TV Removal 1994pt
01-13-2008, 09:56
TV Removal 1994pt
The TV above the cockpit in the 94, 93 PT is easy to remove. first
step is to remove the wood buttons on the TV wood facia and unscrew
the 5 inch long philips #2 screws. the facia will lift off in one
piece.
the TV is mounted in a ply wood box prior to install at the factory
so you more or less simply remove the tv box. I removed all the
contents of the surrounding cabinets then removed 2 phillips wood
screws from the ajoining wall. It is hard to see the screws in the
grey felt but there were only two at each ajoining cabinet.
I hope ya'all can lift it out easy
GregoryO'Connor
94ptRomolandCa
