Boilers (was: Residential fridges)
02-08-2008, 21:25
I changed the subject of this thread - didn't mean to hijack your
fridge thread, Bruce. On Feb 8, 2008 9:57 PM, Gregory OConnor > > thinking of learning to use the instahot for cleaning and other hot > water needs between genset runtimes. (I never turned the instahot > on, dont even know if it runs on inverter ac output??) It doesn't on my coach, but yours is almost a decade newer so it may there. I'd imagine it would pull a good bit of current, though. > I can see that if you WalCamp it would be nice to wake up and take a > hot shower without starting a genset. Maybe a quick 1/2 hour jump on > your next days journey prior to taking a shower will give the > detroit a chance to heat enough water To be honest this is a rare problem, as I like to shower before bed - just can't handle climbing into a clean bed if I'm not clean. The hot water holds for several hours after stopping so I can pull in, have dinner and take a shower just fine. Where it becomes a problem is when I stay in one place, without shore power, for a day. I have to kick the generator on an hour before I want my shower. Now that's only been a hassle a couple of times but nevertheless, it's something I'd like to fix. I'm leaning heavily toward the diesel fired boiler. We stayed with family a couple of months ago and it was cold - snowed all over us the last night we were there. I knew the 8V92 would not be happy firing up in that cold, so I woke up a couple of hours before I wanted to leave, started the genset, turned the block heater on and went back to bed. Well, a couple of hours wasn't anywhere near enough. Getting that old girl to start was difficult and too darn much cranking for my comfort. A diesel fired boiler could be started when I went to bed the night before and run all night without annoying me and would heat both my water and my engine block. We could also use the hydronic heaters instead of LP on those nights, I'd imagine, not that there's any reason to avoid LP but if I'm already heating the water with another fuel, might as well use it. Would be a great boondocking backup if LP heaters failed or I ran out of propane. -Ryan '86 PT-40 8V92 |
02-10-2008, 17:15
Ryan, Might want to check your block heater plug. I have a 8V71 in a Eagle bus, and have started it many times in cold weather after running the gen. set approx. 1 hr., while also charging the batteries. Straight 40W does get thick in cold weather. Mine didn't work very well until I cleaned the electrical plug. Itis amazing how such small amounts of crud/corrosion can cause a bad contact. I love these old Detroits! Good Luck , George Burke 1977 FC Charlotte
On Feb 9, 2008 4:25 AM, Ryan Wright <"ryanpwright@gmail.com"> wrote:
02-11-2008, 05:02
Thanks George, I will do that.
-Ryan On Feb 10, 2008 9:15 PM, George Burke > > Ryan, Might want to check your block heater plug. I have a 8V71 in a Eagle > bus, and have started it many times in cold weather after running the gen. > set approx. 1 hr., while also charging the batteries. Straight 40W does get > thick in cold weather. Mine didn't work very well until I cleaned the > electrical plug. It is amazing how such small amounts of crud/corrosion can > cause a bad contact. I love these old Detroits! Good Luck , > George Burke 1977 FC Charlotte > |
02-11-2008, 11:18
Ryan, I agree with George. The electric block heater should giveyou an easier start within an hour. To avoid burning the oil, I never used mine longer than that (on my Newell).
Brad Barton 00LXiDFW bbartonwx@...
Climb to the top of the charts! Play the word scramble challenge with star power. Play now! |
02-14-2008, 15:48
On my Series 60 the electrical engine block heater is located, in the
cooling water system in the road side of the block, midway fore and aft, behind the radiator fan motor. You can't see it in my coach without using a mirror, because the air conditioning compressor is hiding it. It's about 1 1/2" hex fitting with the wiring in the center. The immersion heater has a very small element on the water side of the plug. Eric Perplies currently in Yuma, AZ 96' 42' WBWL |
