Screen Door Closer Pulleys Needed
01-10-2008, 15:35
The screen door in my 84FC is closed with a spring loaded cable that
runs through 2 small pulleys. The pulleys are small...about 3/4" or
maybe 1/2" diameter. One pulley is worn through, so I need to come up
with a replacement. Where would I find one?
David Hollis 84FC35 Springfield,IL
01-10-2008, 16:31
Just a thought, how about http://www.westmarine.com and look at sailboat hardware.
dthollis1961 wrote: The screen door in my 84FC is
Yahoo! Groups Links
Wallace Craig
95 WLWB 42
Azle, Texas
01-12-2008, 11:21
I found wheels that worked at Lowe's or HD. In the sliding screen door area.
('81FC prev.)
Sent: Thursday, January 10, 2008 9:31 PM
Subject: Re: [WanderlodgeForum] Screen Door Closer Pulleys Needed
Just a thought, how about www.westmarine.com and look at sailboat hardware.
dthollis1961 <"dthollis@sbcglobal.net"> wrote: The screen door in my 84FC is closed with a spring loaded cable that
Yahoo! Groups Links
Wallace Craig
95 WLWB 42
Azle, Texas
01-12-2008, 12:07
IF and when you find the pulley wheels , Try using blind cord,
instead of steel cable, the cable chews up the little wheels.
Bill 88 FC Michigan
up
01-12-2008, 17:39
When we had the '81FC, I rebuilt the spring thing with bungee cord. Getting the right length was a little tricky but it worked good. Naturally, bigger wheels are needed.
Sent: Saturday, January 12, 2008 5:07 PM
Subject: [WanderlodgeForum] Re: Screen Door Closer Pulleys Needed
Bill 88 FC Michigan
--- In "WanderlodgeForum@yahoogroups.com", "dthollis1961" .>
up
01-13-2008, 09:06
Thanks everyone for ideas. I picked up a door roller the other day
that has a bearing in it, it's larger diameter though. I looked
really hard at brass cabinet door knobs...most of them have about the
same size pulley built into them.
--- In WanderlodgeForum@yahoogroups.com, "Richard Hayden"
> From: pattypape
> To:
WanderlodgeForum@yahoogroups.com om>
> Bill 88 FC Michigan
> --- In
WanderlodgeForum@yahoogroups.com om>, "dthollis1961"
that
3/4" or
come
> up
