Questions about low air
01-06-2008, 13:16
We were on the last few miles of our 4,000 mile trip yesterday and
home was just a few miles down the road when my "low air" light and buzzer decided to go off. We had just finished descending a 4,100+ mountain and all my gauges were perfect. I immediately checked all three air gauges and all three were well within the normal operating limits. I checked my brakes and all was fine but nervous given the situation. I continued slowly on and watched as the system increased pressure as it normally does once it gets too low. We were able to make it home just fine but the light and buzzer never went off, even when the system was clearly operating ok (i.e. the gauges indicating all was well). Once home, I turned the Bird off and walked around listening for leaks but could not find/hear anything. Today, I turned the Bird on and light and buzzer went off once the system was fully pressurized. I drove to storage and all was normal, go figure. As such, I am thoroughly confused and have a couple of questions. 1) Has anyone experienced a similar problem? 2) How long should a properly functioning system stay pressurized? After 12 hours of sitting, my system will require a few moments to fully pressurize once I start the Bird. Also, when driving on the highway for example, the system goes from full to low and then pump back up to full every 20-30 minutes. Is this normal? Thanks. Wayne C. San Diego, CA 1985 PT-40 |
01-06-2008, 13:34
It's not uncommon for debris to cause intermittent operational irregularities.
I have seen this more often in suspension, rather in brake operation, it's likely a piece of junk caused a temporary blockage of the sensor setting it off. MH ----- Original Message ----- From: curlesw To: WanderlodgeForum@yahoogroups.com Sent: Sunday, January 06, 2008 7:16 PM Subject: [WanderlodgeForum] Questions about low air We were on the last few miles of our 4,000 mile trip yesterday and home was just a few miles down the road when my "low air" light and buzzer decided to go off. We had just finished descending a 4,100+ mountain and all my gauges were perfect. I immediately checked all three air gauges and all three were well within the normal operating limits. I checked my brakes and all was fine but nervous given the situation. I continued slowly on and watched as the system increased pressure as it normally does once it gets too low. We were able to make it home just fine but the light and buzzer never went off, even when the system was clearly operating ok (i.e. the gauges indicating all was well). Once home, I turned the Bird off and walked around listening for leaks but could not find/hear anything. Today, I turned the Bird on and light and buzzer went off once the system was fully pressurized. I drove to storage and all was normal, go figure. As such, I am thoroughly confused and have a couple of questions. 1) Has anyone experienced a similar problem? 2) How long should a properly functioning system stay pressurized? After 12 hours of sitting, my system will require a few moments to fully pressurize once I start the Bird. Also, when driving on the highway for example, the system goes from full to low and then pump back up to full every 20-30 minutes. Is this normal? Thanks. Wayne C. San Diego, CA 1985 PT-40 [Non-text portions of this message have been removed] |
01-06-2008, 15:57
I agree with Mike. Have experienced this a couple times in 5 years.
On Jan 6, 2008 5:34 PM, Mike Hohnstein <MHOHNSTEIN@...> wrote: > It's not uncommon for debris to cause intermittent operational > irregularities. I have seen this more often in suspension, rather in brake > operation, it's likely a piece of junk caused a temporary blockage of the > sensor setting it off. > MH > > ----- Original Message ----- > From: curlesw > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, January 06, 2008 7:16 PM > Subject: [WanderlodgeForum] Questions about low air > > We were on the last few miles of our 4,000 mile trip yesterday and > home was just a few miles down the road when my "low air" light and > buzzer decided to go off. We had just finished descending a 4,100+ > mountain and all my gauges were perfect. I immediately checked all > three air gauges and all three were well within the normal operating > limits. I checked my brakes and all was fine but nervous given the > situation. I continued slowly on and watched as the system increased > pressure as it normally does once it gets too low. > > We were able to make it home just fine but the light and buzzer never > went off, even when the system was clearly operating ok (i.e. the > gauges indicating all was well). Once home, I turned the Bird off > and walked around listening for leaks but could not find/hear > anything. Today, I turned the Bird on and light and buzzer went off > once the system was fully pressurized. I drove to storage and all > was normal, go figure. As such, I am thoroughly confused and have a > couple of questions. > > 1) Has anyone experienced a similar problem? > > 2) How long should a properly functioning system stay pressurized? > After 12 hours of sitting, my system will require a few moments to > fully pressurize once I start the Bird. Also, when driving on the > highway for example, the system goes from full to low and then pump > back up to full every 20-30 minutes. Is this normal? > > Thanks. > > Wayne C. > San Diego, CA > 1985 PT-40 > > [Non-text portions of this message have been removed] > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
01-06-2008, 16:13
Mike has the most probable cause with debris in the line but I think
it is your Parkingbrake release valve. Some event removed too much air to make the alarm go off and it held open and exhausted pressure just under the buildup pressure of the compressor. when you set the park brake you release air from behind springs at the drive axle (double pumpkin maxicam). these springs are always trying to put the brakeshoes to the drum. Air pressure is required to compress the spring and push the shoe off the drum. So when you drive, air must be maintained in the lines and at-axle diaphrams. The parking brake is completly oppisite of the way service brakes work. To test the ParkValve, line, and diaphram , do the following Build up tanks to full pressure Chock the tires turn off the engine release the parking brake (set to drive) listen for leaks you will hear air pressureize the spring diaphrams. Then you should hear no more air passing the ParkBrakeValve. I put an ear to the yellow handle. It should maintain the tank balance of air pressure for an hour or so. As far as your leakdown it sounds like it is good but you should have someone in the trucking industry check it out. It is inexpensive to have a CHP checkover of all systems at a certified location. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "curlesw" wrote: > > We were on the last few miles of our 4,000 mile trip yesterday and > home was just a few miles down the road when my "low air" light and > buzzer decided to go off. We had just finished descending a 4,100+ > mountain and all my gauges were perfect. I immediately checked all > three air gauges and all three were well within the normal operating > limits. I checked my brakes and all was fine but nervous given the > situation. I continued slowly on and watched as the system increased > pressure as it normally does once it gets too low. > > We were able to make it home just fine but the light and buzzer never > went off, even when the system was clearly operating ok (i.e. the > gauges indicating all was well). Once home, I turned the Bird off > and walked around listening for leaks but could not find/hear > anything. Today, I turned the Bird on and light and buzzer went off > once the system was fully pressurized. I drove to storage and all > was normal, go figure. As such, I am thoroughly confused and have a > couple of questions. > > 1) Has anyone experienced a similar problem? > > 2) How long should a properly functioning system stay pressurized? > After 12 hours of sitting, my system will require a few moments to > fully pressurize once I start the Bird. Also, when driving on the > highway for example, the system goes from full to low and then pump > back up to full every 20-30 minutes. Is this normal? > > Thanks. > > Wayne C. > San Diego, CA > 1985 PT-40 > |
