Furnace thermostat
01-04-2008, 07:01
Furnace thermostat
Greetings All:
The LP furnace in the bedroom runs for 2 minutes, heating normally, then cycles off for one minute, then repeats. I can find no wiper to vary the "heat anticipator" setting, although there is a scale molded into the body of the "Suburban" thermostat housing where I would expect it to be. The thermostat in the salon is the same, but that furnace does not short cycle. Any suggestions? Thanks-- M.R.Kane 1985 PT40 |
01-04-2008, 07:33
Furnace thermostat
I'm all ears. I get the same thing with my bedroom (AquaHot) heat.
Nothing in the thermostat to adjust the anticipation setting. I usually turn the thermostat down, up, or off to break the cycle. (An electric blanket has proved quite helpful when shore power is available.) Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Jan 4, 2008, at 11:01 AM, mrkane1952 wrote: > Greetings All: > > The LP furnace in the bedroom runs for 2 minutes, heating normally, > then cycles off for one minute, then repeats. I can find no wiper to > vary the "heat anticipator" setting, although there is a scale molded > into the body of the "Suburban" thermostat housing where I would > expect it to be. > > The thermostat in the salon is the same, but that furnace does not > short cycle. > > Any suggestions? > [Non-text portions of this message have been removed] |
