1985 PT-40 Radiator Question
12-31-2007, 13:34
This seems like a silly question, but here goes. I need to add
coolant and read the instructions. I had a leak in a hose that
required replacement and now need to add coolant to the system.
Does the engine use the same radiator as the one located in front of
the generator? I just assumed there would be a separate radiator but
guess not, correct?
Thanks.
Wayne C.
12-31-2007, 16:27
No, the radiator for the engine on a PT-40 is at the rear on the
drivers side. The fill is probably through a small door on the back
end of the coach above the engine access door.
By the way, please sign your posts with Name, Location and year &
Model coach.
Wanderlodge Forum Moderator.
> guess not, correct?
> Thanks.
> Wayne C.
12-31-2007, 16:37
Ron, thank you very much for the response. Any hints or helpful ideas
in adding fluid. I lost a lot of fluid when the hose busted so I'm
not sure exactly how much too add. I read the manual to bleed the
heater system, seems easy enough, but it's my first time.
v/r
Wayne Curles
San Diego, CA
1985 PT-40
--- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002"
> Model coach.
> > guess not, correct?
> > Thanks.
> > Wayne C.
01-01-2008, 02:16
Wayne,
I replaced the thermostats in the 6V92 last year. That procedure
required draining much of the anti-freeze.
When it came time to refill, I used a 4 foot step ladder and a helper.
You'll need a funnel with a flexible hose, 6 gallons of Ethyl Glycol
Concentrate, 6 gallons of Distilled Water and a bottle of Fleetguard
DCA-4 additive and a 6-pak of test strips.(go to the local big truck
store for the additive and test strips). You may need more antifreeze
and water, pends on how much is been drained.
May want to go ahead and drain whats left and refresh the system at
this time. If you are mechanically inclined, and you want to do
diligence/preventive maintenance and replace the thermostats and
water pump, if you have no record of such update.
Using a coat hanger or other stiff wire, configure the wire to hold
the funnel upright so you can use both hands to pour the antifreeze.
I bought gallons of concentrated ethyl glycol and gallons of
distilled water. Added a gallon of antifreeze then a gallon of
distilled water, then a gallon of antifreeze then a gallon of
distilled water, etc until full up to the radiator cap.
Then, with the winter/summer switch set to winter and the thermostat
for the chassis heat set as high as it goes, take 'er out for a ride.
Make sure you reach operating temp. If the engine alarm sounds, you
can be reasonably sure you'll need to add coolant when you get back.
When you get back home, allow cool down time. Pull the radiator cap
and stick a test strip in there and read it. You may need to and see
what your level looks like. Probably will need to add coolant.
Repeat the antifreeze/distilled water/take it for a drive/heat it
up/return for cool down and recheck level until you do not need to
add coolant anymore.
You're done.
Jay Darst
85PT40 6V92 with updated coolant/thermostats/water pump/hoses/clamps
00 Prevost Royale H345 FOR SALE Buy it Now $329k
91 Prevost Royale 40XL FOR SALE Buy it Now $129k
HPRCoach.com
HPRCars.com
Springfield/Sullivan, IL
ideas
> v/r
> Wayne Curles
> San Diego, CA
> 1985 PT-40
back
> > Model coach.
front of
radiator but
> > > guess not, correct?
> > > Thanks.
> > > Wayne C.
01-01-2008, 05:08
The engine radiator in a PT is on the left (street) side at the rear
of the coach. From the inside, you should be able to see a fan (with
a shroud around it) that pulls air through the radiator. The radiator
near the generator is for the generator only.
The fill for the radiator is in the center on the rear above the
engine compartment cover. It feeds into a surge tank. Usually there's
a small, round sight glass. The water level (minimum) is to the
center of the sight glass. (Too full will cause the coolant to
overflow when it heats up.)
Be sure you're using a coolant that's appropriate to the engine.
Check the Detroit Diesel recommendation for your engine.
It occurs to me that the hose -might- have been for the generator
rather than the engine. Where, exactly, was the hose you replaced?
(Of course, you should check the water level in the generator as
well. That's accomplished by removing the radiator cap and looking in.)
El Sobrante CA
aeonix1@...
> guess not, correct?
> Thanks.
> Wayne C.
01-01-2008, 06:32
Thanks Jay, very helpful.
Did you have to "bleed" the heater system as noted in the manual?
Also, do you turn all on all three heater chassis or will one suffice?
v/r
Wayne C.
San Diego, CA
1985 PT-40
--- In WanderlodgeForum@yahoogroups.com, "Jay Darst"
> Wayne,
helper.
Glycol
Fleetguard
truck
antifreeze
thermostat
ride.
see
> You're done.
> Jay Darst
> HPRCoach.com
> HPRCars.com
> ideas
I'm
> > v/r
> > Wayne Curles
> > San Diego, CA
> > 1985 PT-40
> back
> > > Model coach.
add
that
system.
> front of
> radiator but
> > > > guess not, correct?
> > > > Thanks.
> > > > Wayne C.
01-01-2008, 06:43
Thanks Pete.
The hose ran from the pump into the engine block....fairly easy to
reach. It had a 2.5" rip in it...didn't expect such a huge failure.
Sure, maybe a small hole from a 21 year old hose, but wow! I lost a
lot of fluid very quickly. I'm glad the engine alarm worked since it
was at night and I could not see all the smoke pouring out the back.
I did not noticed the surge tank and site glass...will have to look
for that when I add coolant back into the system to ensure I do not
overflow.
I read the BB manual and it said to use an antifreeze which contains
ethylene glycol. When I get back home I'll have a complete flush of
all fluids anyway, it's time for a complete refresh...just need to
get home by Sunday, which is 2,000 miles away!
v/r
Wayne C.
San Deigo, CA
1985 PT-40
rear
(with
radiator
there's
in.)
> Pete Masterson
> El Sobrante CA
> aeonix1@...
of
but
> > guess not, correct?
> > Thanks.
> > Wayne C.
01-01-2008, 10:39
The surge tank on the 8v92 may not have the sight glass. I looked at
some photos of older PT-'birds on the Vintage Birds web site, and I
could see (what I assume was) the surge tank just left of center at
the top of the engine compartment (with the cover raised). I didn't
see the sight glass, so I assume that there's an indicator tab just
inside the fill cap (as on many vehicles). (Overfilling the radiator
isn't a serious problem as excess coolant will simply exit through
the overflow tube -- but it does waste a bit of coolant.)
A tear, even quite small, can allow a _lot_ of coolant to escape,
since it's under several pounds of pressure in the system.
El Sobrante CA
aeonix1@...
On Jan 1, 2008, at 10:43 AM, curlesw wrote:
> Thanks Pete.
> overflow.
> v/r
> Wayne C.
> San Deigo, CA
> 1985 PT-40
> rear
> (with
> radiator
> there's
> in.)
>> Pete Masterson
>> El Sobrante CA
>> aeonix1@...
> of
> but
>>> guess not, correct?
>>> Thanks.
>>> Wayne C.
> Yahoo! Groups Links
01-01-2008, 10:44
Wayne,
< suffice?>>
By setting the winter/summer switch to winter, the anti freeze is
circulated to all the heaters.
The on/off switch at each unit enables the fan that blows air thru
the heater core. The Hi/Low switch controls the fan speed. Then the
thermostat on the wall labeled "Chasis Heat" controls all the fans.
Nope, never did any bleeding of the heater system.
Jay Darst
85PT40DD6V92MTB654CR
suffice?
> v/r
> Wayne C.
> San Diego, CA
> 1985 PT-40
> > Wayne,
> helper.
> Glycol
> Fleetguard
> truck
> antifreeze
at
hold
antifreeze.
> thermostat
> ride.
you
back.
cap
> see
to
> > You're done.
> > Jay Darst
pump/hoses/clamps
> > HPRCoach.com
> > HPRCars.com
helpful
> > ideas
> I'm
> > > v/r
> > > Wayne Curles
> > > San Diego, CA
> > > 1985 PT-40
> > back
year
> > > > Model coach.
> add
> that
> system.
> > front of
> > radiator but
> > > > > guess not, correct?
> > > > > Thanks.
> > > > > Wayne C.
01-01-2008, 10:54
My '86 8v92 PT38 does have a sight glass. Surge tank is at top left
(street side) of engine compartment with rear cover raised.
Scott Forman
86 PT38
Memphis
at
I
at
didn't
just
radiator
> Pete Masterson
> El Sobrante CA
> aeonix1@...
> > Thanks Pete.
failure.
lost a
since it
back.
look
not
> > overflow.
contains
of
> > v/r
> > Wayne C.
> > San Deigo, CA
> > 1985 PT-40
> > rear
> > (with
> > radiator
> > there's
replaced?
looking
> > in.)
> >> Pete Masterson
> >> El Sobrante CA
> >> aeonix1@
front
> > of
radiator
> > but
> >>> guess not, correct?
> >>> Thanks.
> >>> Wayne C.
> > Yahoo! Groups Links
