Shurflo Smart Pump 5.7
02-02-2008, 02:43
I called Shurflo today & they said it was a sensor.They said they
would send me a new one free of charge. I just don't know what would have made it break after three years. there wasn't any pressure on it. If the pump would been under our bed we would got a lot of water on the floor. When I turned the water off outside the tank still drained out through the pump. The only way I could get the pump to quit leaking was to turn the water on the in & out side of the pump. Don Spithaler 89 SP 36' Butler, PA In Zephyrhills, FL --- In WanderlodgeForum@yahoogroups.com, "Donald Spithaler" > > Hi All > I had a problem with my Shurflo Smart Pump 5.7. I had water coming > out of the bottom of the pump by the strainer. When I took the 4 > screws out there was sensor that that came out of the bottom with an 0 > ring on it. I didn't think it looked right so I took the other 10 > screws out of the bottom & when I lifted the cover I saw nut laying > loose in there. When I looked at it I could that it had broken off the > sensor. The nut was holding the sensor in place. I hope I can get a > new part from Camping World tomorrow. If I hadn't been home I would > have lost a lot of water & it didn't ruin anything because my pump is > in the back compartment outside. The pump has a three year warranty on > it & mine is three years & 4 months old. Has any one had this problem? > I was also on city water for the last 2 weeks. > Don > 89 SP 36' > Butler, PA > |
02-02-2008, 04:36
If the pipes near the pump are mounted to metal without a rubber
insulator,,,, it may have been ice freeze damage????? or there was a factory crack all along?????? One other thing could be that when you pressurized the system with city water, air in the bus plumbing pipes may have been pressurized by the incomming force of water up against a closed plumbing system. It is possible to add 60 psi city water to a airfilled, closed plumbing system and compress the air in the system to over 150 psi. once the running force of water maxes out compression of air in the closed pipe, the water rebounds and causes a snap action called "water hammer". When I first pressurize my bus I always open a faucet to allow the air to escape. I fear park water hammer backing up to my bus plumbing system so I usully just fill the tank and use the shureflow to maintain pressure in the pipe. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Don Spithaler" > > I called Shurflo today & they said it was a sensor.They said they > would send me a new one free of charge. I just don't know what would > have made it break after three years. there wasn't any pressure on it. > > If the pump would been under our bed we would got a lot of water on > the floor. When I turned the water off outside the tank still drained > out through the pump. The only way I could get the pump to quit > leaking was to turn the water on the in & out side of the pump. > > Don Spithaler > 89 SP 36' > Butler, PA In Zephyrhills, FL > --- In WanderlodgeForum@yahoogroups.com, "Donald Spithaler" > > > > > Hi All > > I had a problem with my Shurflo Smart Pump 5.7. I had water coming > > out of the bottom of the pump by the strainer. When I took the 4 > > screws out there was sensor that that came out of the bottom with an 0 > > ring on it. I didn't think it looked right so I took the other 10 > > screws out of the bottom & when I lifted the cover I saw nut laying > > loose in there. When I looked at it I could that it had broken off the > > sensor. The nut was holding the sensor in place. I hope I can get a > > new part from Camping World tomorrow. If I hadn't been home I would > > have lost a lot of water & it didn't ruin anything because my pump is > > in the back compartment outside. The pump has a three year warranty on > > it & mine is three years & 4 months old. Has any one had this problem? > > I was also on city water for the last 2 weeks. > > Don > > 89 SP 36' > > Butler, PA > > > |
