Second try--Was--accessing dashboard for miscellaneous repairs
01-21-2008, 10:09
Hi, folks--
Gee, it's been since Saturday that we sent in some questions on this, but not a single reply from the group. Was really hoping to get your input because many of you have so much more expertise on these matters than we do. . .we're a bit daunted by some of this. . .
Here are our technical problems/questions: On the dashboard of our '83 FC 35', some of the heater rocker switches don't work, and a few small blue lights are out. On the left side of the instrument panel, the backlighting has gone out. Plus the odometer seems to be working only intermittently. We read the one thread of messages on opening up the dashboard in the archives (beginning at message 15,762), but that was pertaining to a '78 FC 33'. Does anyone have any advice on opening our dash and replacing these components, please?
01-21-2008, 11:15
--- In WanderlodgeForum@yahoogroups.com, "Jo-Ski"
> > Hi, folks--JO. Please call me on my cell and I well try to help you .I have had my dash out in my pt 40 many times. Lee Condosta 85 PT 40 Cell 910-520-9166 Holden Beach N.C > > Gee, it's been since Saturday that we sent in some questions on this, but not a single reply from the group. Was really hoping to get your input because many of you have so much more expertise on these matters than we do. . .we're a bit daunted by some of this. . . > > Here are our technical problems/questions: On the dashboard of our '83 FC 35', some of the heater rocker switches don't work, and a few small blue lights are out. On the left side of the instrument panel, the backlighting has gone out. Plus the odometer seems to be working only intermittently. We read the one thread of messages on opening up the dashboard in the archives (beginning at message 15,762), but that was pertaining to a '78 FC 33'. Does anyone have any advice on opening our dash and replacing these components, please? > > Thanks again very much in advance for any help/advice you can offer! > > Jo-Ski and Stew > '83 FC 35' RB > "The Bird Abides" > Blaine, WA > |
01-21-2008, 11:31
Hi Jo-Ski: Sorry I missed your first post. As Ernie said, remove the outer (4) trim edges, 2 on each side. Ok, here is where we find out if your dash has been pulled up before or not. Gently raise the lower edge of the dash up and see if you feel like it is still screwed down or not, if it lifts then it has been out before if not then stop and on the left side of the dash there will be a couple of "blank" places for add on switches, those will gently lift up and under one of those you will find a screw holding that side of the lower dash panel down. Remove that screw and set it aside,,, way aside Now then the lower dash will only lift up so far it will not come all the way out. Remember there is a ton of wiring under there and I do mean a ton like a rats nest and those wires are brittle or have connectors on them and many many butt splices. so before you start make a diagram of the dash and which switches are not working and really you will want to have then on hand before you start this. on the sides of the switches there is a pressure point to press on to allow the switch to be removed through the top with out prying. Remember to make a diagram of which wires went were and don't trust to memory, if it is written down you don't have to remember and that is one thing less to do. !/2 of the lower dash being out, whew, the inverters (blue ice cube's) are either located on the left side under the lower dash or more than likely they will be on the left behind the upper lower dash and it will have to come out to get to them, but one step at a time. The led lights for the switches may be because no power to the switches, wires pulled off the back of the switches or? or? or? so many things. Bottom line, be super gentle always. Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 02:09 PM 1/21/2008 -0800, you wrote: Hi, |
01-21-2008, 13:13
A note on the electro-lum part, in addition to the inverters that
have been mentioned, the EL can also go out if the "elements" within the dash are damaged. On my old FC, half of the lower dash was out because a corner had somehow gotten crimped, probably on a previous dash removal for some reason. It can also happen if someone drills a new hole for some reason. Once it is damaged, it is toast. Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "Jo-Ski" > > Hi, folks-- > > Gee, it's been since Saturday that we sent in some questions on this, but not a single reply from the group. Was really hoping to get your input because many of you have so much more expertise on these matters than we do. . .we're a bit daunted by some of this. . . > > Here are our technical problems/questions: On the dashboard of our '83 FC 35', some of the heater rocker switches don't work, and a few small blue lights are out. On the left side of the instrument panel, the backlighting has gone out. Plus the odometer seems to be working only intermittently. We read the one thread of messages on opening up the dashboard in the archives (beginning at message 15,762), but that was pertaining to a '78 FC 33'. Does anyone have any advice on opening our dash and replacing these components, please? > > Thanks again very much in advance for any help/advice you can offer! > > Jo-Ski and Stew > '83 FC 35' RB > "The Bird Abides" > Blaine, WA > |
01-21-2008, 13:53
On a 91 EL dash that was out partway, I rubbed the lines with an
eraser and the dash glowed once again. if there is a rehostat check voltage in and out while spinning the dial. The rehostat regulate voltage to the inverter. It goes from battery ;to head light switch (;to relay);to rehostat ;to inverter to ;el lites. With one bad inverter on my 94, I used a radioshack inverter to run the dash for a test. The '94 inverter looks like a brick and cost $400.00 each. Units earlier than 94 have several small inverters. The EL lghts run off of 110 volts so the mini invereters change 12 volts to 110 for the glow. The problem with the radioshack/pepboys inverters is they do not blow enough HTZ (whatever that is) so you cant get a bright glow At a recent tailgate I bugged a '04Prevost neighbor to look at my Dash after dusk. He agreed to check it out if I would not play the MusicalHorn anymore. He missed out on seeing quite a beautiful dash EL is a subject for StephenB and CurtS. careful with 100 voltage after the inverters. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > A note on the electro-lum part, in addition to the inverters that > have been mentioned, the EL can also go out if the "elements" within > the dash are damaged. On my old FC, half of the lower dash was out > because a corner had somehow gotten crimped, probably on a previous > dash removal for some reason. It can also happen if someone drills a > new hole for some reason. Once it is damaged, it is toast. > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "Jo-Ski" > > > > Hi, folks-- > > > > Gee, it's been since Saturday that we sent in some questions on > this, but not a single reply from the group. Was really hoping to get > your input because many of you have so much more expertise on these > matters than we do. . .we're a bit daunted by some of this. . . > > > > Here are our technical problems/questions: On the dashboard of > our '83 FC 35', some of the heater rocker switches don't work, and a > few small blue lights are out. On the left side of the instrument > panel, the backlighting has gone out. Plus the odometer seems to be > working only intermittently. We read the one thread of messages on > opening up the dashboard in the archives (beginning at message > 15,762), but that was pertaining to a '78 FC 33'. Does anyone have > any advice on opening our dash and replacing these components, please? > > > > Thanks again very much in advance for any help/advice you can offer! > > > > Jo-Ski and Stew > > '83 FC 35' RB > > "The Bird Abides" > > Blaine, WA > > > |
