Now tag axle pressure
01-04-2008, 13:43
Scott,
What does your tag pressure gage read?
Jay Darst
85PT40
> "tag axle pressure reducing valve"
> Does this control tag ride height? Where is it? I think my tag is
> riding high despite the pressure gauge reading ok
> Scott Forman
> 86 PT38
> Memphis
> --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@>
> > Bird of the Week has been updated.
> > Today's example is what a dedicated owner can do. I normally do
not
> > post extra information on the Bird of the Week pictures, but this
> one
> > so impressed me with all the new owner's upgrading in such a short
> > time period, that I felt compelled to pass along some of the
> > information they sent in with the pictures.
> > From Glenn's picture submission: "We've had the bird about 6
months
> > and are the 3rd owners. I purchased it from an owner in Texas and
> > drove it home to Georgia. I'm in the process of getting the bus
> > reconditioned. I have replaced the hot water heater,
refrigerator,
> > front window, holding tank dump valves, battery cables, tag axle
> > pressure reducing valve, and air dryer. I have replaced the
seals
> in
> > the drive axle and the steer axle. On the steer axle, I have
> replaced
> > the wheel bearings, shoes, and drums. I have purchased 3 new
> Dometic
> > Penguin low profile A/Cs and a Magnum MS2812 inverter for my next
> > projects. Hopefully I will have them installed in a few months.
We
> > love to camp a lot and so I try to schedule my upgrades and
> > maintenance around our camping schedule."
> > Wow, what an impressive to-do list in such a short period.
Glenn,
> are
> > you retired, or when did you have time to camp? Hopefully you
will
> > document some of the upcoming projects and post step-by-step
> pictures
> > in the Photos section of the forum. I am personally interested in
> > knowing more about the A/C project; part numbers, thermostat
> changes,
> > wiring changes. Please keep us up-to-date on your projects.
> > Thanks to Glenn for his Bird of the Week submission!
> > Mike Bulriss
> > 1991 WB40 "Texas Minivan"
> > San Antonio, TX - back from South Padre, darn it!!
01-04-2008, 14:12
Half way between the 50 and 75 lines. I thought about it after I
typed the post, and the only basis I really have for that
being "normal" is the fact that it is what mine has always read. I
can't say I recall reading or hearing what it is supposed to be.
What is yours?
Scott
--- In WanderlodgeForum@yahoogroups.com, "Jay Darst"
> Scott,
> Jay Darst
> 85PT40
> --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@>
is
> > Scott Forman
> > 86 PT38
> > Memphis
do
> not
this
> > one
short
> months
> refrigerator,
> seals
> > in
> > replaced
> > Dometic
next
months.
> We
> Glenn,
> > are
> will
> > pictures
in
> > changes,
> > > Mike Bulriss
01-04-2008, 14:41
Scott,
my tag pressure agage reads 50psi. Seems to drive fine.
Axle weights are approx:
stear = 13,400 lbs
drive = 20,000 lbs
tag = 8,000 lbs
Thats full of fuel and water.
Gray and black empty.
Have you weighed each axle?
Jay Darst
85PT40
> What is yours?
> Scott
> > Scott,
> > Jay Darst
> > 85PT40
<sforman@>
tag
> is
> > > Scott Forman
> > > 86 PT38
> > > Memphis
> do
> > not
> this
> > > one
> short
> > months
Texas
> and
bus
> > refrigerator,
axle
> > seals
> > > in
> > > replaced
> > > Dometic
> next
> months.
> > We
> > Glenn,
> > > are
you
> > will
> > > pictures
interested
> in
> > > changes,
> > > > Mike Bulriss
01-04-2008, 14:49
I have not weighed.
> Scott,
> stear = 13,400 lbs
> drive = 20,000 lbs
> tag = 8,000 lbs
> Jay Darst
> 85PT40
I
> > What is yours?
> > Scott
> > wrote:
> > > Scott,
> > > Jay Darst
> > > 85PT40
> <sforman@>
> tag
> > is
> > > > Scott Forman
> > > > 86 PT38
> > > > Memphis
<mbulriss@>
normally
> > do
> > > not
but
> > this
> > > > one
a
> > short
6
> > > months
> Texas
> > and
> bus
> > > refrigerator,
> axle
> > > seals
> > > > in
have
> > > > replaced
new
> > > > Dometic
my
> > next
> > months.
> > > We
> > > Glenn,
> > > > are
> you
> > > will
step
> > > > pictures
> interested
> > in
thermostat
> > > > changes,
> > > > > Mike Bulriss
01-04-2008, 16:53
Jay, My 38'WB weighs more than your 40'. Tag pressure is 70.
Steer; 13060
Drive: 19460
Tag: 8940
Dan Williams
38/8V92
Jackson, MS
> stear = 13,400 lbs
> drive = 20,000 lbs
> tag = 8,000 lbs
> Jay Darst
> 85PT40
I
> > What is yours?
> > Scott
> > wrote:
> > > Scott,
> > > Jay Darst
> > > 85PT40
> <sforman@>
> tag
> > is
> > > > Scott Forman
> > > > 86 PT38
> > > > Memphis
<mbulriss@>
normally
> > do
> > > not
but
> > this
> > > > one
a
> > short
6
> > > months
> Texas
> > and
> bus
> > > refrigerator,
> axle
> > > seals
> > > > in
have
> > > > replaced
new
> > > > Dometic
my
> > next
> > months.
> > > We
> > > Glenn,
> > > > are
> you
> > > will
step
> > > > pictures
> interested
> > in
thermostat
> > > > changes,
> > > > > Mike Bulriss
01-04-2008, 17:01
Tag axle pressure is a factor to weight on the tag relative to the
pressure on the drive. Since the drive axle pressure is fixed and
not monitored via the dash, the tag pressure that proves even heat
across the six tires after a run is a safe bet.
When backing in a site or driving on uneven surfaces tag pressure
sudden increase may reveal that the drive axle has lost traction.
If rpm of the detroit is not responding with movement, rpm should be
kept down to minimize the sudden torque stress once the drive makes
traction once again.
Since dropping the air on the tag helps make tighter turns and gives
the bus safer traction in low speed areas, I think The gauge is more
or less an indicator that the tag bags are full or not.
the tag axle Wanderlodge is called "three axle tag". A three axle
truck or bus that has two drive axles connected by a driveshaft
between them is called "TwinScrew".
My tag reads 60 when full. when I dump it via the TAG dash
electric/air switch, tag gauge goes up to over 100. my thinking is
that the drive and tag valve are cross wired, and I am dumping the
drive.
What is the engineered reaction to dumping the suspension switch
ONLY ??? will that also dump the tag?
GregoryO'Connor
94ptRomolandCa
<sforman@...> wrote:
> I have not weighed.
> > Scott,
> > stear = 13,400 lbs
> > drive = 20,000 lbs
> > tag = 8,000 lbs
> > Jay Darst
> > 85PT40
<sforman@>
after I
read.
> I
be.
> > > What is yours?
> > > Scott
> > > wrote:
> > > > Scott,
> > > > Jay Darst
> > > > 85PT40
> > <sforman@>
my
> > tag
> > > is
> > > > > Scott Forman
> > > > > 86 PT38
> > > > > Memphis
> <mbulriss@>
> normally
> > > do
> > > > not
> but
> > > this
> > > > > one
such
> a
> > > short
about
> 6
> > > > months
> > Texas
> > > and
> the
> > bus
> > > > refrigerator,
tag
> > axle
> the
> > > > seals
> > > > > in
> have
> > > > > replaced
3
> new
> > > > > Dometic
for
> my
> > > next
> > > months.
> > > > We
period.
> > > > Glenn,
> > > > > are
Hopefully
> > you
> > > > will
> step
> > > > > pictures
> > interested
> > > in
> thermostat
> > > > > changes,
projects.
> > > > > > Mike Bulriss
01-04-2008, 17:27
Inflate suspension first, tag second. Dump tag first, suspension second.
If suspension pressure is low and dumping tag, the tag pressure will read
beyond normal.
Our tag reads 55 on the gauge, same as the blue book specifies.
> drive.
> GregoryO'Connor
> 94ptRomolandCa
> "Scott Forman"
> > I have not weighed.
> "Jay Darst"
> > wrote:
> > > Scott,
> > > stear = 13,400 lbs
> > > drive = 20,000 lbs
> > > tag = 8,000 lbs
> > > Jay Darst
> > > 85PT40
> > > --- In
> "Scott Forman"
> <sforman@>
> after I
> read.
> > I
> be.
> > > > What is yours?
> > > > Scott
> > > > --- In
> "Jay Darst"
> > > > wrote:
> > > > > Scott,
> > > > > Jay Darst
> > > > > 85PT40
> > > > > --- In
> "Scott Forman"
> > > <sforman@>
> my
> > > tag
> > > > is
> > > > > > Scott Forman
> > > > > > 86 PT38
> > > > > > Memphis
> > > > > > --- In
> "mbulriss"
> > <mbulriss@>
> > normally
> > > > do
> > > > > not
> > but
> > > > this
> > > > > > one
> such
> > a
> > > > short
> the
> about
> > 6
> > > > > months
> > > Texas
> > > > and
> > the
> > > bus
> > > > > refrigerator,
> tag
> > > axle
> > the
> > > > > seals
> > > > > > in
> > have
> > > > > > replaced
> 3
> > new
> > > > > > Dometic
> for
> > my
> > > > next
> > > > months.
> > > > > We
> and
> period.
> > > > > Glenn,
> > > > > > are
> Hopefully
> > > you
> > > > > will
> > step
> > > > > > pictures
> > > interested
> > > > in
> > thermostat
> > > > > > changes,
> projects.
> > > > > > > Mike Bulriss
Curt Sprenger
Anaheim Hills, CA
01-04-2008, 18:01
Repost with the correct subject....sorry
Scott,
I believe this is the way the rear air works for ride height, but I'm
sure someone on here can correct any mis-conceptions I have:
There are two ride height control valves in the rear that controls
the rear frame height by controlling the pressure to the drive axle
air bags. You can adjust the control height rod to change the height
of the rear, but this only affects the drive axle air bags. This
must be done on a level surface, and there are specs for the actual
height that should be measured when adjusting.
The tag axle air bag pressure is controlled by a pressure reducing
valve located on a cross member just behind the tag axle. This is an
adjustable valve. Conceptually, the tag axle should not be used to
control ride height, but should be used for load distribution. As
you increase pressure on the tag, the load will be removed from the
drive axle and shared by the front and tag axles. Too much pressure
in the tag can cause too much load on the front axle. Too little
pressure on the tag, can cause wheel lock-up during agressive braking
and also possibly overload the drive axle. So, depending on your
load distribution, the required tag air pressure will vary from coach
to coach.
The pneumatic diagram for my coach recommends a 40psi setting for my
tag. I think this is too little based on braking tests. I believe
45 to 50 psi seems to be better for me. I will be weighing the coach
soon and making final adjustments based on axle weight distribution.
I replaced my leaking Tag pressure reducing valve with one I ordered
from NAPA (they ordered from Bendix). My docs call for the RV-1
279926 40 psi. I ordered the RV-1 278247 50 psi version. They are
both adjustable so either one will work. NAPA has some "cloans", but
I don't recommend using them because the ports are arranged
differently and will require a plumbing change.
So, hopefully, I have all of this correct.
Glenn Allen
1986 PT-40
Marietta, GA
01-05-2008, 05:24
My tag gauge normally reads about 65# (as is specified in my blue
box). Dumping the tag axle causes the gauge to drop down to near zero
(after a few minutes). I always dump tag first, then main suspension
-- although sometimes in close succession, as when preparing to drop
the jacks in an RV park. I've never seen the tag pressure go up above
70 (sometimes, while underway, the gauge 'jiggles' between 60 and 70
-- from suspension movement, I presume).
I don't generally pay much attention to the tag pressure, except to
verify that it's come up during start up phase before a departure --
and occasionally, while on the road, I'll scan all the "minor"
instruments to see that they're in normal range. For example, exhaust
gas temperature is not much of an issue, except when climbing a long
grade. Pressure boost also is rarely of interest except climbing at
higher altitudes, etc. The top row of gauges get more regular
attention while on the road -- and I suppose they're positioned as
they are due to their relative importance. Since the tag pressure
gauge is in a hard to view spot at the bottom edge of the panel next
to the steering wheel post, it's position suggests relatively low
importance.
El Sobrante CA
aeonix1@...
> second.
> will read
> beyond normal.
>> drive.
>> GregoryO'Connor
>> 94ptRomolandCa
>> --- In WanderlodgeForum@yahoogroups.com >> 40yahoogroups.com>,
>> "Scott Forman"
>>> I have not weighed.
>>> --- In WanderlodgeForum@yahoogroups.com >>> 40yahoogroups.com>,
>> "Jay Darst"
>>> wrote:
>>>> Scott,
>>>> stear = 13,400 lbs
>>>> drive = 20,000 lbs
>>>> tag = 8,000 lbs
>>>> Jay Darst
>>>> 85PT40
>>>> --- In WanderlodgeForum@yahoogroups.com >>>> 40yahoogroups.com>,
>> "Scott Forman"
>> <sforman@>
>> after I
>> read.
>>> I
>> be.
>>>>> What is yours?
>>>>> Scott
>>>>> --- In WanderlodgeForum@yahoogroups.com >>>>> 40yahoogroups.com>,
>> "Jay Darst"
>>>>> wrote:
>>>>>> Scott,
>>>>>> Jay Darst
>>>>>> 85PT40
>>>>>> --- In WanderlodgeForum@yahoogroups.com >>>>>> 40yahoogroups.com>,
>> "Scott Forman"
>>>> <sforman@>
>> my
>>>> tag
>>>>> is
>>>>>>> Scott Forman
>>>>>>> 86 PT38
>>>>>>> Memphis
>>>>>>> --- In WanderlodgeForum@yahoogroups.com >>>>>>> 40yahoogroups.com>,
>> "mbulriss"
>>> <mbulriss@>
>>> normally
>>>>> do
>>>>>> not
>>> but
>>>>> this
>>>>>>> one
>> such
>>> a
>>>>> short
>> the
>> about
>>> 6
>>>>>> months
>>>> Texas
>>>>> and
>>> the
>>>> bus
>>>>>> refrigerator,
>> tag
>>>> axle
>>> the
>>>>>> seals
>>>>>>> in
>>> have
>>>>>>> replaced
>> 3
>>> new
>>>>>>> Dometic
>> for
>>> my
>>>>> next
>>>>> months.
>>>>>> We
>> and
>> period.
>>>>>> Glenn,
>>>>>>> are
>> Hopefully
>>>> you
>>>>>> will
>>> step
>>>>>>> pictures
>>>> interested
>>>>> in
>>> thermostat
>>>>>>> changes,
>> projects.
>>>>>>>> Mike Bulriss
> Curt Sprenger
> Anaheim Hills, CA
> Yahoo! Groups Links
01-05-2008, 05:33
You may be giving the designers more credit than they deserve. Otherwise it
means that on my coach tag pressure is very important, as it is top row just to
the right of center.
Don Bradner
90 PT40 "Blue Thunder"
Eureka, CA
>importance.
>Pete Masterson
>El Sobrante CA
>aeonix1@...
