Adding a boiler to an 86 PT
02-10-2008, 02:38
I have been watching closely the thread that has been discussing adding
boilers to the older coaches. I would love to have one in my 86 PT.
How do I go about doing this project? It seems to me that all one has
to do it tap in to the chassis heater system, correct? How big and
expensive a project is this?
Scott Forman
86 PT38
Memphis
02-10-2008, 03:00
I am considering this too for our 83 FC. I was speaking with a Webasto
distributer/
dealer/ service facility last week. He quoted me (over the phone) Webeasto 2010
(45K
BTU) $1,600 and installation would be in the $500 range. From what I have seen,
this
may be pretty fair. I see prices on the net that are double that.
http://www.webasto.us/am/en/am_busses_heaters_2780.html
http://www.webasto.us/am/en/am_busses_heaters_819.html
NH-Bill
1983 FC 35
> Scott Forman
> 86 PT38
> Memphis
02-10-2008, 03:12
Here's what I did. Mounted the boiler in the front curb side compartment, tapped the generator for the fuel supply. Using T-connectors I accessed the supply and return water lines wired it up and flipped the switch. I replaced theauxillary circulation pump in the rear of the coach with a higher capacity unit. I doubt this upgrade is cheaper to operate as compared to propane but it adds an additional heat source and preheats the engine faster than the electric engine heater.
A word on fuel supply, it's always a good idea to isolate the supply to each fuel using component with a dedicated check valve. Back flow and air in the lines are your enemy.
MH
Sent: Sunday, February 10, 2008 8:38 AM
Subject: [WanderlodgeForum] Adding a boiler to an 86 PT
Scott Forman
86 PT38
Memphis
02-10-2008, 03:17
To me, this is most useful for hot water and engine heating rather
than coach heating. I really must say that I think not giving the
option of propane for water heat is the biggest error BB made in
these coaches.
Scott
and flipped the switch. I replaced the auxillary circulation pump in
> MH
> From: Scott Forman
adding
PT.
has
> Scott Forman
> 86 PT38
> Memphis
02-10-2008, 05:20
I agree with Scott WRT the propane water heater. I installed a
attwood 6 gal water heater in my 35' FC. I retained the electric
water heater, so I have the option of using either elec when
available, or propane when I am without hook-ups, and I do not want
to run the generator. I bought mine at camping world for approx $250
but you can get them cheaper on EBay. Ebay also has some interesting
tankless systems.
Pete
"Prairie Dog"
78 35'FC
> these coaches.
> Scott
in
> > MH
> > From: Scott Forman
discussing
> adding
> PT.
one
> has
> and
> > Scott Forman
> > 86 PT38
> > Memphis
02-10-2008, 05:38
Pete,
Where did you locate the Attwood? Does it vent like the Surbubans?
NH-Bill
1983 FC 35 SB
--- In WanderlodgeForum@yahoogroups.com, "susanmarycamilleri"
> tankless systems.
> Pete
> "Prairie Dog"
> 78 35'FC
> --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@>
> > these coaches.
> > Scott
> in
> > > MH
> > > From: Scott Forman
> discussing
> > adding
> > PT.
> one
> > has
> > and
> > > Scott Forman
> > > 86 PT38
> > > Memphis
02-10-2008, 06:53
My coach came with an AquaHot unit as standard. I note that it has its own small Racor fuel filter. The burner nozzle has a very fine hole to turn the diesel into a mist to burn efficiently. Any debris that gets to the nozzle has a high chance of clogging it. There is a second fuel filter in the fuel line after the Racor. So, do consider adding appropriate fuel filters (and regularly replace the elements as necessary).
El Sobrante CA
"aeonix1@mac.com"
these coaches.
Scott
--- In "WanderlodgeForum@yahoogroups.com", "Mike Hohnstein"
02-10-2008, 14:54
Bill
I put it under the kitchen sink. The heater just fit between the rub
rails. I tapped into the gas line that goes to the furnace under the
stove. It does vent outside, and you have to cut an opening to fit
the HWT in. I have the hot water line from the electric tank going
into the propane HWT, but there is a bypass valve on the propane HWT.
When I have electricity I bypass the propane HWT. When I am going to
use propane I open the valve and the water from the electric HWT
(whick is cold because of no electricity) goes into the propane HWT
to be heated. I bought the cheaspest attwood I could, it has a pilot
light not a DSI. I figured that I only use the propane tank when I am
somewhere without power, so I can get out and light the pilot.
I have had this for three years and it works well.
Pete
"Prairie Dog"
35' FC 78
--- In WanderlodgeForum@yahoogroups.com, "Bill Garamella"
<bgaramella@...> wrote:
> Pete,
> NH-Bill
> 1983 FC 35 SB
want
$250
interesting
> > tankless systems.
> > Pete
> > "Prairie Dog"
> > 78 35'FC
<sforman@>
rather
in
> > > these coaches.
> > > Scott
side
it up
pump
> > in
this
adds an
valve.
> > > > MH
> > > > From: Scott Forman
> > discussing
> > > adding
my 86
> > > PT.
all
> > one
> > > has
big
> > > and
> > > > Scott Forman
> > > > 86 PT38
> > > > Memphis
User(s) browsing this thread: 9 Guest(s)
