Horton Fan
02-16-2008, 04:00
Horton Fan
Guys
I would like to know when my fan engages & disengages. Being a
pusher the fan is two far away. How would be a good way to wire it up.
I would like to have a light come on when it is engaged. Would the air
solenoid be a good place to tap into the wiring? I would like to know
at what temp it engages. I can tell it is working when I stop because
it will cycle on & off. How does everyone else know? I hope I am not
the only one that wanders that.
Don Spithaler
89 SP 36'
Butler, PA Zephyrhills, FL
02-16-2008, 04:59
Horton Fan
On my PT, is is fairly obvious, as the temp will fall when the fan
cycles on. It is not exact, but good enough for me.
Scott Forman
86 PT38
Memphis
--- In WanderlodgeForum@yahoogroups.com, "Donald Spithaler"
> Guys
> Don Spithaler
> 89 SP 36'
02-16-2008, 15:36
Horton Fan
I am not sure who can hear a Horton, but according to Dr. Seuss,
Horton can hear a who!
Gardner
78FC33 (I can't hear anything in my FC)
--- In WanderlodgeForum@yahoogroups.com, "Scott Forman"
> Scott Forman
> 86 PT38
> Memphis
> > Guys
it up.
the air
know
because
not
> > Don Spithaler
> > 89 SP 36'
02-17-2008, 04:57
Horton Fan
Don I dont know about the fan on your bus but some air clutches are
engaged in the absence of air pressure. air is needed to turn the fan
on. that way the fan will be on at a failure of the air pressure system
(passive on). If you dis connect voltage or ground at the electric
over air switch the fan comes on.
GregoryO'Connor
94ptRomolandCa
> Guys
> Don Spithaler
> 89 SP 36'
02-17-2008, 05:27
Horton Fan
Our 88FC fan is activated by an air electrical 12V solenoid.
An indicator light could be attached, but I think you would need
at least 70 feet of wire, and probably a relay for voltage.
I do not have this schematic, but possibly it could be attached to
the overide switch ??????
This is not impossible. And I think a good idea.
Bill 88 FC Michigan
> Guys
up.
air
know
because
> Don Spithaler
> 89 SP 36'
02-17-2008, 14:03
Horton Fan
Greg -- Bill
When you put air to my fan it will lock the clutch. I just had it
off & rebuilt a couple of months ago. It was leaking air around the
hub. I haven't had time to check the solenoid to see which wire is the
12 volt. I want to know when the fan comes on. When it is cold my temp
stays at about 175 & when the outside temp goes up it runs around
190+or -. When it is warm out side & I stop for a break the fan is
running & then after a few minuets it cycles off then back on again. I
would just like to know if it does that when driving or if it stays
off longer. The fan would make a difference in you fuel consumption to
wouldn't it? When I turn my key off the solenod opens up & lets air to
the fan clutch & my fan will stay locked up till the air in the tanks
drain down. lf I turn the key back on the will release from the fan &
it will spin free. Bill if you figure out a good way to wire it let
me know.
Don Spithaler
89 SP 36'
Butler, PA In Zephyrhills, FL
> Bill 88 FC Michigan
> > Guys
> up.
> air
> know
> because
> > Don Spithaler
> > 89 SP 36'
02-17-2008, 17:45
Horton Fan
Sounds like when 12 volts is complete at the 12v/pnumatic clutch
valve it stops air from being sent to the clutch and at the same
time allows the trapped air to exhaust.??? it might be that 12 volts
is always present at the pnumatic valve and the signal is sent via a
ground.
if you were to hook up a bosch relay to read the 12 volts input +
or - that turns the fan off and connect that acting signal to Bosch
terminal 85 you could mount a bulb on the dash and hook its + side
to Bosch 87a. Terminal 87 is not used. Terminal 30 is +12 volts
ignition power.Terminal 86 is powered depending on what signal trips
the pnumatic valve.
you may want to see if the fan override switch gets a signal
backwards when the fan comes on????? that may reduce the need for a
long wire between the dash and valve.
See link below and scrool to the bottom for using positive or
negitive input to power the relay
http://tinyurl.com/5hjxm
GregoryO'Connor
94ptRomolandCa
> Greg -- Bill
it
temp
again. I
consumption to
air to
tanks
fan &
let
> me know.
> Don Spithaler
> 89 SP 36'
to
> > Bill 88 FC Michigan
> > wrote:
> > > Guys
wire it
> > up.
Would the
> > air
to
> > know
> > because
am not
> > > Don Spithaler
> > > 89 SP 36'
02-18-2008, 15:26
Horton Fan
Greg
Thanks for the info on the way to wire it. I will check the over
ride switch before I pull a wire from the back. If I end up pulling
one I have a pull line I left in the wire chase from the last time I
pulled a wire so it won't be to hard to do.
Don Spithaler
89 SP 36'
On Feb 18, 2008 12:45 AM, Gregory OConnor wrote:
> ack
ut
> ground.
> the pnumatic valve.
> GregoryO'Connor
> 94ptRomolandCa
> > Greg -- Bill
> it
> the
> temp
> again. I
> consumption to
> air to
> tanks
> fan &
> let
> > me know.
> > Don Spithaler
> > 89 SP 36'
> to
> > > Bill 88 FC Michigan
> > > wrote:
> > > > Guys
> wire it
> > > up.
> Would the
> > > air
> to
> > > know
> > > because
> am not
> > > > Don Spithaler
> > > > 89 SP 36'
11-24-2008, 13:48
Horton Fan
Guys
I put a small light at the dash to let me know when my fan comes on.
I took it out on the road today to check it out. It was cold today & I
saw the fan coming on & off at about 170 degree. That seems to cold
for the fan to be coming on & off. What do you think? What is the
sender set at & does anybody know what degree it should come on at. I
always though the fan was running more that it should.
Don Spithaler
89 SP 36'
Butler, PA
11-24-2008, 14:30
Horton Fan
190• That's what my thermostat is manufactured for
Jim Riordan
--- Don Spithaler wrote:
> Guys
> my fan comes on.
> was cold today & I
> That seems to cold
> think? What is the
> should.
> Don Spithaler
> 89 SP 36'
> Butler, PA
