1985 TV antenna lifter motor
01-13-2008, 09:23
when my antenna comes down, it will do the chatter routine, also.
Ernie Ekberg 83PT40 Weatherford, Tx Start the year off right. Easy ways to stay in shape in the new year. |
01-13-2008, 12:46
Greetings All:
I wanted to watch the play-offs in HD via off-the-air digital broadcasts from the local stations, but the TV antenna lifter fails to raise the antenna on my 1985 PT40. The motor makes "slipping clutch" noises when run in either the "raise" or "lower" modes. After removing the extension assembly, it was possible to use the motor to raise the stubs to allow access to the (eighteen!!) cover screws, each of which required an impact driver to loosen. The lifter consists of a single assembly integrating motor and gear train. The only mark is a sticker "Warner Electric." There is a micro-switch positioned such that it probably was intended to open the circuit, stopping the motor when the antenna was completely retracted. However, the usual mode of operation during my ownership has been to raise or lower the antenna until slipping is heard. (This is a "tock-tock-tock" sound.) Anyone have any experience with R/R on this unit? Thanks-- M.R.Kane 1985 PT40 currently San Marcos, TX PS: I seem to be in one of those phases: on the last trip down from the roof, the plastic step-stool I've been using for some time shattered to pieces. Had a good grip on the ladder, so no harm. Managed to short out the power leads for the co-pilot seat by pinching them in the swivel. Symptom was repeated tripping of a DC circuit breaker in the curb-side forward load center. Troubleshooting was unusual, as several wires of different colors were all numbered "10." Last week discovered an inoperative slack adjuster on one side of the drive axle, which had existed for some time judging from the different wear on the brake shoes. Properly adjusted brakes work so much better! And the previous week, the 50 A. receptacle on the coach shorted out (at 1:08 A.M.,) burning a hole through the case. Was able to get a reference number from Earl at BB, as the original manufacturer, Arrow-Hart, is gone. Number is Bryant 7968 (Bryant is owned by Hubbell.) These are U.L. approved, but not to current (NEMA?) standards. In order to make the minimum order I also got the connector for the coach end of the cord. A local electric supply company in Seguin was able to get them overnight, but as usual there were issues. The receptacle did not include the strain relief/seal on the original--lucky that wasn't melted so I could reuse mine. Secondly, although cataloged as the same steel plug as on my cord, the new plug (Bryant 7764) is nylon, and about twice as long as the original. It will work, but the compartment door cannot be closed and locked as before... |
01-13-2008, 12:56
Warner Electric, Beloit WI, RIP many years now.
MH
01-13-2008, 13:07
My coach is 10 years newer -- and I thought the "tock-tock-tock" sound was the usual mode of operation. Now I wonder about that switch!
My antenna has worked as expected, except once when it hit some tree branches when it was raised. Then it wouldn't come down until I gave it a little push to get it started while my spouse pressed the 'down' switch. Now you got me thinking that I'll have to pull the cover off to see what's in there! Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Jan 13, 2008, at 4:56 PM, Mike Hohnstein wrote:
01-13-2008, 13:41
The micro switch should be for the "antenna is up" alarm. The slipping clutch is
the normal sound when reaching the stops; I would expect it if too much resistance was being felt on the way up also. Don Bradner 90 PT40 "Blue Thunder" Posting today by satellite from Quartzsite, AZ On 1/14/2008 at 12:46 AM mrkane1952 wrote: >Greetings All: > >I wanted to watch the play-offs in HD via off-the-air digital >broadcasts from the local stations, but the TV antenna lifter fails to >raise the antenna on my 1985 PT40. The motor makes "slipping clutch" >noises when run in either the "raise" or "lower" modes. After >removing the extension assembly, it was possible to use the motor to >raise the stubs to allow access to the (eighteen!!) cover screws, each >of which required an impact driver to loosen. > >The lifter consists of a single assembly integrating motor and gear >train. The only mark is a sticker "Warner Electric." > >There is a micro-switch positioned such that it probably was intended >to open the circuit, stopping the motor when the antenna was >completely retracted. However, the usual mode of operation during my >ownership has been to raise or lower the antenna until slipping is >heard. (This is a "tock-tock-tock" sound.) > >Anyone have any experience with R/R on this unit? |
01-13-2008, 14:10
Don:
Makes sense about the "up" warning light switch. A "stop" switch is probably inviting trouble. The rubber bumpers were deteriorated: is it possible the mechanism needed help due to over-travel in the down position? I'm using one of those saucer antennas with no rotator needed. It wasn't possible to try to manually lift the assembly while activating the motor--I'm working solo. --M.R. 1985 PT40 San Marcos, TX --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > The micro switch should be for the "antenna is up" alarm. The slipping clutch is the normal sound when reaching the stops; I would expect it if too much resistance was being felt on the way up also. > > Don Bradner > 90 PT40 "Blue Thunder" > Posting today by satellite from Quartzsite, AZ > |
01-13-2008, 17:09
Was bought by Danaher the linear drives are still available but are a
special order the old number was a warner number the Blue bird part number is 3748985 Danaher can still cross the part over and it can be bought It is expensive around 400.00 list Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Warner Electric, Beloit WI, RIP many years now. > MH > ----- Original Message ----- > From: mrkane1952 > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, January 13, 2008 6:46 PM > Subject: [WanderlodgeForum] 1985 TV antenna lifter motor > > > Greetings All: > > I wanted to watch the play-offs in HD via off-the-air digital > broadcasts from the local stations, but the TV antenna lifter fails to > raise the antenna on my 1985 PT40. The motor makes "slipping clutch" > noises when run in either the "raise" or "lower" modes. After > removing the extension assembly, it was possible to use the motor to > raise the stubs to allow access to the (eighteen!!) cover screws, each > of which required an impact driver to loosen. > > The lifter consists of a single assembly integrating motor and gear > train. The only mark is a sticker "Warner Electric." > > There is a micro-switch positioned such that it probably was intended > to open the circuit, stopping the motor when the antenna was > completely retracted. However, the usual mode of operation during my > ownership has been to raise or lower the antenna until slipping is > heard. (This is a "tock-tock-tock" sound.) > > Anyone have any experience with R/R on this unit? > > Thanks-- > M.R.Kane > 1985 PT40 > currently San Marcos, TX > > PS: I seem to be in one of those phases: on the last trip down from > the roof, the plastic step-stool I've been using for some time > shattered to pieces. Had a good grip on the ladder, so no harm. > Managed to short out the power leads for the co-pilot seat by pinching > them in the swivel. Symptom was repeated tripping of a DC circuit > breaker in the curb-side forward load center. Troubleshooting was > unusual, as several wires of different colors were all numbered "10." > Last week discovered an inoperative slack adjuster on one side of the > drive axle, which had existed for some time judging from the different > wear on the brake shoes. Properly adjusted brakes work so much > better! And the previous week, the 50 A. receptacle on the coach > shorted out (at 1:08 A.M.,) burning a hole through the case. Was able > to get a reference number from Earl at BB, as the original > manufacturer, Arrow-Hart, is gone. Number is Bryant 7968 (Bryant is > owned by Hubbell.) These are U.L. approved, but not to current > (NEMA?) standards. In order to make the minimum order I also got the > connector for the coach end of the cord. A local electric supply > company in Seguin was able to get them overnight, but as usual there > were issues. The receptacle did not include the strain relief/seal on > the original--lucky that wasn't melted so I could reuse mine. > Secondly, although cataloged as the same steel plug as on my cord, the > new plug (Bryant 7764) is nylon, and about twice as long as the > original. It will work, but the compartment door cannot be closed and > locked as before... > |
01-14-2008, 15:50
Stephen:
Is contact information available for Danaher? I found a number of 12 VDC linear actuators at McMaster-Carr and Grainger, priced from $200-$500 depending on force rating etc. Can you suggest a sufficient force rating? Interested parties can review the web info I found at the following: <http://www.grainger.com>...search term "Linear Motion Actuators" <http://www.mcmaster.com>...search term "linear motor" Thanks-- M.R.Kane 1985 PT40 near San Marcos, TX for one more day then enroute to Quartzsite --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > > > > Was bought by Danaher the linear drives are still available but are a > special order the old number was a warner number > the Blue bird part number is 3748985 > Danaher can still cross the part over and it can be bought > It is expensive around 400.00 list > Stephen 77fc35 > |
