Tire help
02-07-2008, 15:04
Tire help
Anyone out there in civilization help me get a replacement Michelin
XZE-star 11R22.5 inch tire? I'm stuck in Balmorhea State Park in west Texas. The side-wall is bulging on a steer-axle tire so bad I think I'll have to buy a used tire at the nearest truckstop and swap a tag forward before I can drive anywhere. Thanks-- M.R.Kane '85 PT 40 Balmorhea SP, Tx |
02-07-2008, 15:31
Tire help
Michael:
You might try Pecos, which is the closest. Next would be Ft. Stockton and if those fail, Odessa should have it for sure. If I would have known this this morning, I could have dropped one off for you from El Paso. I am already past you in Big Spring, TX. I hope you have a toad with you. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "mrkane1952" <mrkane@...> wrote: > > Anyone out there in civilization help me get a replacement Michelin > XZE-star 11R22.5 inch tire? I'm stuck in Balmorhea State Park in west > Texas. The side-wall is bulging on a steer-axle tire so bad I think > I'll have to buy a used tire at the nearest truckstop and swap a tag > forward before I can drive anywhere. > > Thanks-- > > M.R.Kane > '85 PT 40 > Balmorhea SP, Tx > |
02-07-2008, 15:33
Tire help
Forgot to tell you that there are 3 truck stops in Pecos.
R.E. (Ron) Marabito, Dallas, tX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "mrkane1952" <mrkane@...> wrote: > > Anyone out there in civilization help me get a replacement Michelin > XZE-star 11R22.5 inch tire? I'm stuck in Balmorhea State Park in west > Texas. The side-wall is bulging on a steer-axle tire so bad I think > I'll have to buy a used tire at the nearest truckstop and swap a tag > forward before I can drive anywhere. > > Thanks-- > > M.R.Kane > '85 PT 40 > Balmorhea SP, Tx > |
02-07-2008, 17:11
Tire help
Thanks Ron:
I arrived here at 17:00 from Deming. No problems observed at any stops, including fueling in Anthony, so it must have happened in the last 100 miles. I posted in the hope one of the Texas contingent at Q might be passing on the way home. From previous experience, I'm not optimistic about services in Pecos. Web shows a Michelin dealer in Midland, and a Bridgestone truck tire dealer in Ft. Stockton. I have my pickup to fetch one, once located. I have CoachNet road service for mounting. --M.R.Kane 1985 PT 40 Balmorhea SP, TX --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > Forgot to tell you that there are 3 truck stops in Pecos. > > R.E. (Ron) Marabito, Dallas, tX 92WB40 > |
02-08-2008, 01:36
Tire help
Good luck to you. Wish I had been a day behind and could have helped.
Ron --- In WanderlodgeForum@yahoogroups.com, "mrkane1952" <mrkane@...> wrote: > > Thanks Ron: > > I arrived here at 17:00 from Deming. No problems observed at any > stops, including fueling in Anthony, so it must have happened in the > last 100 miles. I posted in the hope one of the Texas contingent at Q > might be passing on the way home. > > From previous experience, I'm not optimistic about services in Pecos. > Web shows a Michelin dealer in Midland, and a Bridgestone truck tire > dealer in Ft. Stockton. I have my pickup to fetch one, once located. > I have CoachNet road service for mounting. > > --M.R.Kane > 1985 PT 40 > Balmorhea SP, TX > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > Forgot to tell you that there are 3 truck stops in Pecos. > > > > R.E. (Ron) Marabito, Dallas, tX 92WB40 > > > |
