Roof Trim
01-09-2008, 20:59
Roof Trim
Bill,
I performed this task last year on my coach. I am remembering the job
just a little differently than you describe. On my coach the aluminum drip trim
is below the awning above the windows. I did not remove this trim, simply
caulked the space between the coach and the drip trim on the upper side. (Some
areas the space was significant). I used a caulking product called Pro Flex
and was able to match the color somewhat closely. (Almond I believe)
I also caulked the awning to coach. For this I removed the awning from
the coach, removed the old foam/rubber strip that was between the awning and
the coach, installed a new strip of double backed foam tape between the awning
and coach and reinstalled the awning. After reinstalling, I caulked the
upper edge of the awning rail to coach joint. (I highly recommend that the
awning
removal is a two or three man job. When I did mine, I attempted this alone.
The awning tries to unravel and fortunately my wife came by the garage at an
opportune moment or I might still be hanging on out in the garage).
The paint did not "chip" away on my coach but the 79 coaches did not
have Imron paint on them. The Imron paint on your 88 coach might act
differently
than the alkaline based paint.
The result was satisfactory and helped the dripping rain from running
down the side of the coach. Un- fortunately in a heavy rain it still drips
through, albeit not nearly as much.
Steve Anderson
79 FC 35
In a message dated 1/10/2008 5:14:10 A.M. US Mountain Standard Time,
billpatty@... writes:
This is the time of year, when I do full Bird detailing. not a fun job!!
There is rain water leaking behind the trim that runs the full length
of the Bird above the awnings, on each side This is only an exterior
leak , but water runs behind the awnings , then down the windows.
Has anyone removed this trim and recaulked???H
Will the paint chip??
Does the awnings need to be removed???
What type of caulk is used???
It looks like windshield butyl. about 1/4 gap to fill.
Bill 88 FC Michigan
**************Start the year off right. Easy ways to stay in shape.
http://body.aol.com/fitness/winter-exerc...0000002489
01-10-2008, 00:13
Roof Trim
Has anyone removed this trim and recaulked????
Bill 88 FC Michigan
01-10-2008, 02:43
Roof Trim
Hi Bill:
I have re caulked several drip rails on Bird's. Yes there will be some
paint chipping, the Imron does not seems to adhere to the aluminium drip
rail trim as well as steel. Behind the screws that attach the rail over the
rub rail they cover, are small rubber gaskets, much the same idea as the
diamond plate on the top that sits on the rubber gaskets that the screws go
through to seal.
I use the grey putty tape and put 2 thicknesses in the grove on the back
made for caulk. There are 2 tools that come in very handy and works like a
charm, 1. a square caulk remover tool about $.89 at Ace and a screen roller
tool. I also found if I build a scaffold between 2 ladders, it makes the
job go so much easier. Anyway, with old caulk removed and new caulk
installed and a helper holding the far end of the rail, (most are in 2
pieces on PT's and end caps) then place the rail over the rub rails over
the windows and when you put the screws back in the grey putty will ooze
out and this is a good thing. I use the square tool to trim the ooze even
with the top of the rail then I use the roller screen tool and complete the
drip channel by rolling it into the drip rail and form a rain drip gutter.
It works great!!!
Then touch up the paint chips, (the chips are going to happen no matter how
careful you are.
Safe travels,
84FC35 "Ruff Diamond"
Duncan, Oklahoma
>Bill 88 FC Michigan
01-10-2008, 05:51
Roof Trim
Steve,
More proof, that no two Birds are alike.
Taking another closer look,
The four smaller window awnings are below the drip rail, The much
larger over the door awning in above the drip rail , I now understand
why you removed the awnings. This is a task, I was trying to avoid.
Good input about the Imron Paint.
It would be nice to solve this problem without removing the Awnings
or the drip rails.
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com, ebirder2000@... wrote:
> Bill,
the job
aluminum drip trim
simply
side. (Some
Pro Flex
believe)
awning from
awning and
between the awning
caulked the
that the awning
this alone.
garage at an
did not
act differently
running
still drips
> Steve Anderson
> 79 FC 35
Time,
job!!
length
exterior
> Bill 88 FC Michigan
shape.
> http://body.aol.com/fitness/winter-exercise?
NCID=aolcmp00300000002489
01-10-2008, 06:04
Roof Trim
Ralph,
The drip rail on our 88 FC is in two pieces each side. about 28ft
and about 6 ft. I now understand the need for a scaffold and a helper,
to remove and re-install the rail.
Is the screen roller, the tool used to replace the screening in a
door or window ?? it usually has a roller at each end???
Thanks again,
Bill 88 FC Michigan
> Hi Bill:
some
drip
over the
as the
screws go
> through to seal.
back
like a
screen roller
makes the
in 2
over
ooze
ooze even
complete the
gutter.
> It works great!!!
matter how
> careful you are.
> Safe travels,
> Duncan, Oklahoma
job!!
length
exterior
> >Bill 88 FC Michigan
01-10-2008, 06:14
Roof Trim
Bill:
Yes, that is the tool, the rounded roller works great. You can do both
sides in less than a day. Oh, for the gaskets behind the screws, I replace
them with a thick rubber gasket material I get at an auto parts store. This
is one of those jobs best done if the temp is in the 70's, besides the beer
tastes better! LOL
I use the same grey putty tape on the main awning rail and any roof work
like vents, A/C's and re seal the wiring V wedge covers. The hotter the sun
the tighter this stuff seals, un like foam rubber or silicone sealant.
Safe travels,
Duncan, Oklahoma
At 06:04 PM 1/10/2008 +0000, you wrote:
>Ralph,
>Thanks again,
>Bill 88 FC Michigan
> > Hi Bill:
>some
>drip
>over the
>as the
>screws go
> > through to seal.
>back
>like a
>screen roller
>makes the
>in 2
>over
>ooze
>ooze even
>complete the
>gutter.
> > It works great!!!
>matter how
> > careful you are.
> > Safe travels,
> > Duncan, Oklahoma
>job!!
>length
>exterior
> > >Bill 88 FC Michigan
01-10-2008, 07:04
Roof Trim
Thanks Ralph,
Just to confirm ,
We are talking about plumbers putty. Comes in a can , ribbon or rope
putty. Old timers used to for glazing the old type wood sash window
glass.
Bill 88 FC Michigan
> Bill:
both
replace
store. This
the beer
> tastes better! LOL
work
the sun
sealant.
> Safe travels,
> Duncan, Oklahoma
> >Ralph,
helper,
> >Thanks again,
> >Bill 88 FC Michigan
> > wrote:
> > > Hi Bill:
be
> >some
aluminium
> >drip
rail
> >over the
idea
> >as the
> >screws go
> > > through to seal.
> >back
works
> >like a
> >screen roller
> >makes the
caulk
are
> >in 2
rails
> >over
will
> >ooze
> >ooze even
> >complete the
drip
> >gutter.
> > > It works great!!!
> >matter how
> > > careful you are.
> > > Safe travels,
> > > Duncan, Oklahoma
fun
> >job!!
> >length
> >exterior
windows.
> > > >Bill 88 FC Michigan
01-10-2008, 07:20
Roof Trim
Ribbon; about 3/4 inch wide rolled up and separated with paper about $4.00
per roll give or take, you can get it in white as well. I put one strip or
thickness on the apply another then mount on the coach.
Safe travels,
Duncan, Oklahoma
At 07:04 PM 1/10/2008 +0000, you wrote:
>Thanks Ralph,
>Just to confirm ,
>glass.
>Bill 88 FC Michigan
> > Bill:
>both
>replace
>store. This
>the beer
> > tastes better! LOL
>work
>the sun
>sealant.
> > Safe travels,
> > Duncan, Oklahoma
> > >Ralph,
>helper,
> > >Thanks again,
> > >Bill 88 FC Michigan
> > > wrote:
> > > > Hi Bill:
>be
> > >some
>aluminium
> > >drip
>rail
> > >over the
>idea
> > >as the
>the
> > >screws go
> > > > through to seal.
>the
> > >back
>works
> > >like a
> > >screen roller
> > >makes the
>caulk
>are
> > >in 2
>rails
> > >over
>will
> > >ooze
> > >ooze even
> > >complete the
>drip
> > >gutter.
> > > > It works great!!!
> > >matter how
> > > > careful you are.
> > > > Safe travels,
> > > > Duncan, Oklahoma
>fun
> > >job!!
> > >length
> > >exterior
>windows.
> > > > >Bill 88 FC Michigan
01-10-2008, 07:37
Roof Trim
Thanks,
Bill 88 FC Michigan
about $4.00
strip or
> Safe travels,
> Duncan, Oklahoma
> >Thanks Ralph,
> >Just to confirm ,
rope
> >glass.
> >Bill 88 FC Michigan
> > wrote:
> > > Bill:
do
> >both
screws, I
> >replace
> >store. This
besides
> >the beer
> > > tastes better! LOL
roof
> >work
hotter
> >the sun
> >sealant.
> > > Safe travels,
> > > Duncan, Oklahoma
> > > >Ralph,
28ft
> >helper,
in a
> > > >Thanks again,
> > > >Bill 88 FC Michigan
> > > > wrote:
> > > > > Hi Bill:
will
> >be
> > > >some
> >aluminium
> > > >drip
> >rail
> > > >over the
> >idea
> > > >as the
that
> >the
> > > >screws go
> > > > > through to seal.
grove on
> >the
> > > >back
> >works
> > > >like a
a
> > > >screen roller
it
> > > >makes the
new
> >caulk
(most
> >are
> > > >in 2
rub
> >rails
> > > >over
putty
> >will
> > > >ooze
> > > >ooze even
> > > >complete the
rain
> >drip
> > > >gutter.
> > > > > It works great!!!
happen no
> > > >matter how
> > > > > careful you are.
> > > > > Safe travels,
> > > > > Duncan, Oklahoma
not a
> >fun
> > > >job!!
full
> > > >length
> > > >exterior
> >windows.
> > > > > >Bill 88 FC Michigan
