Why is my gas gauge pessimistic?
02-28-2008, 06:34
Hi Scott- I have close to the same- mine will stay full for an hour then go to 1/2 and stay there for a couple days before dropping. I gauge my fuel by my robust 5 mpg. Works for me, and I don't have to tear up my wood floor in the kitchen to replace the sending unit.
Ernie Ekberg 83PT40 Livingston, Montana Delicious ideas to please the pickiest eaters. Watch the video on AOL Living. |
02-28-2008, 11:28
My gas gauge reads full when it is full, but proceeds to fall much
faster than the actual fuel level. The gauge will be at E and the 'low fuel' light on with 60-70 gals remaining. Anyone else experiencing this? No matter how "sure" I am of fuel level using my mileage log, it is still disconcerting... Scott Forman 86 PT38 Memphis |
02-28-2008, 12:36
The fuel tank is a cylinder, laying on its side. The level of the fuel moves quickly during the first quarter tank and much less quickly during the middle half, then much more quickly during the last quarter tank. (Think about the shape.)
I would describe my fuel gauge as neither pessimistic nor optimistic. I would also describe it as being generally misleading. Since I have some trouble with the fuel spitting with some fuel dispensers, I try to make a guess about how much fuel I expect to take on so I can avoid the diesel bath. Using the gauge has proven futile. Making a guess based on the miles since the last fill up at about 5 mpg gives me a better estimate. Since the 300 gallon tank gives me about 1500 miles range, I usually plan fuel stops about every 1000 miles. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Feb 28, 2008, at 3:28 PM, Scott Forman wrote:
02-28-2008, 14:29
The fuel level sensor (in mine and probably in your coach) Looks like
toilet float. It's a roundish brass sphere at the end of a long rod. On my coach the rod is about 3 feet long. The control end of the fuel gauge contains the electrical contact that remain outside your tank. If the length of the float arm is too short it could cause the symptoms that you have mentioned. The two possibilities that comes to my mind are that the float at the end of the arm has somehow slid on the shaft making the shaft arm shorter than it should be. A second thought is that a fuel level sensor for another (shallower) fuel tank has been installed on your coach. My tank is a large rectangular box with the fuel level gauge mounted to street side near the top close to the center of the tank. Good luck, Eric Perplies currently at CCW in Riverside 96' 42' WBWL --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > My gas gauge reads full when it is full, but proceeds to fall much > faster than the actual fuel level. The gauge will be at E and the 'low > fuel' light on with 60-70 gals remaining. > > Anyone else experiencing this? No matter how "sure" I am of fuel level > using my mileage log, it is still disconcerting... > > Scott Forman > 86 PT38 > Memphis > |
02-28-2008, 15:20
I wouldn't complain. First trip with my FC pulled in for fuel with quarter tank showing. Took 142 gallons to fill the 150 gallon tank. Whew!!
MH
02-28-2008, 15:23
Scott I wonder if the Empty calibration is at the level where the
genset pickup will run dry??? My gauge is optimistic, 70 gallons on empty is a free 350 mile weekend trip. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > My gas gauge reads full when it is full, but proceeds to fall much > faster than the actual fuel level. The gauge will be at E and the 'low > fuel' light on with 60-70 gals remaining. > > Anyone else experiencing this? No matter how "sure" I am of fuel level > using my mileage log, it is still disconcerting... > > Scott Forman > 86 PT38 > Memphis > |
02-28-2008, 18:02
FWIW...we all need to monitor/understand our gauges from day one of ownership. Pay attention to the readings, and then become familiar with what the gauges are telling us as we fill our tanks, temperature reading, etc.
Thu, Feb 28, 2008 at 3:28 PM, Scott Forman <"sforman@renasant.com"> wrote:
02-28-2008, 21:14
Scott,
Probably typical for the year, as my '86 is similar. I've never run it down to E, but I can get down just below 1/4 of a tank and only put ~180 gallons in. It should take 225+ gallons at that mark, which, if the thing is linear, would leave me with 45+ gallons remaining on empty. The most I've ever put in was 197 gallons. Don't recall where the gauge was, but was probably 1/8th or so. Should have read 1/3rd at that point, so quite a bit off. Anyway, at least it's inaccurate in a good way. Would rather this than running out with 1/4 tank "remaining" ... also nice to stop for fuel expecting a thousand dollar bill and only wind up paying $600. I know better but it still makes me smile every time. -Ryan '86 PT-40 8V92 On Thu, Feb 28, 2008 at 3:28 PM, Scott Forman <sforman@...> wrote: > > My gas gauge reads full when it is full, but proceeds to fall much > faster than the actual fuel level. The gauge will be at E and the 'low > fuel' light on with 60-70 gals remaining. > > Anyone else experiencing this? No matter how "sure" I am of fuel level > using my mileage log, it is still disconcerting... > > Scott Forman > 86 PT38 > Memphis |
02-29-2008, 16:57
Hi Everyone
This seems to be a fairly common problem with the mid 80s PTs. My PO told me that when the gauge reads E it still has at least 50/60 gallons left. I have never got a low fuel light. I base mine fuel time off the generator since it has a shorter pickup. When the generator shuts off and will not start back it time to get fuel. When I was in the Air Force working on airplanes ,we had to physically dip the tanks to check the quantity. Hugh & Lexie Turner 1984 Wanderlodge PT 40 âOUR DREAMâ FMCA F393612 Bluebird Chapter FCRV #75760 Pollywogs chapter Good Sam Life Member 057729600 Thomaston, Ga 30286 hturner12@...
02-29-2008, 17:28
I once had to fully drain my fuel tank to have it welded. I pulled
into the shop a few miles after the low fuel light came on. We drained my tank. When my low fuel light comes on I have 30 gallons of fuel in the tank. 70 additional gallons (a total of 100 gallons) caused my gauge to read 3/8 tank. An additional 100 gallons makes my gauge read about 5/8 full. Eric Perplies 96' 42' WBWL |
