Laminate repair
03-08-2008, 07:32
Laminate repair
Fred, where is the damaged area?
Ernie Ekberg 83PT40 Livingston, Montana It's Tax Time! Get tips, forms and advice on AOL Money Finance. |
03-08-2008, 08:27
Laminate repair
Hi Fred, I was in your coach before you bought her. Not many mid door PTs around. Hope you get it fixed.
03-08-2008, 10:19
Laminate repair
I had an accident with the laminate sidingthat is in the kitchen and bath areas,it is a damaged area that would be like a hammer strike and I was hoping if someone knew if there was a repair for this.
Fred & Jeanne Hulse
Morristown,Arizona 1997 Wanderlodge WB41 |
03-08-2008, 11:33
Laminate repair
Fred: If it is minor, the laminate company might have a filler that
would correct it, but I would bet it would show because your laminate is probably a gloss finish. A good laminate installer could overlay that entire panel if you can find a match for it. Mayber the records of your coach build are still available in the files at the factory. It so happens with mine, I have a build folder in my Blue Box that gives the colors and manufacturer. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > > I had an accident with the laminate siding that is in the kitchen and bath areas,it is a damaged area that would be like a hammer strike and I was hoping if someone knew if there was a repair for this. > Fred & Jeanne Hulse > Morristown,Arizona > 1997 Wanderlodge WB41 > |
03-08-2008, 11:50
Laminate repair
Ron
Thank you
Good idea,
I will see what I can find out.
Fred & Jeanne Hulse
03-08-2008, 12:39
Laminate repair
I have repaired a dent by using a kitchen towel over the dent and
heating the dent spot with a steam iron. Care must be taken to only draw the dent back out flat. A repair kit can be purchased to do any addition repair or you can go to a good counter top fab shop and they can do the finishing touches. Good Luck! --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" wrote: > > I had an accident with the laminate siding that is in the kitchen and bath areas,it is a damaged area that would be like a hammer strike and I was hoping if someone knew if there was a repair for this. > Fred & Jeanne Hulse > Morristown,Arizona > 1997 Wanderlodge WB41 > |
03-08-2008, 13:13
Laminate repair
Ernie
The damage is on the corner, arounded edge in the counter and sink base where there isn't a drawer.Wonderfully obvious as you enter the coach at the level between the floor and counter.
There are bits of the laminate missing resulting from the injury.
Just a reminder,I have a mid door.
Fred & Jeanne Hulse
03-08-2008, 13:22
Laminate repair
Hi Fred,
I can give you a weird solution that has worked for me in the past. If the damage is on an edge, I took Bondo and fixed the missing area. Then took small paint, the kind you find for using in model building. I experimented on a piece of plastic till I got the color mixing the same (or almost a match)then painted over the Bondo. I finished it off with a masked off area around the damage and covered it with a clear spray. Worked for me. Bob Lawrence 84 PT36 Boulder City, Nv (Fulltiming and leaving here around April 1st) > I had an accident with the laminate siding that is in the kitchen and bath areas,it is a damaged area that would be like a hammer strike and I was hoping if someone knew if there was a repair for this. > Fred & Jeanne Hulse > Morristown,Arizona > 1997 Wanderlodge WB41 > |
03-08-2008, 13:23
Laminate repair
ripsmail2
The damage was a sliding blow and did not dent,but broke the laminate into a few tiny pieces of shards not salvageable.
Fred & Jeanne Hulse
03-08-2008, 13:28
Laminate repair
Hi Bob
I am happy to hear about the Bondo plastic filler theory.
It appears that is a good solution.
I had that thought and was not certain it was viable.
Thanks
Fred & Jeanne Hulse
