ULSD in older engines-emissions
01-29-2008, 11:34
I know that ULSD results in greatly reduced emissions from the engines
designed to run on it, but is it any cleaner in our old engines? Just curious. Scott Forman 86 PT38 Memphis |
01-29-2008, 11:56
I'm sure it is possible to debate what-all makes up "cleaner," but the basic
equation is simple: Less sulphur in equals less sulphur out. So for that particular byproduct, all engines are outputting far less of it than they were, when run on ULSD. Don Bradner 90 PT40 "Blue Thunder" Posting today by satellite from Quartzsite On 1/29/2008 at 11:34 PM Scott Forman wrote: >I know that ULSD results in greatly reduced emissions from the engines >designed to run on it, but is it any cleaner in our old engines? Just >curious. > >Scott Forman >86 PT38 >Memphis |
08-14-2008, 07:13
In theory, ULSD, would have fewer sulphur-based emissions in any
engine using it. There are some issues with fuel system hoses and seals on older vehicles (pre-90, probably), so you may need to watch for fuel leaks and plan to upgrade/replace the flexible fuel lines. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Idaho Springs, CO On Jan 29, 2008, at 4:34 PM, Scott Forman wrote: > I know that ULSD results in greatly reduced emissions from the engines > designed to run on it, but is it any cleaner in our old engines? Just > curious. > > Scott Forman > 86 PT38 > Memphis > |
08-15-2008, 17:41
Less sulphur means less sulphuric acid in the exhaust circuit. Pipes
and muffler may last a little longer. Wave, GPSGary |
