Safe in 85 pt40
01-21-2008, 08:44
Safe in 85 pt40
The very green 85pt.40.6V92 in Pa is to be delivered soon but the
dealer is having problems opening the safe for the new owner. Does anyone have experience with opening the safe? I will forward it on. GregoryO'Connor 94ptRomolandCa |
01-21-2008, 09:35
Safe in 85 pt40
Gregory,
When he starts to open the safe if it says turn right or left to 37 don't assume you need to make a complete turn and then to 37. Go to 37 the first time even if you are on 27 when you start. Then reverse the turn to the next number. Once you havedialedall the numbers turn the dial in theopposite direction to unlockthe locking pins.
One thing to remember the previous owner may have changed the combination. If possible check with previous owner.
If you would like I would be happy to walkthe new ownerthru it. Hopefully it is full of diamonds.
I would not want the dealer opening it.
Howard Truitt
Camilla, Ga.
86 PT40
01-21-2008, 15:51
Safe in 85 pt40
When I looked at it it was open?
Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > The very green 85pt.40.6V92 in Pa is to be delivered soon but the > dealer is having problems opening the safe for the new owner. Does > anyone have experience with opening the safe? I will forward it on. > GregoryO'Connor > 94ptRomolandCa > |
01-22-2008, 03:52
Safe in 85 pt40
Thanks Howard , I will forward your info to Jeff at the dealership
in Pa. Gardner noticed it was open so the only jewel the new owner is getting is the bus. I bought a property to rent out in December and found a safe hidden. The seller was the children of the couple that passed away. I moved the safe to the rear porch and intended to take it to a locksmith. Thankfuly it was stolen from the porch, don't know if I would have passed the test??? GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Gregory, > When he starts to open the safe if it says turn right or left to 37 don't assume you need to make a complete turn and then to 37. Go to 37 the first time even if you are on 27 when you start. Then reverse the turn to the next number. Once you have dialed all the numbers turn the dial in the opposite direction to unlock the locking pins. > One thing to remember the previous owner may have changed the combination. If possible check with previous owner. > If you would like I would be happy to walk the new owner thru it. Hopefully it is full of diamonds. > I would not want the dealer opening it. > Howard Truitt > Camilla, Ga. > 86 PT40 > > ----- Original Message ----- > From: Gregory OConnor > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, January 21, 2008 3:44 PM > Subject: [WanderlodgeForum] Safe in 85 pt40 > > > The very green 85pt.40.6V92 in Pa is to be delivered soon but the > dealer is having problems opening the safe for the new owner. Does > anyone have experience with opening the safe? I will forward it on. > GregoryO'Connor > 94ptRomolandCa > > > > > > > ------------------------------------------------------------------- ----------- > > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.503 / Virus Database: 269.19.8/1235 - Release Date: 1/21/2008 9:39 AM > |
01-22-2008, 08:40
Safe in 85 pt40
I'am happy to hear i am not the only one that has the cold safe problem. I guess BB's are not intendedto be in cold weather.
Paul Downey
Versailles Ky
83PT35
Our Rollin Home
And it's COLD Start the year off right. Easy ways to stay in shape in the new year. |
01-22-2008, 13:13
Safe in 85 pt40
Here's how mine works in my 84FC. Turn left and stop at the 4th time
you come to the 1st number. Turn right and stop the 3rd time at the 2nd number. Turn left and stop at the 2nd time you get to the 3rd number. Turn right and it should stop at the 4th number. It won't open when it is cold without pointing a hair dryer at the dial for a few minutes.. David Hollis 84FC35 Springfield,IL --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > The very green 85pt.40.6V92 in Pa is to be delivered soon but the > dealer is having problems opening the safe for the new owner. Does > anyone have experience with opening the safe? I will forward it on. > GregoryO'Connor > 94ptRomolandCa > |
