Another compressor problem
12-30-2007, 07:06
John, on my previous coach, 84 35FC, the air dryer was located in the middle
of the coach just inboard of the steps. Ernie Ekberg 83PT40 Weatherford, Tx -- Ocala, Fla **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NC...0000000004) [Non-text portions of this message have been removed] |
12-30-2007, 07:32
John, I believe that the 77 vintage birds did not have an air dryer. They
started incorporating them in the early 80s models. You should have a spitter assembly attached to the bottom of your primary air tank. It spits air and oil from it on a low volume basis. Sometimes makes a mess. You also should have a valve at the bottom of all three air tanks that should be opened occasionally to drain any moisture and oil that accumulates in the tanks.(Also making a mess). Steve Anderson 79 FC 35 Currently wintering in Arizona In a message dated 12/30/2007 4:53:08 P.M. US Mountain Standard Time, jehdds@... writes: Scott, Where would the air dryer be? I have an little gizmo which I assumed was some kind of filter on the side of the compressor. Other then that I don't know what I am looking for. John Heckman central Pa 1973 FC > > If you have an air dryer, check the relief valve, sometimes they stick > open. Often of you cover the outlet on the bottom with the palm of > your hand with the engine running, it will fix itself for that trip. > If you find this happening, you need new relief valve. > > Scott Forman > 86 PT38 > Memphis > > --- In _WanderlodgeForum@WanderlodgeFWan_ (mailto:WanderlodgeForum@yahoogroups.com) , "bubblerboy64" > wrote: > > > > Upon trying to take the son-in-law for a turn in the bus I found that > > the compressor would not bring the air up to release the brakes. > > Checked and the belt is Ok and the compressors seems to be turning > Ok. > > Is there a solenoid or a switch which activates and deactivates the > > compressor. I get about 30lbs on the air gauge but no more. The only > > other clue is that when the compressor is running normally it makes > > enough noise that I can hear it and it is not doing that. Don't know > > beans about what I am dealing with but any help or suggestions as to > > what to look at or for would certainly be appreciated. > > > > John Heckman > > central Pa > > 1973 FC converted to 3208 CAT > > > **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NC...0000000004) [Non-text portions of this message have been removed] |
12-30-2007, 11:07
the compressor would not bring the air up to release the brakes. Checked and the belt is Ok and the compressors seems to be turning Ok. Is there a solenoid or a switch which activates and deactivates the compressor. I get about 30lbs on the air gauge but no more. The only other clue is that when the compressor is running normally it makes enough noise that I can hear it and it is not doing that. Don't know beans about what I am dealing with but any help or suggestions as to what to look at or for would certainly be appreciated. John Heckman central Pa 1973 FC converted to 3208 CAT |
12-30-2007, 11:15
open. Often of you cover the outlet on the bottom with the palm of your hand with the engine running, it will fix itself for that trip. If you find this happening, you need new relief valve. Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > Upon trying to take the son-in-law for a turn in the bus I found that > the compressor would not bring the air up to release the brakes. > Checked and the belt is Ok and the compressors seems to be turning Ok. > Is there a solenoid or a switch which activates and deactivates the > compressor. I get about 30lbs on the air gauge but no more. The only > other clue is that when the compressor is running normally it makes > enough noise that I can hear it and it is not doing that. Don't know > beans about what I am dealing with but any help or suggestions as to > what to look at or for would certainly be appreciated. > > John Heckman > central Pa > 1973 FC converted to 3208 CAT > |
12-30-2007, 11:52
assumed was some kind of filter on the side of the compressor. Other then that I don't know what I am looking for. John Heckman central Pa 1973 FC > > If you have an air dryer, check the relief valve, sometimes they stick > open. Often of you cover the outlet on the bottom with the palm of > your hand with the engine running, it will fix itself for that trip. > If you find this happening, you need new relief valve. > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > wrote: > > > > Upon trying to take the son-in-law for a turn in the bus I found that > > the compressor would not bring the air up to release the brakes. > > Checked and the belt is Ok and the compressors seems to be turning > Ok. > > Is there a solenoid or a switch which activates and deactivates the > > compressor. I get about 30lbs on the air gauge but no more. The only > > other clue is that when the compressor is running normally it makes > > enough noise that I can hear it and it is not doing that. Don't know > > beans about what I am dealing with but any help or suggestions as to > > what to look at or for would certainly be appreciated. > > > > John Heckman > > central Pa > > 1973 FC converted to 3208 CAT > > > |
12-30-2007, 12:19
Here's a nice booklet that fully describes how an air brake system
works: <http://www.gnb.ca/0276/vehicle/pdf/ab_manual-e.pdf> The air dryer is located between the "wet" and "dry" air systems. The compressor will provide air to the wet air reservoir -- it then passes through the air dryer to the dry air reservoir. Most BBs use a Bendix AD-9 system -- a Google search will find some photos. They look sort of like a big oil filter (but are attached to the air lines). If you're in cold weather, another common problem is for the step to be 'stuck' in a partially extended position, sometimes this leaves the air valve open and venting, keeping pressure from building up. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Dec 30, 2007, at 4:06 PM, erniecarpet@... wrote: > John, on my previous coach, 84 35FC, the air dryer was located in > the middle > of the coach just inboard of the steps. > > Ernie Ekberg > 83PT40 > Weatherford, Tx > -- Ocala, Fla > > > [Non-text portions of this message have been removed] |
12-30-2007, 13:20
Could be anywhere. On my 82 FC is was just about at the center
(length and width) of the underside. Your coach is older, it may not have one. The dryer is the thing that makes the "pssshh" sound as it spits air when the compressor reaches its governed PSI. Follow the sound. Scott --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > Scott, Where would the air dryer be? I have an little gizmo which I > assumed was some kind of filter on the side of the compressor. Other > then that I don't know what I am looking for. > John Heckman > central Pa > 1973 FC > > > > If you have an air dryer, check the relief valve, sometimes they > stick > > open. Often of you cover the outlet on the bottom with the palm of > > your hand with the engine running, it will fix itself for that > trip. > > If you find this happening, you need new relief valve. > > > > Scott Forman > > 86 PT38 > > Memphis > > > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > > wrote: > > > > > > Upon trying to take the son-in-law for a turn in the bus I found > that > > > the compressor would not bring the air up to release the brakes. > > > Checked and the belt is Ok and the compressors seems to be > turning > > Ok. > > > Is there a solenoid or a switch which activates and deactivates > the > > > compressor. I get about 30lbs on the air gauge but no more. The > only > > > other clue is that when the compressor is running normally it > makes > > > enough noise that I can hear it and it is not doing that. Don't > know > > > beans about what I am dealing with but any help or suggestions as > to > > > what to look at or for would certainly be appreciated. > > > > > > John Heckman > > > central Pa > > > 1973 FC converted to 3208 CAT > > > > > > |
12-30-2007, 13:35
I believe that older coaches (older than 83' mostly did not have a air
drier-- unless someone added one after the fact. My 81 FC-33SB did not have one, however my friends 83' had one from the factory. I'm sure others may chime in on this, but I do think it was a factory addition around 83. Stephen H 81 FC-33SB Former owner- now looker! Plant City, FL On Dec 30, 2007 8:20 PM, Scott Forman <sforman@...> wrote: > Could be anywhere. On my 82 FC is was just about at the center > (length and width) of the underside. Your coach is older, it may not > have one. The dryer is the thing that makes the "pssshh" sound as it > spits air when the compressor reaches its governed PSI. Follow the > sound. > > Scott > > > --- In WanderlodgeForum@yahoogroups.com > "bubblerboy64" > wrote: > > > > Scott, Where would the air dryer be? I have an little gizmo which > I > > assumed was some kind of filter on the side of the compressor. > Other > > then that I don't know what I am looking for. > > John Heckman > > central Pa > > 1973 FC > > > > > > If you have an air dryer, check the relief valve, sometimes they > > stick > > > open. Often of you cover the outlet on the bottom with the palm > of > > > your hand with the engine running, it will fix itself for that > > trip. > > > If you find this happening, you need new relief valve. > > > > > > Scott Forman > > > 86 PT38 > > > Memphis > > > > > > --- In WanderlodgeForum@yahoogroups.com > "bubblerboy64" > > > wrote: > > > > > > > > Upon trying to take the son-in-law for a turn in the bus I > found > > that > > > > the compressor would not bring the air up to release the > brakes. > > > > Checked and the belt is Ok and the compressors seems to be > > turning > > > Ok. > > > > Is there a solenoid or a switch which activates and deactivates > > the > > > > compressor. I get about 30lbs on the air gauge but no more. > The > > only > > > > other clue is that when the compressor is running normally it > > makes > > > > enough noise that I can hear it and it is not doing that. > Don't > > know > > > > beans about what I am dealing with but any help or suggestions > as > > to > > > > what to look at or for would certainly be appreciated. > > > > > > > > John Heckman > > > > central Pa > > > > 1973 FC converted to 3208 CAT > > > > > > > > > > > > [Non-text portions of this message have been removed] |
12-30-2007, 14:19
John,
The problem could also be the governor itself on the compressor, which is an inexpensive fix, try tapping on it with a hammer, sometimes they get a little moisture in there that in cold weather freezes, or in my case it was rust, so I just changed it. Make sure if you change it, to install a new one as they are only a few more dollars than a remanufactured governor. Check out this page on my web site for more information and the location of the governor itself on an FC model 'Bird. http://www.pbase.com/iamflagman/image/68481426 JOHN FINN 1982 FC35RB BLUEBIRD WANDERLODGE HOPKINS, SOUTH CAROLINA VISIT THE FINN'S INN EXPRESS REMODELING ADVENTURE AND TECH. TIPS http://www.pbase.com/image/24977457 I'M SO SLOW ON THE HILLS, THAT I GET TO SMELL THE FLOWERS AS I GO BY .....AND WATCH THEM GROW TOO!! REMEMBER 9/11 /////////////////////////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > Upon trying to take the son-in-law for a turn in the bus I found that > the compressor would not bring the air up to release the brakes. > Checked and the belt is Ok and the compressors seems to be turning Ok. > Is there a solenoid or a switch which activates and deactivates the > compressor. I get about 30lbs on the air gauge but no more. The only > other clue is that when the compressor is running normally it makes > enough noise that I can hear it and it is not doing that. Don't know > beans about what I am dealing with but any help or suggestions as to > what to look at or for would certainly be appreciated. > > John Heckman > central Pa > 1973 FC converted to 3208 CAT > |
12-30-2007, 15:38
I know my '78 does not have an air dryer. I can usually tell by the
sound if my compressor is running/working as opposed to bypassing. If yours is not working then I would suspect the governor. It is unlikely that the compressor would fail suddenly. Other problems may include broken/leaking air lines, failing pressure regulators, or other leaks in the system. Since the front and rear brake tanks should be independant, I would look for a leak in the primary/wet tank circuits. On my coach I found tons of oil sludge in the tanks and I suspect no one ever drained them. The sludge caused some of the inline regulators to stick and cause low pressure problems. Mine seemed to clear up with repeated attempts to charge the system. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "John" wrote: > > John, > > The problem could also be the governor itself on the compressor, > which is an inexpensive fix, try tapping on it with a hammer, > sometimes they get a little moisture in there that in cold weather > freezes, or in my case it was rust, so I just changed it. > > Make sure if you change it, to install a new one as they are only a > few more dollars than a remanufactured governor. Check out this page > on my web site for more information and the location of the governor > itself on an FC model 'Bird. > > http://www.pbase.com/iamflagman/image/68481426 > > JOHN FINN > 1982 FC35RB BLUEBIRD WANDERLODGE > HOPKINS, SOUTH CAROLINA > VISIT THE FINN'S INN EXPRESS REMODELING ADVENTURE AND TECH. TIPS > http://www.pbase.com/image/24977457 > I'M SO SLOW ON THE HILLS, > THAT I GET TO SMELL THE FLOWERS AS I GO BY > .....AND WATCH THEM GROW TOO!! > REMEMBER 9/11 > > > /////////////////////////////////////////////////////////////// > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > wrote: > > > > Upon trying to take the son-in-law for a turn in the bus I found > that > > the compressor would not bring the air up to release the brakes. > > Checked and the belt is Ok and the compressors seems to be turning > Ok. > > Is there a solenoid or a switch which activates and deactivates the > > compressor. I get about 30lbs on the air gauge but no more. The > only > > other clue is that when the compressor is running normally it makes > > enough noise that I can hear it and it is not doing that. Don't > know > > beans about what I am dealing with but any help or suggestions as > to > > what to look at or for would certainly be appreciated. > > > > John Heckman > > central Pa > > 1973 FC converted to 3208 CAT > > > |
