Advice regarding air leak on my 77FC35
01-13-2008, 01:15
Sounds like the air governor is shot. That's an easy 20 dollar fix. Air governor is on or beside the air compressor. It happened to my on my FC
Ernie Ekberg 83PT40 Weatherford, Tx Start the year off right. Easy ways to stay in shape in the new year. |
01-13-2008, 05:10
Hello All,
I have an air leak which I think is coming from the water drain valve or similar on my 77FC35. Please see http://www.hetzel.org/P1010012.JPG for a picture of the problem spot. Any advice as to the identity of the leaking part and the best way to fix the problem would be greatly appreciated. The coach has been parked in front of my house since it's last trip from which we returned on 12/24, and was last started and run for an hour about a week ago, at which time this problem was not present. We did have a quite hard freeze since then, down to about 12F. Best Regards and thanks in advance for any help/advice, Dorn Hetzel 77FC35 Hogansville, GA |
01-13-2008, 05:41
Spitter valve for draining the air tanks???
--- In WanderlodgeForum@yahoogroups.com, "Dorn Hetzel" wrote: > > Hello All, > > I have an air leak which I think is coming from the water drain valve or > similar on my 77FC35. > > Please see http://www.hetzel.org/P1010012.JPG for a picture of the problem > spot. > > Any advice as to the identity of the leaking part and the best way to fix > the problem would be greatly appreciated. > > The coach has been parked in front of my house since it's last trip from > which we returned on 12/24, and was last started and run for an hour about a > week ago, at which time this problem was not present. We did have a quite > hard freeze since then, down to about 12F. > > Best Regards and thanks in advance for any help/advice, > > Dorn Hetzel > 77FC35 > Hogansville, GA > |
01-13-2008, 05:45
I think so, but then I don't really know for sure. In any case, it's "spitting" constantly at this point and I can't get air pressure over 30psi or so...
On Jan 13, 2008 12:41 PM, Stephen Birtles <
"cape0001@hotmail.com"> wrote:
01-13-2008, 05:56
Winterizing blow out valve??? the valve to use Cat compressor to blow
out the pipes for winter storage??? GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Dorn Hetzel" wrote: > > Hello All, > > I have an air leak which I think is coming from the water drain valve or > similar on my 77FC35. > > Please see http://www.hetzel.org/P1010012.JPG for a picture of the problem > spot. > > Any advice as to the identity of the leaking part and the best way to fix > the problem would be greatly appreciated. > > The coach has been parked in front of my house since it's last trip from > which we returned on 12/24, and was last started and run for an hour about a > week ago, at which time this problem was not present. We did have a quite > hard freeze since then, down to about 12F. > > Best Regards and thanks in advance for any help/advice, > > Dorn Hetzel > 77FC35 > Hogansville, GA > |
01-13-2008, 06:34
It could also be a spitter valve if it under the air dryer or the air
tank. If itis real cold you could have moisture in the tank & be frozen Don Spithaler 89 SP 36' Butler, PA Posting from the Birds Nest On Jan 13, 2008 1:15 PM, > > > > > Sounds like the air governor is shot. That's an easy 20 dollar fix. Air > governor is on or beside the air compressor. It happened to my on my FC > > Ernie Ekberg > 83PT40 > Weatherford, Tx > Sounds like the air governor is shot. That's an easy 20 dollar fix. Air > governor is on or beside the air compressor. It happened to my on my FC > > Ernie Ekberg > 83PT40 > Weatherford, Tx > > > ________________________________ > Start the year off right. Easy ways to stay in shape in the new year. > > |
01-13-2008, 07:03
try giving it rap with a hammer on the main body to see if it will
seal then change it out to a manual valve or a new spitter Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Dorn Hetzel" wrote: > > I think so, but then I don't really know for sure. In any case, it's > "spitting" constantly at this point and I can't get air pressure over 30psi > or so... > > On Jan 13, 2008 12:41 PM, Stephen Birtles > > > Spitter valve for draining the air tanks??? > > > > --- In WanderlodgeForum@yahoogroups.com > > "Dorn Hetzel" > > > > wrote: > > > > > > Hello All, > > > > > > I have an air leak which I think is coming from the water drain valve or > > > similar on my 77FC35. > > > > > > Please see http://www.hetzel.org/P1010012.JPG for a picture of the > > problem > > > spot. > > > > > > Any advice as to the identity of the leaking part and the best way > > to fix > > > the problem would be greatly appreciated. > > > > > > The coach has been parked in front of my house since it's last trip from > > > which we returned on 12/24, and was last started and run for an hour > > about a > > > week ago, at which time this problem was not present. We did have a > > quite > > > hard freeze since then, down to about 12F. > > > > > > Best Regards and thanks in advance for any help/advice, > > > > > > Dorn Hetzel > > > 77FC35 > > > Hogansville, GA > > > > > > > > > > |
01-13-2008, 08:36
It definitely appears to be connected to the bottom of the air tank, not the compressor.
On Jan 13, 2008 1:15 PM, <"erniecarpet@aol.com"> wrote:
01-13-2008, 08:58
Go here to find the valve that is leaking air.
http://www.bendix.com/en-us/Pages/default.aspx On Jan 13, 2008 12:36 PM, Dorn Hetzel <
"dhetzel@gmail.com"> wrote:
01-13-2008, 09:11
Mine did the same on my81-not as bad though.
Itook it off took itapart at the bench, cleaned all the old dried oil and goo inside, worked like new.
Stephen H
Former 81 FC-33SB
Plant City, FL
On Jan 13, 2008 3:58 PM, Curt Sprenger <"curtsprenger@gmail.com"> wrote:
