Tire Deflated by road debris...long
05-17-2005, 09:15
While on Rt95 two weekends ago I was in heavy traffic at about 60
MPH when suddenly popping out from a truck IFO our Bird was a 4 foot section of 4x4 timber in my lane. I steered to avoid but heard/felt impacts on the bottom of the bus so I pulled off and checked the bottom of the bus fearing big problems. Nothing was found as far as damage or big scrapes but the last thing I checked was from a vantage point behind the RR dual tires...the tires looked "diffrent" in thier respective sidewall profiles. When I tapped them with my maglight, the inner tire sounded "dull" or "flat" while the outer tire "rang" when tapped. Checking the air pressure, the inner tire was dead flat, outer tire fine. My assumption was that I must have hit the 4x4 with just the inner tire...and this caused a momentary break in the seal between tire/rim, deflating the tire. Tire was reinflated with no problems using the air chuck and hose. So my point is that first, a curb hit or other impact could potentially deflate a tire, if you hit something, check the tires carefully as part of your whole "after hit" inspection. Second, clearly my tire is questionable, it may have damage...if this was a front tire I would replace it and not risk a blowout from hidden damage. I am gambling with the inner rear dual. Last thing is a previous thread mentioned quick checking tires by tapping, it is a good method for a quick check, "tapping" can tell you something, learn to listen for the "ring" Thankfully I found the flat tire in this case before running a hundred miles or more on it. Last comments...my wife got me a cheep jumpsuit from Kmart and some rubber hospital gloves, I carry these items on the bus for emergency use...came in handy here, sure saves good clothes...also another gift that I sort of laughed off when she bought it was a small "headlight" flashlight. Being able to see with a flashlight and have both hands free for tools and moving around is a "good thing", it looks a little wierd...but i love this light. Just a pair of LED's and a elastic head strap. Works great when riding a bicycle also. Frank W. 85FC33 Woodbridge, VA. |
05-17-2005, 14:47
Frank W.
Interesting story and good tips. I agree with you, the tire is suspect, I'd replace it in the near future. Murphy's law says the tire will blow at the most inopportune time. In addition, tires can cause significant damage to the undercarriage as they come apart when they blow and spin for a while. I have known folks who have driven for quite a number of miles with a blown rear dual tire ripping things apart with each turn. Harry Saddock 83FC35 South Windsor, CT - In WanderlodgeForum@yahoogroups.com, "fwernlein" wrote: > While on Rt95 two weekends ago I was in heavy traffic at about 60 > MPH when suddenly popping out from a truck IFO our Bird was a 4 foot > section of 4x4 timber in my lane. I steered to avoid but heard/felt > impacts on the bottom of the bus so I pulled off and checked the > bottom of the bus fearing big problems. > > Nothing was found as far as damage or big scrapes but the last thing > I checked was from a vantage point behind the RR dual tires...the > tires looked "diffrent" in thier respective sidewall profiles. When > I tapped them with my maglight, the inner tire sounded "dull" > or "flat" while the outer tire "rang" when tapped. Checking the air > pressure, the inner tire was dead flat, outer tire fine. > > My assumption was that I must have hit the 4x4 with just the inner > tire...and this caused a momentary break in the seal between > tire/rim, deflating the tire. Tire was reinflated with no problems > using the air chuck and hose. > > So my point is that first, a curb hit or other impact could > potentially deflate a tire, if you hit something, check the tires > carefully as part of your whole "after hit" inspection. Second, > clearly my tire is questionable, it may have damage...if this was a > front tire I would replace it and not risk a blowout from hidden > damage. I am gambling with the inner rear dual. Last thing is a > previous thread mentioned quick checking tires by tapping, it is a > good method for a quick check, "tapping" can tell you something, > learn to listen for the "ring" Thankfully I found the flat tire in > this case before running a hundred miles or more on it. > > Last comments...my wife got me a cheep jumpsuit from Kmart and some > rubber hospital gloves, I carry these items on the bus for emergency > use...came in handy here, sure saves good clothes...also another > gift that I sort of laughed off when she bought it was a > small "headlight" flashlight. Being able to see with a flashlight > and have both hands free for tools and moving around is a "good > thing", it looks a little wierd...but i love this light. Just a > pair of LED's and a elastic head strap. Works great when riding a > bicycle also. > > Frank W. > 85FC33 > Woodbridge, VA. |
05-17-2005, 21:45
--- In WanderlodgeForum@yahoogroups.com, "fwernlein"
wrote: >............. > Last comments...my wife got me a cheep jumpsuit from Kmart and some > rubber hospital gloves, I carry these items on the bus for emergency > use...came in handy here, sure saves good clothes...also another > gift that I sort of laughed off when she bought it was a > small "headlight" flashlight. Being able to see with a flashlight > and have both hands free for tools and moving around is a "good > thing", it looks a little wierd...but i love this light. Just a > pair of LED's and a elastic head strap. Works great when riding a > bicycle also. > > Frank W. > 85FC33 > Woodbridge, VA. I also carrysome cardboard to use as a creeper--makes sliding underneath a whole lot easier. Regards, Jim Scoggins 04 M380 Stafford, VA |
