 WLWB > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > > > > [Non-text portions of this message have been removed] > > > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
12-26-2007, 15:46
Scott,
As I think about air compressor access...Someone on the sites cut a second access panel to gain better access to the air compressor. Hopefully they will chime in here, or point us to a doc. addressing the creation of the second access panel. On Dec 26, 2007 7:24 PM, Curt Sprenger > Scott, > > Very possible you will be that lucky; would be great. Be sure both hoses > are newer or get replaced. > > Good luck! > > > On Dec 26, 2007 7:15 PM, Scott Forman < sforman@...> wrote: > > > Thanks! This is great. I am hoping to God that I open up the hatch > > and see that those hoses are fresh and recent like the others on the > > engine...but I am sure I will not be so lucky > > > > Scott > > > > --- In WanderlodgeForum@yahoogroups.com > > "Curt Sprenger" > > > > > > > > > > Scott, > > > > > > Stick you head down in the hatch hole into the engine compartment > > The engine > > > air compressor is just forward of the cross member. Air compressor > > forward > > > hose (towards the front of the coach) runs to the curb side of the > > engine > > > block and above the starter. The rear hose runs to the manifold or > > head on > > > the curb side of the engine. Here is a link to a procedure I put > > together > > > some time ago. Check section "D". Let me know if you have any > > questions. > > > > > > *http://tinyurl.com/3a628w* > > > [Open in new window <http://tinyurl.com/3a628w>] > > > > > > > > > On Dec 26, 2007 3:24 PM, Rob Robinson > > > > > > > Scott there are two hoses. Hopefully Curt Sprenger will chime > > in here > > > > soon > > > > as he has done this job. Randy is in Bainbridge at his new house > > and might > > > > not be able to answer until later tonight. > > > > > > > > > > > > On 26/12/2007, Scott Forman <sforman@... <sforman%40renasant.com>> > > > > wrote: > > > > > > > > > > This weekend, I am going to open up the hatch in the bedroom in > > an > > > > > effort to look at my air compressor and the associated hose > > that has > > > > > been the topic of so much discussion around here. > > > > > > > > > > My questions is this: when I open the hatch up, where is the > > > > > compressor? I have only had it open once, and that was briefly > > just to > > > > > see if I could get it open. As I remeber, the exhaust pipe > > crosses > > > > > just below it and the alternator is directly below. Can someone > > direct > > > > > me the the compressor and the hose? > > > > > > > > > > Thanks > > > > > Scott Forman > > > > > 86 PT38, 8v92 > > > > > Memphis > > > > > > > > > > > > > > > > > > > > > > > -- > > > > Rob, Sue & Merlin Robinson > > > > 94 WLWB > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > -- > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, CA > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
12-26-2007, 16:05
Curt not sure if this is relevant but both Randy and I cut away some plywood
to provide greater access when we were working on our alternators. After removing the metal plate we found that we could cut away some of the plywood flooring closer to the passenger side outer wall. It was a square section approx 6" X 6" On 26/12/2007, Curt Sprenger > > Scott, > > As I think about air compressor access...Someone on the sites cut a second > access panel to gain better access to the air compressor. Hopefully they > will chime in here, or point us to a doc. addressing the creation of the > second access panel. > > On Dec 26, 2007 7:24 PM, Curt Sprenger > wrote: > > > Scott, > > > > Very possible you will be that lucky; would be great. Be sure both hoses > > are newer or get replaced. > > > > Good luck! > > > > > > On Dec 26, 2007 7:15 PM, Scott Forman < sforman@...<sforman%40renasant.com>> > wrote: > > > > > Thanks! This is great. I am hoping to God that I open up the hatch > > > and see that those hoses are fresh and recent like the others on the > > > engine...but I am sure I will not be so lucky > > > > > > Scott > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > "Curt Sprenger" > > > > > > > > > > > > > > Scott, > > > > > > > > Stick you head down in the hatch hole into the engine compartment > > > The engine > > > > air compressor is just forward of the cross member. Air compressor > > > forward > > > > hose (towards the front of the coach) runs to the curb side of the > > > engine > > > > block and above the starter. The rear hose runs to the manifold or > > > head on > > > > the curb side of the engine. Here is a link to a procedure I put > > > together > > > > some time ago. Check section "D". Let me know if you have any > > > questions. > > > > > > > > *http://tinyurl.com/3a628w* > > > > [Open in new window <http://tinyurl.com/3a628w>] > > > > > > > > > > > > On Dec 26, 2007 3:24 PM, Rob Robinson > > > > > > > > > Scott there are two hoses. Hopefully Curt Sprenger will chime > > > in here > > > > > soon > > > > > as he has done this job. Randy is in Bainbridge at his new house > > > and might > > > > > not be able to answer until later tonight. > > > > > > > > > > > > > > > On 26/12/2007, Scott Forman <sforman@... <sforman%40renasant.com>> > > > > > wrote: > > > > > > > > > > > > This weekend, I am going to open up the hatch in the bedroom in > > > an > > > > > > effort to look at my air compressor and the associated hose > > > that has > > > > > > been the topic of so much discussion around here. > > > > > > > > > > > > My questions is this: when I open the hatch up, where is the > > > > > > compressor? I have only had it open once, and that was briefly > > > just to > > > > > > see if I could get it open. As I remeber, the exhaust pipe > > > crosses > > > > > > just below it and the alternator is directly below. Can someone > > > direct > > > > > > me the the compressor and the hose? > > > > > > > > > > > > Thanks > > > > > > Scott Forman > > > > > > 86 PT38, 8v92 > > > > > > Memphis > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > > Rob, Sue & Merlin Robinson > > > > > 94 WLWB > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > Curt Sprenger > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > Anaheim Hills, CA > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
