Electric horns
05-16-2005, 07:31
Electric horns
My musical horns have quit working. Looking for suggestions on where to
begin the trouble shooting. I did locate the fuse and it is good. Steve Creger 1982 FC35 Littleton,Co. |
05-16-2005, 07:34
Electric horns
Check the speakers first. Carry a car-stereo speaker into the coach
and connect it to the speaker output of the amp (one channel at a time) to see if there is music output from the amp. It is usually the speakers. I believe that the '82 amp is in the forwardmost portion of the RH overhead. Someone with an '82 might be able to verify. Otherwise, hook to the speaker wires on the roof. - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "stevecreger" wrote: > My musical horns have quit working. Looking for suggestions on where to > begin the trouble shooting. I did locate the fuse and it is good. > > Steve Creger > 1982 FC35 > Littleton,Co. |
05-16-2005, 13:51
Electric horns
In my 1982 FC35 there are two amps in the front overhead and the main
computer in the passenger side overhead in the very front as Jeff suggests. I trashed mine since it was outmoded. I am installing a computer in the front that will handle both my GPS system, internet etc. It will also take the place of the musical horns. The tunes are already loaded into it and its fed to the two overhead amps and then to the horns on the top. Each tune is just a symbol on the desktop. thats about l#50 for me to do now. tom 1982 Fc35 Vernon Center,NY At 07:34 PM 5/16/2005 +0000, you wrote: >Check the speakers first. Carry a car-stereo speaker into the coach >and connect it to the speaker output of the amp (one channel at a >time) to see if there is music output from the amp. It is usually the >speakers. > >I believe that the '82 amp is in the forwardmost portion of the RH >overhead. Someone with an '82 might be able to verify. Otherwise, >hook to the speaker wires on the roof. > >- Jeff Miller >http://www.wanderlodge.net >http://www.millercoachworks.com > > >--- In WanderlodgeForum@yahoogroups.com, "stevecreger" >wrote: > > My musical horns have quit working. Looking for suggestions on >where to > > begin the trouble shooting. I did locate the fuse and it is good. > > > > Steve Creger > > 1982 FC35 > > Littleton,Co. > |
