8v92 6v92 two stroke basics
01-11-2008, 07:06
Thanks, Greg, for that post.
Ernie Ekberg 83PT40 Weatherford, Tx --no rust on my bus--cause it leaks!!!! **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exerc...0000002489 [Non-text portions of this message have been removed] |
01-11-2008, 11:48
The 92-series Detroits are two-cycle engines.
All current production diesels are 4-cycle. Detroit stopped production on the 2-strokers due to EPA requirements - and for no other reason. They simply would not meed EPA emissions requirements on or off-road, no matter what they tried - and try mightily they did, with their DDEC and then DDEC-II (electronic control) systems. Ultimately, they were forced into 4-stroke production. It is true that modern electronic engines get better fuel efficiency. However, there is a LOT to be said for a basic engine design that goes back to WWII! I have 6V92s on my boat (two of 'em.) Detroit's basic design was simplicity itself, and ingenious. The supercharger on these engines is necessary; they will not run without them. There is no intake valve system at all. The valves are all for exhaust; as the piston moves down on a power stroke, the exhaust valves open and at the same time the piston uncovers a port, much like a 2-stroke outboard motor, that leads to an airbox that is pressurized by the blower. The clean air forces out the exhaust. When the piston moves back upward the valves close and the ports are covered; compression occurs, and fuel is injected at the appropriate time. Injection is performed by a cam-driven unit injector. The design is extremely simple - ingenious, really. The emissions problem comes from being unable to perfectly scavenge the exhaust. However, these engines tend to run very low EGTs compared to 4-stroke turbodiesels due to the overabundance of air that flows through them on a given power cycle. The nice thing about Detroits is that there is no high-pressure injection pump or electronics. They will run, once started, so long as they have fuel and compression. You can also replace the entire fuel system (the injectors) for about $100 a hole and the low pressure fuel lift pump for a couple hundred bucks - these are unit injector engines. With under $200 worth of special tools you can keep a Detroit running in tip-top shape for a loooong time, and properly maintained they are great motors. They have a reputation (somewhat earned) as oil leakers, which is due to the fact that Detroit made the blocks so they could be "doubled" - thus, you have 6V92s, 8V92s, 12V92s (two 6V92s end-to-end) and 16V92s (two 8V92s end to end!) This, however, means there are oil ports and such on the ends of the blocks that have plugs in them and thus they tend to leak oil.... The other thing to be aware of is that Detroits are quite inexpensive to get parts for. A cylinder kit, for example, is about $600 - that's the liner, piston, con-rod, rings, etc - the whole shot. One new hole, coming up. So for about $5k in parts you can do a complete kit replacement, and it can be done "in-frame" - without pulling the motor. Detroits have no glow plugs and "off the shelf" no starting assist. They are ENTIRELY dependant on engine compression to start. They also require (not recommend, REQUIRE) straight weight 40 grade Cx-II oil. Multigrade oils are strictly forbidden due to the high shear strength required by the injector followers - you WILL destroy cams if you run a 15W40 in them, for example, and you'll also get incessant low oil pressure warnings and probably a spun main to go with it. Unlike "modern" diesels its not uncommon (nor a problem) to have oil pressure readings as low as 10psi at idle when fully warmed up! Normal oil pressure at power (1800 rpmish) is in the 45-50psi range though, just like modern engines. What this means is that in cold weather you need STOUT batteries or you will not be able to roll them over at a high enough RPM to get 'em to light. Block heaters are strongly recommended for the winter months. Ether is very dangerous to use on these engines; I know people who have and do, but my recommendation is "never" on a Detroit. The nemesis on the 92 Series Detroits is overheating. This is a wet liner design with elastomer (O-ring) seals at the top and bottom of the cylinder liner. If you overheat these engines, even just a bit, the liner seals will be compromised. The result will be oil to cooling system leaks, and if not caught very quickly, damage to the mains or even worse, a spun main and damaged crank. Cooling system maintenance is THE big deal on these motors. Keep them running cool and all is well. Let them get hot and you will be rebuilding them. Also, later versions of these engines in "turbo" trim used aftercoolers, which are under the blower. That needs to be kept clean; getting to it requires removing the blower, which requires disturbing the governor and fuel rack. Its not a tough job, but it is a pain in the butt. Thus, its important to avoid exhaust leaks and use a good air cleaner so that becomes an infrequent problem rather than a frequent one. Finally, there is the matter of airbox drains. The airbox on a Detroit is where the blower "accumulates" the charge for scavenging and the new combustion cycle. The blower seals, as the blower ages, and turbo seals will eventually leak small amounts of oil, and the compression and then cooling of the air charge causes water to condense. The airbox drains allow this accumulated crud out of the airbox instead of having it sucked into the cylinders where it will cause abnormal wear. On turbo motors there are check valves located at each drain; these must work properly. If they stick open or closed its bad news; many people neglect these service items. They should be pulled and cleaned at every oil change, and if you have motors where Detroit routed them back to the oil pan (they did on some motors, as the EPA had a kitten about the original design which just allowed the slop to go onto the road) you will do your engine a huge favor by removing that and routing them to a "crap can" that you then empty once in a while (at oil change intervals is a good choice.) I'm very much "up" on the 92-series engines, since I own two and maintain them myself. Set up for reasonable power levels (500HP from an 8V92TA is reasonable) and proper maintenance they provide extraordinarily good service. The 8V89TA CAN be "hot-rodded" to as far as 750HP quite cheaply just by changing injectors and a few other things - don't be tempted, as the service life in that configuration can be as short as 1500 hours or less between overhauls! The DDEC and DDEC-II versions of these engines replace the mechanical fuel rack with electronic control of the injectors and a bunch of sensors in an attempt to get cleaner and more fuel- efficient operation from them. Its mostly successful, but now you're into the computer-controlled realm and simple mechanical maintenance procedures go out the window. If I was going to own a Detroit-powered coach, I'd want one with mechanical injection - if I'm gonna buy an electronic engine, I want one of the new design ones, as if I'm gonna get the warts I want the benefits too. With a handful of parts and a few tools on board I can fix these things by the side of the road if necessary so long as I haven't spun a main or something equally catastrophic - something you simply won't be doing with "today's technology". Repost form JimS GregoryO'Connor 94ptRomolandCa |
01-11-2008, 12:06
Don, Nice to see you and your wife in Riverside today. Your
electronics are quite impressive. The size of the dish make your bus look like a VW Camper. You missed a great lunch even though Tim, MontyH, DerekH, and I were asked to leave the restaurant befor the desert cart was shown. the start of this thread is a repost of info forum member jimS posted on irv2. Below is a snip I refered to about slober path maintenance. I didnt want to hang around in fear that the CCW tech would take the time to answer my question on your dime. This may be a good question to pose to CCW in Q as they see V92's with major miles. There were pics of Brian???? 94ish pt someplace with major blower box sludge oil repair. I always wondered how to avoid the buildup??????? > these engines in "turbo" trim used > aftercoolers, which are under the blower. That needs to be kept > clean; getting to it requires removing the blower, which requires > disturbing the governor and fuel rack. Its not a tough job, but it > is a pain in the butt. Thus, its important to avoid exhaust leaks > and use a good air cleaner so that becomes an infrequent problem > rather than a frequent one. > > Finally, there is the matter of airbox drains. The airbox on a > Detroit is where the blower "accumulates" the charge for scavenging > and the new combustion cycle. The blower seals, as the blower ages, > and turbo seals will eventually leak small amounts of oil, and the > compression and then cooling of the air charge causes water to > condense. The airbox drains allow this accumulated crud out of the > airbox instead of having it sucked into the cylinders where it will > cause abnormal wear. On turbo motors there are check valves located > at each drain; these must work properly. If they stick open or > closed its bad news; many people neglect these service items. They > should be pulled and cleaned at every oil change, and if you have > motors where Detroit routed them back to the oil pan (they did on > some motors, as the EPA had a kitten about the original design which > just allowed the slop to go onto the road) you will do your engine a > huge favor by removing that and routing them to a "crap can" that > you then empty once in a while (at oil change intervals is a good > choice.) > > GregoryO'Connor > 94ptRomolandCa > |
01-11-2008, 12:17
Ernie, I always wondered how much of a leak is necessary to let you
know that the scavangers are expelling debris. I get little drip after a run. this article and the pics ???? kinda concern me. Now I wish my bus leaked oil GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Thanks, Greg, for that post. > > Ernie Ekberg > 83PT40 > Weatherford, Tx > --no rust on my bus--cause it leaks!!!! > > > > **************Start the year off right. Easy ways to stay in shape. > http://body.aol.com/fitness/winter-exerc...0000002489 > > > [Non-text portions of this message have been removed] > |
01-11-2008, 12:26
Greg I get a fair amount of oil globs on my toad. You might not see it on
your Hummer as it is taller than my Civic. Put something on the ends of the slobber tubes that will catch the globs. Maybe just several layers of rag wrapped over the tube ends or plastic water bottles (vented) would prove how much you're expelling. Your run to Quartzite should show how much slobber you are getting rid of. On 11/01/2008, Gregory OConnor > > Ernie, I always wondered how much of a leak is necessary to let you > know that the scavangers are expelling debris. I get little drip after > a run. this article and the pics ???? kinda concern me. > > Now I wish my bus leaked oil > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com > erniecarpet@... wrote: > > > > Thanks, Greg, for that post. > > > > Ernie Ekberg > > 83PT40 > > Weatherford, Tx > > --no rust on my bus--cause it leaks!!!! > > > > > > > > **************Start the year off right. Easy ways to stay in > shape. > > http://body.aol.com/fitness/winter-exerc...0000002489 > > > > > > [Non-text portions of this message have been removed] > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
01-12-2008, 04:18
Thanks Greg,
That was very enlightening. One question to ponder? My 8V92 in my Bird consistently shows oil temp above 240 and most nearly 300. I have done an inframe overhaul which included a new radiator and changed the thermostats so that the electric fan would switch on lower. All to no avail. The only way to keep the temp anywhere near normal is to run the fan. I was told by Detroit that as long as my water temp stayed OK that I should not worry, but I can't help but to keep my eyes on oil temp most of the time. One mechanic Even said that the temp sensor was in the wrong place. Thanks for any info anyone has. Tommy Standard 93 40'WBWL (for sale incidentally) [Non-text portions of this message have been removed] |
01-12-2008, 05:17
Tommy my oil temp reads high too. As Greg once said....."the oil temp guage
is a good spot for a round STP sticker". My water temps are always good and the highest I ever see is 201 on my VMSPC guage On 12/01/2008, Tommy Standard > > Thanks Greg, > > That was very enlightening. One question to ponder? My 8V92 in my Bird > consistently shows oil temp above 240 and most nearly 300. I have done an > inframe overhaul which included a new radiator and changed the thermostats > so that the electric fan would switch on lower. All to no avail. The only > way to keep the temp anywhere near normal is to run the fan. > I was told by Detroit that as long as my water temp stayed OK that I > should not worry, but I can't help but to keep my eyes on oil temp most of > the time. One mechanic Even said that the temp sensor was in the wrong > place. > Thanks for any info anyone has. > > Tommy Standard > 93 40'WBWL (for sale incidentally) > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
01-12-2008, 12:08
Tommy: When you said you had changed thermostats to turn on fan
sooner, the fan is controlled by the Alarmstat. Did you actually change the thermostats? There are two of them. You can get them at 180 degrees or 170 degrees. You may also have a faulty sending unit or guage. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, Tommy Standard > > Thanks Greg, > > That was very enlightening. One question to ponder? My 8V92 in my Bird consistently shows oil temp above 240 and most nearly 300. I have done an inframe overhaul which included a new radiator and changed the thermostats so that the electric fan would switch on lower. All to no avail. The only way to keep the temp anywhere near normal is to run the fan. > I was told by Detroit that as long as my water temp stayed OK that I should not worry, but I can't help but to keep my eyes on oil temp most of the time. One mechanic Even said that the temp sensor was in the wrong place. > Thanks for any info anyone has. > > Tommy Standard > 93 40'WBWL (for sale incidentally) > > > [Non-text portions of this message have been removed] > |
