Water pressure regulator/tank fill valve mystery solved
03-21-2008, 15:24
On our recent visit with Ralph and Charolette in our 89FC35, Ralph and
I performed the obligatory 'walk around' of our coach. I opened the utility hookup door, (street side rear) and Ralph immediately spotted the non standard piece of garden hose added by a PO. Ralph's comment was "get rid of that" as I tried to explain I was not the guilty party responsible for this re-engineered method for filling the pure water tank via a 1/2" hose protruding through a 1" hole bored through the backside steel bulkhead of the utility compartment. Now settled down after our South Texas travels, I'm doing preventive maintenance on the bird, 3208 & ZF service, AD4 dyer rebuild, new D2 air governor. We've had this 35FC 18 months now and that dangling piece of fill hose has bugged us long enough...previous owner told me that's the only way to fill the fresh water tank. Turns out, the first night we spent in the coach when bringing it home from GA, the regulator /fill valve leaked like a sieve (through the 2 small holes where you insert snap ring pliers for service) and the first repair I made to the coach 18 mos ago was replacing that regulator assembly. This fixed the leak. Previous owner related he did not ever hook to 'city water' but in lieu always filled the tank through this stupid hose and like a dummy I've continued to use the "hose thru the wall" instead of filling by flipping the fill switch to energize the sporlan valve. Hose is gone now and I plugged the hole with a chrome plug purchased at Lowe's. My lesson here is simple; try to keep the original systems fully operational when practical! This case of the water hose added to bypass the factory regulator could have been avoided by merely doing the preventive maintenance on the regulator and the city water function as well as the electric fill function could have remained intact. Ralph, thanks for helping us keep the Blue Bird systems working; also thanks to all who contribute to the forum. Dick Gideon Freedom Bird 1989 35FC Rolla, MO |
03-21-2008, 17:38
The mystery is why was the garden hose installed?
The potable water tank fill is an appliance on the citywaterhookup line. like an icemaker or sink. On 91 and newer birds the sporlan is a diaphram valve like a automatic lawn sprinkler valve. the valve is closed passivly then opened when the valve is energized by the switch. the problem with the notion that it is closed all the time is that when there is no pressure pushing into the input side of the sporlan tankfill valve, the diaphram that keeps the valve closed floats open. since ther is no pressure, water doesnt pass but air gets in the valve. when the plumbing system in the bus is not hooked to city water and the automatic 12 volt pump is turned off, some one is sure to open a sink valve and depressurize the plumbing lines which will float the valve open. when this happens and the bus sits for a month or two, scum builds up on the rubber and the valve will not shut closed. if the valve does not shut closed, hooking up to city water the potable tank will overfill. with the valve failed open, running on the 12volt pump you will keep removing water from the tank and refill the tank with that water so removed. Fulltimers have frequent or constant pressure up against the valve thus have not this problem but us monthly or bimonthly users welcome your "hose through the wall upgrade" One caution I see with filling the potable tank too fast via a non Bird-engeneered design is if you fill it faster than the air or over fill pipe can exhaust the air or water you build pressure in the 'not designed to be pressurized', plastic tank. This may cause the potable tank to split. talk about wetting the bed! GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Richard Gideon" > > On our recent visit with Ralph and Charolette in our 89FC35, Ralph and > I performed the obligatory 'walk around' of our coach. I opened the > utility hookup door, (street side rear) and Ralph immediately spotted > the non standard piece of garden hose added by a PO. Ralph's comment > was "get rid of that" as I tried to explain I was not the guilty party > responsible for this re-engineered method for filling the pure water > tank via a 1/2" hose protruding through a 1" hole bored through the > backside steel bulkhead of the utility compartment. > > Now settled down after our South Texas travels, I'm doing preventive > maintenance on the bird, 3208 & ZF service, AD4 dyer rebuild, new D2 > air governor. > > We've had this 35FC 18 months now and that dangling piece of fill hose > has bugged us long enough...previous owner told me that's the only way > to fill the fresh water tank. Turns out, the first night we spent in > the coach when bringing it home from GA, the regulator /fill valve > leaked like a sieve (through the 2 small holes where you insert snap > ring pliers for service) and the first repair I made to the coach 18 > mos ago was replacing that regulator assembly. This fixed the leak. > > Previous owner related he did not ever hook to 'city water' but in lieu > always filled the tank through this stupid hose and like a dummy I've > continued to use the "hose thru the wall" instead of filling by > flipping the fill switch to energize the sporlan valve. Hose is gone > now and I plugged the hole with a chrome plug purchased at Lowe's. > > My lesson here is simple; try to keep the original systems fully > operational when practical! This case of the water hose added to > bypass the factory regulator could have been avoided by merely doing > the preventive maintenance on the regulator and the city water function > as well as the electric fill function could have remained intact. > > Ralph, thanks for helping us keep the Blue Bird systems working; also > thanks to all who contribute to the forum. > > Dick Gideon > Freedom Bird > 1989 35FC > Rolla, MO > |
03-22-2008, 01:41
Greg: All good points; the sporland is working just fine; my guess
is that the PO installed the bypass hose setup simply because the check valve within the external water fill/regulator needed a good cleaning...I chose to replace the water fill/regulator because of my lack of knowledge for disassembly for service. Just adding my 2 cents regarding "quick fixes" to solve a problem and thereby possibly introducing a new problem or inconvenience. Kinda like some of those temporary fences I used to build on our farm years ago...many of them are still being used! Dick Gideon Freedom Bird 1989 35FC Rolla, MO --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > The mystery is why was the garden hose installed? > > The potable water tank fill is an appliance on the citywaterhookup > line. like an icemaker or sink. On 91 and newer birds the sporlan > is a diaphram valve like a automatic lawn sprinkler valve. the valve > is closed passivly then opened when the valve is energized by the > switch. the problem with the notion that it is closed all the time > is that when there is no pressure pushing into the input side of the > sporlan tankfill valve, the diaphram that keeps the valve closed > floats open. since ther is no pressure, water doesnt pass but air > gets in the valve. > > when the plumbing system in the bus is not hooked to city water and > the automatic 12 volt pump is turned off, some one is sure to open a > sink valve and depressurize the plumbing lines which will float the > valve open. when this happens and the bus sits for a month or two, > scum builds up on the rubber and the valve will not shut closed. if > the valve does not shut closed, hooking up to city water the potable > tank will overfill. with the valve failed open, running on the > 12volt pump you will keep removing water from the tank and refill > the tank with that water so removed. > > Fulltimers have frequent or constant pressure up against the valve > thus have not this problem but us monthly or bimonthly users > welcome your "hose through the wall upgrade" > > One caution I see with filling the potable tank too fast via a non > Bird-engeneered design is if you fill it faster than the air or over > fill pipe can exhaust the air or water you build pressure in > the 'not designed to be pressurized', plastic tank. This may cause > the potable tank to split. talk about wetting the bed! > > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "Richard Gideon" > > > > > On our recent visit with Ralph and Charolette in our 89FC35, Ralph > and > > I performed the obligatory 'walk around' of our coach. I opened > the > > utility hookup door, (street side rear) and Ralph immediately > spotted > > the non standard piece of garden hose added by a PO. Ralph's > comment > > was "get rid of that" as I tried to explain I was not the guilty > party > > responsible for this re-engineered method for filling the pure > water > > tank via a 1/2" hose protruding through a 1" hole bored through > the > > backside steel bulkhead of the utility compartment. > > > > Now settled down after our South Texas travels, I'm doing > preventive > > maintenance on the bird, 3208 & ZF service, AD4 dyer rebuild, new > D2 > > air governor. > > > > We've had this 35FC 18 months now and that dangling piece of fill > hose > > has bugged us long enough...previous owner told me that's the only > way > > to fill the fresh water tank. Turns out, the first night we spent > in > > the coach when bringing it home from GA, the regulator /fill valve > > leaked like a sieve (through the 2 small holes where you insert > snap > > ring pliers for service) and the first repair I made to the coach > 18 > > mos ago was replacing that regulator assembly. This fixed the > leak. > > > > Previous owner related he did not ever hook to 'city water' but in > lieu > > always filled the tank through this stupid hose and like a dummy > I've > > continued to use the "hose thru the wall" instead of filling by > > flipping the fill switch to energize the sporlan valve. Hose is > gone > > now and I plugged the hole with a chrome plug purchased at Lowe's. > > > > My lesson here is simple; try to keep the original systems fully > > operational when practical! This case of the water hose added to > > bypass the factory regulator could have been avoided by merely > doing > > the preventive maintenance on the regulator and the city water > function > > as well as the electric fill function could have remained intact. > > > > Ralph, thanks for helping us keep the Blue Bird systems working; > also > > thanks to all who contribute to the forum. > > > > Dick Gideon > > Freedom Bird > > 1989 35FC > > Rolla, MO > > > |
03-22-2008, 04:38
Dick, Farmers across the country had a crisis when nylon string
replaced bailing wire in hay packaging. I found a professional bailing wire device at Quartsite 07 and returned this year to buy it because my 07 statement "I can make one of these" never put metal to mill. I was disapointed when the vender didnot show up this year. Forum member, Dick Hayden found one of the tools earlier this month and sent it to me in the mail. This is a got to have tool for everyone. I will find a web site or take pics and post soon. A big thank to DickH for my much loved ClampTool GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Richard Gideon" > > Greg: All good points; the sporland is working just fine; my guess > is that the PO installed the bypass hose setup simply because the > check valve within the external water fill/regulator needed a good > cleaning...I chose to replace the water fill/regulator because of my > lack of knowledge for disassembly for service. Just adding my 2 > cents regarding "quick fixes" to solve a problem and thereby possibly > introducing a new problem or inconvenience. Kinda like some of those > temporary fences I used to build on our farm years ago...many of them > are still being used! > > Dick Gideon > Freedom Bird > 1989 35FC > Rolla, MO > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > The mystery is why was the garden hose installed? > > > > The potable water tank fill is an appliance on the citywaterhookup > > line. like an icemaker or sink. On 91 and newer birds the sporlan > > is a diaphram valve like a automatic lawn sprinkler valve. the > valve > > is closed passivly then opened when the valve is energized by the > > switch. the problem with the notion that it is closed all the time > > is that when there is no pressure pushing into the input side of > the > > sporlan tankfill valve, the diaphram that keeps the valve closed > > floats open. since ther is no pressure, water doesnt pass but air > > gets in the valve. > > > > when the plumbing system in the bus is not hooked to city water > and > > the automatic 12 volt pump is turned off, some one is sure to open > a > > sink valve and depressurize the plumbing lines which will float the > > valve open. when this happens and the bus sits for a month or two, > > scum builds up on the rubber and the valve will not shut closed. if > > the valve does not shut closed, hooking up to city water the > potable > > tank will overfill. with the valve failed open, running on the > > 12volt pump you will keep removing water from the tank and refill > > the tank with that water so removed. > > > > Fulltimers have frequent or constant pressure up against the valve > > thus have not this problem but us monthly or bimonthly users > > welcome your "hose through the wall upgrade" > > > > One caution I see with filling the potable tank too fast via a non > > Bird-engeneered design is if you fill it faster than the air or > over > > fill pipe can exhaust the air or water you build pressure in > > the 'not designed to be pressurized', plastic tank. This may > cause > > the potable tank to split. talk about wetting the bed! > > > > GregoryO'Connor > > 94ptRomolandCa > > > > --- In WanderlodgeForum@yahoogroups.com, "Richard Gideon" > > > > > > > > On our recent visit with Ralph and Charolette in our 89FC35, > Ralph > > and > > > I performed the obligatory 'walk around' of our coach. I opened > > the > > > utility hookup door, (street side rear) and Ralph immediately > > spotted > > > the non standard piece of garden hose added by a PO. Ralph's > > comment > > > was "get rid of that" as I tried to explain I was not the guilty > > party > > > responsible for this re-engineered method for filling the pure > > water > > > tank via a 1/2" hose protruding through a 1" hole bored through > > the > > > backside steel bulkhead of the utility compartment. > > > > > > Now settled down after our South Texas travels, I'm doing > > preventive > > > maintenance on the bird, 3208 & ZF service, AD4 dyer rebuild, new > > D2 > > > air governor. > > > > > > We've had this 35FC 18 months now and that dangling piece of fill > > hose > > > has bugged us long enough...previous owner told me that's the > only > > way > > > to fill the fresh water tank. Turns out, the first night we > spent > > in > > > the coach when bringing it home from GA, the regulator /fill > valve > > > leaked like a sieve (through the 2 small holes where you insert > > snap > > > ring pliers for service) and the first repair I made to the coach > > 18 > > > mos ago was replacing that regulator assembly. This fixed the > > leak. > > > > > > Previous owner related he did not ever hook to 'city water' but > in > > lieu > > > always filled the tank through this stupid hose and like a dummy > > I've > > > continued to use the "hose thru the wall" instead of filling by > > > flipping the fill switch to energize the sporlan valve. Hose is > > gone > > > now and I plugged the hole with a chrome plug purchased at Lowe's. > > > > > > My lesson here is simple; try to keep the original systems fully > > > operational when practical! This case of the water hose added to > > > bypass the factory regulator could have been avoided by merely > > doing > > > the preventive maintenance on the regulator and the city water > > function > > > as well as the electric fill function could have remained intact. > > > > > > Ralph, thanks for helping us keep the Blue Bird systems working; > > also > > > thanks to all who contribute to the forum. > > > > > > Dick Gideon > > > Freedom Bird > > > 1989 35FC > > > Rolla, MO > > > > > > |
03-22-2008, 16:34
Hi All
I had a problem filling the water.I fulltime and needed water so I disconnected the overfill above the tank and filled the water with a hose. Did not make any permanent modification .Started to look for a fix.Was advised to clean and lubricate the pressure regulator fill valve sounded difficult turned out to be very easy ( thanks Ralph ) Nothing modifed still original and works great. Mario 1985FC35 in MV MA. Coach in SoCal --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Dick, Farmers across the country had a crisis when nylon string > replaced bailing wire in hay packaging. I found a professional > bailing wire device at Quartsite 07 and returned this year to buy it > because my 07 statement "I can make one of these" never put metal to > mill. I was disapointed when the vender didnot show up this year. > Forum member, Dick Hayden found one of the tools earlier this month > and sent it to me in the mail. This is a got to have tool for > everyone. I will find a web site or take pics and post soon. A big > thank to DickH for my much loved ClampTool > > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "Richard Gideon" > > > > > Greg: All good points; the sporland is working just fine; my > guess > > is that the PO installed the bypass hose setup simply because the > > check valve within the external water fill/regulator needed a good > > cleaning...I chose to replace the water fill/regulator because of > my > > lack of knowledge for disassembly for service. Just adding my 2 > > cents regarding "quick fixes" to solve a problem and thereby > possibly > > introducing a new problem or inconvenience. Kinda like some of > those > > temporary fences I used to build on our farm years ago...many of > them > > are still being used! > > > > Dick Gideon > > Freedom Bird > > 1989 35FC > > Rolla, MO > > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > > > > The mystery is why was the garden hose installed? > > > > > > The potable water tank fill is an appliance on the > citywaterhookup > > > line. like an icemaker or sink. On 91 and newer birds the > sporlan > > > is a diaphram valve like a automatic lawn sprinkler valve. the > > valve > > > is closed passivly then opened when the valve is energized by > the > > > switch. the problem with the notion that it is closed all the > time > > > is that when there is no pressure pushing into the input side of > > the > > > sporlan tankfill valve, the diaphram that keeps the valve > closed > > > floats open. since ther is no pressure, water doesnt pass but > air > > > gets in the valve. > > > > > > when the plumbing system in the bus is not hooked to city water > > and > > > the automatic 12 volt pump is turned off, some one is sure to > open > > a > > > sink valve and depressurize the plumbing lines which will float > the > > > valve open. when this happens and the bus sits for a month or > two, > > > scum builds up on the rubber and the valve will not shut closed. > if > > > the valve does not shut closed, hooking up to city water the > > potable > > > tank will overfill. with the valve failed open, running on the > > > 12volt pump you will keep removing water from the tank and > refill > > > the tank with that water so removed. > > > > > > Fulltimers have frequent or constant pressure up against the > valve > > > thus have not this problem but us monthly or bimonthly users > > > welcome your "hose through the wall upgrade" > > > > > > One caution I see with filling the potable tank too fast via a > non > > > Bird-engeneered design is if you fill it faster than the air or > > over > > > fill pipe can exhaust the air or water you build pressure in > > > the 'not designed to be pressurized', plastic tank. This may > > cause > > > the potable tank to split. talk about wetting the bed! > > > > > > GregoryO'Connor > > > 94ptRomolandCa > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Richard Gideon" > > > > > > > > > > > On our recent visit with Ralph and Charolette in our 89FC35, > > Ralph > > > and > > > > I performed the obligatory 'walk around' of our coach. I > opened > > > the > > > > utility hookup door, (street side rear) and Ralph immediately > > > spotted > > > > the non standard piece of garden hose added by a PO. Ralph's > > > comment > > > > was "get rid of that" as I tried to explain I was not the > guilty > > > party > > > > responsible for this re-engineered method for filling the pure > > > water > > > > tank via a 1/2" hose protruding through a 1" hole bored > through > > > the > > > > backside steel bulkhead of the utility compartment. > > > > > > > > Now settled down after our South Texas travels, I'm doing > > > preventive > > > > maintenance on the bird, 3208 & ZF service, AD4 dyer rebuild, > new > > > D2 > > > > air governor. > > > > > > > > We've had this 35FC 18 months now and that dangling piece of > fill > > > hose > > > > has bugged us long enough...previous owner told me that's the > > only > > > way > > > > to fill the fresh water tank. Turns out, the first night we > > spent > > > in > > > > the coach when bringing it home from GA, the regulator /fill > > valve > > > > leaked like a sieve (through the 2 small holes where you > insert > > > snap > > > > ring pliers for service) and the first repair I made to the > coach > > > 18 > > > > mos ago was replacing that regulator assembly. This fixed the > > > leak. > > > > > > > > Previous owner related he did not ever hook to 'city water' > but > > in > > > lieu > > > > always filled the tank through this stupid hose and like a > dummy > > > I've > > > > continued to use the "hose thru the wall" instead of filling > by > > > > flipping the fill switch to energize the sporlan valve. Hose > is > > > gone > > > > now and I plugged the hole with a chrome plug purchased at > Lowe's. > > > > > > > > My lesson here is simple; try to keep the original systems > fully > > > > operational when practical! This case of the water hose added > to > > > > bypass the factory regulator could have been avoided by merely > > > doing > > > > the preventive maintenance on the regulator and the city water > > > function > > > > as well as the electric fill function could have remained > intact. > > > > > > > > Ralph, thanks for helping us keep the Blue Bird systems > working; > > > also > > > > thanks to all who contribute to the forum. > > > > > > > > Dick Gideon > > > > Freedom Bird > > > > 1989 35FC > > > > Rolla, MO > > > > > > > > > > |
