LXI vs. WB's
02-13-2008, 07:21
LXI vs. WB's
We are still looking at larger BB's. I have seen a few LXI's of the 98
vintage 41,s and 43,s for sale as well as a few 90 to 96 WB's. I
understand some of the differences such as the Detroit 60 and the
dropped engine for the rear closet. But I am interested in knowing some
of the possible problems with a 98. Is the 60 DD a good engine? Are
he 98's overloaded on the FA? I remeber reading something about some
BB's having this problem. Any other things I should be aware of? Would
really appreciate some assistance.
Bruce
1988 FC35
02-13-2008, 07:46
LXI vs. WB's
Bruce,
David Brady has been working with the front end of his LXi. Mine is not overloaded, but overbuilt. I don't think there is a better engine than the Series 60, but I like any Detroit. Mine has a standard non-slide bedroom without a rear closet, but the bed's a lot eaiser to get around. We have a full length closet on the front wall of the bedroom and 3 hall closets. Plenty of storage on board.
Brad Barton 00LXiDFW
bbartonwx@...
Date: Wed, 13 Feb 2008 19:21:33 +0000
Subject: [WanderlodgeForum] LXI vs. WB's
Bruce
1988 FC35
Connect and share in new ways with Windows Live. Get it now!
02-13-2008, 08:16
LXI vs. WB's
I have to admit that the Series 60 in my '95 was a major attraction. Nothing wrong with the DD 8v92, but it's been nearly 20 years since 8vs and 6vs have been built. It's getting difficult to find experienced diesel mechanics who can work with them. Since the Series 60 is still in production -- and widely used -- there is little difficulty finding qualified mechanics.
FWIW, I've had no troubles with the engine and haven't needed any repairs on it -- just the usual preventive maintenance you'd expect.
When I had my coach weighed, I was a little surprised how heavy it was -- but it's still comfortably under the GVWR and no axle is close to being overloaded. I did, however, have to raise the tire pressures to keep the tires 'in spec' to somewhat above the recommended pressures on a plate found in one of the storage bays.
Some of the 'purists' might suggest that the coaches with rivets in their skin are "better" than the later, adhesive bonded models -- but I wouldn't know how true that is. From an engineering perspective, adhesive bonding, if done correctly, gives a stronger connection with less concentrated stress on the connection points as is the case with rivets. But I can understand a concern that "glue" might not be as durable over time. (But I've never heard that anyone has had trouble with a 'bird in this regard.)
El Sobrante CA
"aeonix1@mac.com"
On Feb 13, 2008, at 11:46 AM, brad barton wrote:
Bruce,
"bbartonwx@hotmail.com"
Bruce
1988 FC35
02-13-2008, 08:25
LXI vs. WB's
Bruce,
I'm with Brad - the S60 is a remarkable engine with a long
successful history in the trucking industry. My axles, like
the rest of the bus, are overbuilt too. GAWR: steer: 16K,
drive: 23K, tag: 13K. My actual axle weights are steer: 14.5K,
drive: 21K, tag: 11.5K for a vehicle weight 47K and a CCC of
5K lbs. I know that the steer axle on early LXi's had a GAWR of
14K lb, but I think they were all recalled and swapped with 16K lb
units. (Definitely something to check). Some of the early units had
steerable tags, a very cool option, but known to present it's own set
of problems. A non-steer tag is probably preferable. My LXi has
been great - reliable and spacious. The only issue I've had is ride
quality.
When I bought my coach it rode rough primarily at the steer axle. I
found that the ride height was almost an inch low at all axles. Setting
it
up with the proper ride height, Koni FSDs, CrossFires, and Centramatics
improved the ride significantly. Recently though, I discovered that
BlueBird put an excessively stiff front anti-sway bar on the steer axle.
I removed the steer axle anti-sway bar and now the ride is as close
to a Prevost (and I've driven a few) as your likely to find. A lighter
weight Roadmaster anti-sway bar is in the works.The non-slide LXi
does use a lighter anti-sway bar (1.75" diameter versus my 2.125" bar),
but I still think 1.75" is too stiff. I'll be going to a 1.5" bar. The
great thing
about BB's (as I'm sure you know) are the capacities, and the LXi
follows in that BB tradition including a 40 gallon LPG tank and a dual
fuel refrigerator. The non-slide LXi has the typical
triangulated basement bays; the slide equipped LXi adds to this by
incorporating longitudinal frame rails running the length of the
basement.
These rails are under the basement and are also triangulated (take a
peek under any LXi and you'll see what I'm talking about). These were
added to compensated for the slide opening. In addition, the inside of
bus has a layer of sheet metal riveted to the inner frame members
spanning
the length of the bus and spanning the distance from the floors to the
bottoms of the windows. This is used to compensate for the rivet-less
exterior look; i.e, hide the rivets on the inside. The slide equipped
bus
also has a set of triangulated frame members stretching from the top of
the steer axle to the bottom of the basement longitudinal rails, which I
discussed earlier. As Bruce Morris put it, your not losing any strength
by going from a non-slide bus to a slide equipped LXi (lots of
compensating
strength was built in.
David Brady
'02 LXi, NC
brad barton wrote:
Bruce,
Bruce
1988 FC35
Checked by AVG Free Edition. Version: 7.5.516 / Virus Database: 269.20.4/1275 - Release Date: 2/12/2008 3:20 PM
02-13-2008, 08:35
LXI vs. WB's
Oops, I beg your pardon, I meant to write "George Morris", not Bruce.
George is the ex-bluebird mechanic now working for Bleakley's at
Unidilla.
David Brady
'02 LXi, NC
David Brady wrote:
Bruce,
compensating
David Brady
'02 LXi, NC
02-13-2008, 11:19
LXI vs. WB's
I will stick with rivets. Most aircraft are built with one inch or less rivet spacing. There are many 50 year old examples out there in fine condition. My BB has three inch spacing. Yes there are composites out there, all subject to UV problems over time. No offense to newer units.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Royale Conversion
El Sobrante CA
"aeonix1@mac.com"
Bruce,
To:
BB's having this
Bruce
1988 FC35
Connect and share in new ways with Windows Live.Get it now!
Never miss a thing. Make Yahoo your homepage.
02-13-2008, 12:19
LXI vs. WB's
I'm with you Leroy. I love the rivet-ed buses of the 40's, 50's &
60's,
GM's, Flxible's, etc. Unfortunately they don't build 'em like that
anymore. If you want the newer features, Series 60, etc, then you
get the smooth sides. At least the LXi has rivets on the inside wall
panels.
David Brady
'02 LXi, NC
units.
Leroy Eckert
Dahlonega, GA
Royale Conversion
El Sobrante CA
"aeonix1@mac.com"
Bruce,
Bruce
1988 FC35
Never miss a thing.
02-13-2008, 13:20
LXI vs. WB's
My bus has rivets -- and a Series 60. I think the rivets went away in '96.
El Sobrante CA
"aeonix1@mac.com"
On Feb 13, 2008, at 4:19 PM, David Brady wrote:
I'm with you Leroy. I love the rivet-ed buses of the 40's, 50's & 60's,
panels.
02-13-2008, 14:18
LXI vs. WB's
Call me an old romantic.
I opted for the rivets for the classic look. 97 was the last year for
riveted birds. Since neither my wife nor I wanted slides anymore, and
since we wanted rivets, it became a no brainer for us.
With the exception of slides and bonded sides, there isn't enough
difference between the 1995-2003 WB43s and LXis to be concerned about.
It really just comes down to what style and layout you prefer. I'm not
getting into the bonded vs riveted wars, we bought what we liked and
have been changing anything we didn't like and we REALLY like our bird.
> '96.
02-13-2008, 14:26
LXI vs. WB's
97 was the last year of the rivets. You can get a Series 60 w/rivets in the
95/96 42 footer, and the 97 41 and 43 footers.
The 97 was when they dropped the engine down and gained some room at the back.
My personal ideal would be a 97 41 ft with mid-entry, like the Hulse's have.
Don Bradner
90 PT40 "Blue Thunder"
Posting today by satellite from Casa Grande, AZ
>'96.
>Pete Masterson
>El Sobrante CA
>aeonix1@...
>> 60's,
>> panels.
Don Bradner
Eureka, CA
