DC amp meter on dash
03-21-2008, 06:55
Thanks to everyone for their input. I have replaced both alternators
with new ones. When I start the bus, I get about 14.2 on the dc volt meter on the dash. I initially get about 100 amps on the ampmeter on the dash but drops off slowly to almost 0 in 3 to 4 seconds. Any ideas? All information is greatly appreciated. Gus 89PT40 8V92T Houston, Tx |
03-21-2008, 08:22
Gus. That can be normal with good batteries that are fully charged. Try turning the heaters on to put a load on the system. That should put a load on the batteries and cause the alternators toincrease output.
Paul Downey
Versailles Ky
83 PT 35
Our Rollin Home for sale Create a Home Theater Like the Pros. Watch the video on AOL Home. |
03-23-2008, 05:02
Just this Morning at Amicalola Falls, GA in the mountains with temps at 29 degrees my amp gauge registered a draw of 150 amps on cold start, and dropped back to 50 amps where it runs normally in about 5 minutes. That sounds normal to me.
Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Gus Rodriguez
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. [url=http://us.rd.yahoo.com/evt=51733/*http://mobile.yahoo.com/;_ylt=Ahu06i62sR...o8Wcj9tAcJ ] Try it now.[/url] |
03-23-2008, 17:25
Thanks for all the input. I put a load on the system as Paul
suggested by turning on the heaters,all the lights, and the dash AC. The meter showed a little over 50 amps. It's on to my next fix. Gus 89pt40 8v92t Houston, Tx --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > Just this Morning at Amicalola Falls, GA in the mountains with temps at 29 degrees my amp gauge registered a draw of 150 amps on cold start, and dropped back to 50 amps where it runs normally in about 5 minutes. That sounds normal to me. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > > Gus Rodriguez Thanks to everyone for their input. I have replaced both alternators > with new ones. When I start the bus, I get about 14.2 on the dc volt > meter on the dash. I initially get about 100 amps on the ampmeter on > the dash but drops off slowly to almost 0 in 3 to 4 seconds. Any > ideas? All information is greatly appreciated. > > Gus 89PT40 8V92T > Houston, Tx > > > > > > > --------------------------------- > Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. > |
